JWalt
Posted: Thu Aug 06, 2026 7:41 am Post subject: Kolb Twinstar Mk III parts |
I have a incomplete kit that I need to find a new home. Wings are build and tail is clecoed together. I purchased this kit from the third owner and started to modify the fuse for larger doors, Parkinson's stopped my build and I need to get the parts gone.
I have the original doors and tubing that was removed for the fuse mods so it could be put back to original. I do not have the fiberglass nose. All parts have been stored inside garage.
This would be perfect for someone that has a twinstar with damaged wings or tail. Main tube is drilled and have landing gear and tires.
Kit located in Central Illinois.
Would like $650.00 or OBO.
If interested I can take pictures. Will not part out you must take everything If no interest by the end of August plane will be sent to the scrap yard.
