Europa-List Digest: 1 Msgs - 01/03/25
JohnFrance
PostPosted: Sun Jan 05, 2025 4:23 am    Post subject: Europa-List Digest: 1 Msgs - 01/03/25 Reply with quote
Hi Jonathan,
Europa Aviation sell silicone hoses for oil and coolant and they are excellent quality. The oil return line is moulded to the correct shape for the return to the oil tank. In my opinion, for that hose it is certainly worth using silicone as it is directly above the exhaust system. Sheath it with Thermotec sleeving or similar anyway to help protect it. The biggest risk to silicone hoses is cutting them with incorrect hose clamps.
1. 09:09 AM - Oil and water hoses (JonathanMilbank)
________________________________ Message 1 _____________________________________
Time: 09:09:29 AM PST US
Subject: Oil and water hoses
Several years ago I bought a set of silicone hoses from someone in Sweden who created
shaped coolant hoses for the Europa and also provided silicone hoses with
protective lining for the oil system. He no longer makes or provides these
items. Someone, but I can't remember who, stated that these hoses would last at
least twice as long as the rubber types and I have no reason to doubt that.
However my engine is currently off the aircraft, so a fellow pilot who has a minor
share of the aircraft would like the oil hoses to be replaced by rubber originals,
even though the silicone looks and feels supple, as good as new! I would
prefer to continue with silicone, because the recommendation is to replace
ALL rubber items every 5 years. The oil hoses are the difficult ones to access,
particularly the return line from the crankcase. But I must also consider my
friend's opinion.
So two questions, pertaining only to the oil hoses. What's the problem with continuing
to use lined silicone hoses for the oil? What specification do you recommend
for the rubber oil hoses, which I hope to purchase from a local automotive
parts supplier?
http://forums.matronics.com/viewtopic.php?p=515189#515189
Europa mono Nr 192
wdaniell.longport(at)gmai
PostPosted: Sun Jan 05, 2025 5:03 am    Post subject: Europa-List Digest: 1 Msgs - 01/03/25 Reply with quote
I tried silicone hoses water but found that i damaged the outer sheathing while wrestling them into place.  Probably my fault.     Reverted to the rotax spec.
As for changing rubber every 5 years i see it as an opportunity to have a really good look around in those inaccessible areas.
I used parker 836 pushlok for oil on buds recommendation and it has worked well.   I protect all hose with thermotec velcro sleeve.
Will
William Daniell
+1 786 878 0246
On Sun, Jan 5, 2025, 07:24 John Archer <77alembert(at)gmail.com (77alembert(at)gmail.com)> wrote:
--> Europa-List message posted by: John Archer <77alembert(at)gmail.com (77alembert(at)gmail.com)>
Hi Jonathan,
> From: "JonathanMilbank" <jdmilbank(at)yahoo.co.uk (jdmilbank(at)yahoo.co.uk)>
> friend's opinion.
> parts supplier?
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
