velletazjp
Posted: Wed Apr 01, 2026 12:37 am Post subject: Z12 Review for my Experimental Robin DR250 |
Hello all,
I would greatly appreciate a review of my electrical wiring diagram, and I would be especially grateful for any feedback.
This is a 4-seat, wood & fabric, amateur-built, tailwheel aircraft. It's a clone of the famous Robin DR250.
The primary mission is day VFR, with a strong focus on mountain flying. The aircraft will also be used for cross-country flights, with occasional night VFR and light IFR operations (no icing - no precipitations) (supported by a certified GPS).
The engine is a Lycoming IO-360 (parallel valve) equipped with a Bendix-style mechanical fuel injection system. Ignition is currently provided by dual Slick magnetos, with provisions for a future upgrade to an electronic ignition system (PMAG).
The electrical generation system consists of:
- A PlanePower alternator (12V, 60A – ALY-8520LS) regulated by a B&C LR3E
- Backup alternator: B&C 410H with LS1B standby regulator
The avionics suite is based on Garmin G3X, including:
GAD27, GEA24
Dual-screen setup (PFD + MFD)
2-axis autopilot (GSA 28 servos)
The aircraft is equipped with:
Electric roll trim (Ray Allen T3-12A)
Electric pitch trim (Thomson Linear MD12)
Both trims are controlled through the Garmin autopilot servos.
The electrical distribution is organized around three buses:
MAIN BUS (20 positions)
E-BUS (10 positions)
BATT BUS (6 positions)
All using fuse blocks.
The architecture is based on the Z12 (dual alternator, single battery) design, with minimal modifications:
Replacement of fuselinks with ANL current limiters, as seen in more recent architectures
Replacement of shunt fuselinks with 1A breakers, per Garmin G3X installation manual recommendations
I am also intentionally trying to keep the number of circuit breakers to a strict minimum. At this stage, only two breakers are used, both dedicated to alternator field activation.
You will find the wiring diagram below.
Any comments, critiques, or suggestions are more than welcome.
Thank you very much for your time and expertise.
Best regards,
JP
| Description: |
 Download |
| Filename: |
DH 251 panel G3X.pdf |
| Filesize: |
81.01 KB |
| Downloaded: |
15 Time(s) |
| Description: |
 Download |
| Filename: |
F-PEZZ G3x avionique Interconex wiring schematics.pdf |
| Filesize: |
72.78 KB |
| Downloaded: |
14 Time(s) |
| Description: |
 Download |
| Filename: |
F-PEZZ electrical diagram dual Alternators single battery (Z12) G3x integration.pdf |
| Filesize: |
166.87 KB |
| Downloaded: |
16 Time(s) |
| Description: |
 Download |
| Filename: |
e-bus load analysis.pdf |
| Filesize: |
55.45 KB |
| Downloaded: |
11 Time(s) |
_________________ 2020 contribution paid |
user9253
Joined: 28 Mar 2008 Posts: 1969 Location: Riley TWP Michigan
Posted: Sat Apr 04, 2026 1:21 pm Post subject: Re: Z12 Review for my Experimental Robin DR250 |
Using one of Bob Nuckolls' diagrams with minimal modifications is a good way to go. You might consider using hall effect sensors instead of shunts.
Amploc has issued an END OF LIFE announcement for their KEY100 Hall Effect Sensor (and several others) effective June 1, 2026.
_________________ Joe Gores |
