What did you do with you europa this week - 02/03/25
Area-51
PostPosted: Tue Mar 04, 2025 2:23 am    Post subject: What did you do with you europa this week - 02/03/25 Reply with quote
Sunday 05:30 start, pulled out the 80hp rotax unit and bolted in a 100hp rotax unit; all in a single day...
Primary ground checks yesterday; Secondary ground runs today...
5400rpm static burst check on previous 80hp prop pitch setting; 100rpm drop on both line A and line B ignition channels.
Maintenance release and log books signed off; ready for flight ops... waiting for cyclone to go away...
 Filesize:  271.24 KB
 Viewed:  14286 Time(s)
 Filesize:  253.08 KB
 Filesize:  154.92 KB
