				 Posted: Thu Oct 19, 2006 9:39 am    Post subject: Dual Lightspeed? |
				Hey all –
 Sorry if this has been discussed already, but I combed the archives and couldn’t really find what I was looking for.  I’ve got a couple opinions privately, but thought I’d pose the question to the list.  I’m getting ready to order an engine, and originally I thought I’d go dual lightspeed ignition, but as I get closer, I’m starting to chicken out and am thinking of going single lightspeed / slick mag.   The aircraft is all electric, dual battery, and 2 alternators ( main, and SD-8 as standby).  Can I get a few people to weigh in?
 cj
 #40410
 fuse
 www.perfectlygoodairplane.net  (updated!!)
		randy(at)romeolima.com Guest
				 Posted: Thu Oct 19, 2006 10:34 am    Post subject: Dual Lightspeed? |
				With the batteries and backup alternator you are planning I'd  definitely NOT put in a mag. Klaus (Mr. Lightspeed) has a simple backup battery  schematic he provides if you don't want to do multiple buses. No question it's  better to have both plugs firing at the same time!
  Randy Lervold
  www.rv-3.com
  www.rv-8.com
  [url=http://www.rv-3.com][/url]
  [quote]   ---
		Tim(at)MyRV10.com Guest
				 Posted: Thu Oct 19, 2006 10:41 am    Post subject: Dual Lightspeed? |
				I don't see a problem with what you're doing either way.  I myself
 chickened out, so I have one mag.  It seems as it isn't a real
 bad compromise anyway, because my RPM drop is almost zero when
 shutting off the mag, but is more when I shut off the Lightspeed.
 The only negative I can say about running dual lightspeeds on
 the IO-540 is this:
 The cable that runs from the sensor under the flywheel/ring gear
 is a pain in the butt to run, and it sits pretty close to
 that wheel.  I can imagine that whole area could be somewhat
 vulnerable to having things happen to it.  Since you use the
 same sensors for dual lightspeed, I myself feel better having
 something else in the back of the engine.  If I were running
 2 P-Mags, I wouldn't have the same concern.  I'm absolutely
 not saying there's something wrong with the arrangement that
 needs to be changed...but it just isn't ideal from a reliability
 standpoint....and in a manner that would fail regardless of
 how many batteries or alternators you have.
 I had dreamed of 1 lightspeed and 1 P-Mag, but I heard
 a logical argument that due to differences in timing
 curves between systems, this might not be a great idea.
 You will love the lightspeed though, even if you still
 have that one stinkin' mag.
 Chris Johnston wrote:
 [quote] Hey all –
  cj
  #40410
  fuse
  www.perfectlygoodairplane.net <http://www.perfectlygoodairplane.net/>
   (updated!!)
		mstewart(at)iss.net Guest
				 Posted: Thu Oct 19, 2006 11:07 am    Post subject: Dual Lightspeed? |
				I ran dual for 800 hours on one bat and one alt on an RV. Never worried one bit.
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Johnston
  Sent: Thursday, October 19, 2006 1:38 PM
  Subject: Dual Lightspeed?
 Hey all –
 cj
 #40410
 fuse
		bcondrey
				 Posted: Thu Oct 19, 2006 11:11 am    Post subject: Dual Lightspeed? |
				Chris,
 I opted for dual LSE Plasma IIIs and have dual alternators and electrical busses.  The point that Tim makes is a valid one – the wiring from the crank sensor must be very well routed/secured.  With the dual system there’s a pair of cables but they are running together.  I suppose one could route one down each side of the engine to provide isolation in case of some sort of mechanical event that damage them.
 Hey all –
 cj
 #40410
 fuse
				 Posted: Thu Oct 19, 2006 11:39 am    Post subject: Dual Lightspeed? |
				I see Mike Stewart also replied that he sees no problems.
 One thing to be aware of is that Mike probably has the
 rear mounted hall effect sensors (or am I wrong, Mike?),
 so it isn't the same as the IO-540 crank sensor mount.
 Bob's got a good idea of separate routing.  I was also
 *slightly* personally worried about the fragility of
 the electronics up under that hub...and about the
 what-if's during bad weather, or even lightning/static
 discharge.  Again, I'm not saying "don't do it"...just
 giving my rationalization.  I'm just as swayed to go
 dual electronic some day...I just don't quite yet have
 the nads required.  At least it runs great with just
 one, or I'd be just diving right into it.
 Condrey, Bob (US SSA) wrote:
  	  | Quote: | 	 		   Chris,
		gorejr(at)bellsouth.net Guest
				 Posted: Thu Oct 19, 2006 11:55 am    Post subject: Dual Lightspeed? |
				Before you decide you might talk to some larger players in the engine building business like BPE.   They are building my engine and said they would not consider building it with either the Lightspeed or Lazar systems.  They have had to many problems.  They are building mine with 2 Bendix mags.  As an aside I have the Lazar on my mooney and have not had a problem.  There is supposed to be a new system coming out this next year that is superior to these 2 according to BPE.  Good luck!  Jim
  Date: 2006/10/19 Thu PM 01:38:15 EDT
  Hey all -
  couldn't really find what I was looking for.  I've got a couple opinions
  privately, but thought I'd pose the question to the list.  I'm getting
  ready to order an engine, and originally I thought I'd go dual
  lightspeed ignition, but as I get closer, I'm starting to chicken out
  cj
  #40410
  fuse
  (updated!!)
		jjessen
				 Posted: Thu Oct 19, 2006 12:02 pm    Post subject: Dual Lightspeed? |
				And, Tim, you have a standard mag, not a p-mag?
 John J
		bcondrey
				 Posted: Thu Oct 19, 2006 12:16 pm    Post subject: Dual Lightspeed? |
				FWIW, before making the decision to go single or dual I was having a
 discussion at OSH last year with Klaus.  While talking Jon Johanson
 (south pole fame) came by.  Turns out he runs a dual system!  Now, I
 don't know which engine or pickups he had - 4 cyl can have either hall
 effect modules that replace the mags or a crank sensor, 6 cyl only has
 the crank sensor as an option.  I've noticed within the last few days
 some chatter about the hall effect modules leaking oil after a few
 hundred hours.  It was mentioned during that discussion that the crank
 sensor was much more reliable although nothing quantitative to back it
 up.
 Bottom line: it's all about risk management.  In a dual LSE
 configuration there's communication between the boxes which supposedly
 provides some additional nominal improvement.
 Following are the risks that I identified before making the leap along
 with mitigation thoughts:
 - all electric ignition; lose the electrons and you're a glider.  This
 is managed by either a second battery wired as in the LSE instructions
 or a dual electrical system.  Of course, having a single LSE and one mag
 also eliminates this.
 - crank sensor assembly as a single point of failure.  The assembly
 actually contains 2 of everything and the only thing common is the
 actual circuit board that the components are mounted on.  This assembly
 (steel plate with circuit board mounted to it) is bolted to the
 crankcase behind the crankshaft flange.  After the flywheel is in place
 it's very well protected.
 - wires from crankshaft sensor may be subject to damage.  As I said in
 my earlier post, easiest way to mitigate this is to run one down each
 side of the engine.  Biggest risk here is probably the alternator belt
 breaking and somehow damaging the wire.  Highly unlikely that you'd have
 damage to both if they had separate paths.
 It would be easy to get REALLY carried away, but the reality is that
 there are a lot of single points of failure (fuel lines after the valve,
 control linkages, carb or injection system components, engine mech
 failure, etc).  Bottom line: You have choices here - if dual electric
 ignitions is going to cause you to lose sleep at night, go with a single
 and a mag.
				 Posted: Thu Oct 19, 2006 12:38 pm    Post subject: Dual Lightspeed? |
				Yessir, that's correct.
  John J
		flysrv10(at)gmail.com Guest
				 Posted: Thu Oct 19, 2006 2:04 pm    Post subject: Dual Lightspeed? |
				I know that you can rationalize anything you do and this is the way I rationalized my decision.  There are good reasons for electronic ignitions, they just were not good enough for me.
 I decided against electronic ignitions for couple of reasons:
 If you break down during your travel, no one can fix your system at the airport.  You will have to order parts and work on it yourself while being distracted from your intended trip.  This is my strongest objection against anything that is not known at airport shops.  I recently lost the alternator on my trip and experienced this personally.  Since I had to be at my destination the next day, I left the plane with a mechanic, ordered the alternator from Van, drove the rest of the trip and came back to pick up the plane after my business ended.
 If you are looking for fuel economy, you will get it with mags at high altitude and high power.  Mag timing is  advanced to give you the best performance at your cruising speeds and altitude.  I am assuming that you are building this plane for something other than local short trips.
 Mags, as short lived as they seem to be in service, can take a lot of beating and still continue functioning.  On one of my trips, I noticed a missed beat in my RV6.  I found that the mag seal was gone and it was full of oil, but it still worked.
 I am not sure if Slick's Lasar system is reliable.  If so, that would be my choice.
  Rob
 On Oct 19, 2006, at 1:38 PM, Chris Johnston wrote:
 Hey all –
 cj
 #40410
 fuse
		AV8ORJWC
				 Posted: Thu Oct 19, 2006 7:10 pm    Post subject: Dual Lightspeed? |
				Chris, this is an excellent discussion point but be sure and evaluate all the characteristics.  By reading today’s posts, most of the decisions were a “I follow the leader” mentality.  “I don’t know why but the crowd is moving towards the noise.  So I guess I should follow”  A responsible solution is to study the characteristics, ask experienced operators, weigh the pluses and minuses.  That means make a list.
 At this time the six cylinder P Mag is not yet an alternative.  It merits review.  The GAMI supplenator and PRISM are not yet to market.  The magneto and electronic ignition  systems are.  Do not limit your knowledge input.
 Which performs better at idle?
 Which assists in resisting Lead Fowling of your plugs?
 Which makes use of automotive plugs rather than aviation?
 Which is more reliable?
 Which is more cost effective over its entire life?
 Which is easier to maintain on the road when traveling distances from your maintenance base?
 Which produces more horsepower and performance in the range requests by the pilot?
 Which works better at altitude?
 Which does not change spark advance over the range of load, F/A temperature and rpm?
 What is Flame Front Propagation and why does it require a change in spark advance to maintain BMP?
 Which system will respond better to an alternative fuel to 100LL?
 Which one is less prone to failure and ensuing safety concerns?
 Your work is not done. Before you reach a conclusion, ask the pros.  You will likely get a choir of similar answers here which might not qualify the value of the answer enough.  This input has not yet been comprehensively tabulated.  In the lack of a conclusion on the subject. My source is Barrett.  The dyno says HP drop with dual electronics.  Research the why and the negatives before throwing out the baby with the bath water.
 John W. Cox
 #40600
 Do not Archive until all of the meaningful input is recorded.
  Sent: Thursday, October 19, 2006 10:38 AM
 Hey all –
 cj
 #40410
 fuse
		coop85(at)bellsouth.net Guest
				 Posted: Fri Oct 20, 2006 4:03 am    Post subject: Dual Lightspeed? |
				One last (probably not) consideration for you aside from the redundancy issues.  When I was looking at the Lightspeed options, I talked to Klaus and he indicated about 90% of the performance advantages are obtained with the first system and there is a limited performance increase by using dual electronic ignition systems.  Since I had not already put in the dual alternator/battery setup I opted for a Lightspeed/standard mag setup.  My only backup battery is in the Dynon EFIS I use as the standby instrument.
 Marcus
 40286
 60 hours and loving it
 Hey all –
 cj
 #40410
 fuse
				 Posted: Fri Oct 20, 2006 4:55 am    Post subject: Dual Lightspeed? |
				Talk to Rhonda at Barrett.  I think you might consider changing your mind about using these systems.  These folks are in the experience loop!  They deal with these issues daily.  Jim
  Date: 2006/10/19 Thu PM 11:10:22 EDT
  Subject: RE: Dual Lightspeed?
  all the characteristics.  By reading today's posts, most of the
  decisions were a "I follow the leader" mentality.  "I don't know why but
  the crowd is moving towards the noise.  So I guess I should follow"  A
  knowledge input.
  the pilot?
  bath water.
  John W. Cox
  #40600
  Johnston
  Hey all -
  cj
  #40410
  fuse
  (updated!!)
				 Posted: Fri Oct 20, 2006 6:22 am    Post subject: Dual Lightspeed? |
				I had dual hall effects in my 6.
 Have Direct crank in my 8.
 Do not archive.
		billderou(at)yahoo.com Guest
				 Posted: Fri Oct 20, 2006 9:06 am    Post subject: Dual Lightspeed? |
				I have a question for those familiar with Lightspeed (etc) ignition systems that I have been pondering for some time. Purchased a 25 SFOH engine with new mags and saw no good reason to upgrade. One mag was equipped with dual points "flash of sparks" and added a SlickStart in place of the old Bendix vibrator. It starts easily.
   If you configure a system with Lightspeed and a Slick mag I would assume that the Lightspeed is firing at 25 degrees advanced up to 45 degrees while the Slick mag is always firing at 25 degrees. So what is happening to the force of the gas explosion?
   I cannot imagine that the Slick is contributing to the ignition if the Lightspeed is advanced beyond 25 degrees. Therefore, does the single, hotter Lightspeed spark create more explosive force than two mags firing at 25 degrees? Is this the root of the cruising performance gain?
   From  Lycoming, setting the mags at 25 degrees, I would assume this is optimum. What is gained when advanced beyond this point? How would the cockpit controlled variable timing be used strategically? Do we have firm evidence that a Lightspeed/mag configuration produces more horsepower than two mags?
   I understand the ease of starting argument but need more facts to understand the claim of higher cruise performance.
   Bill DeRouchey
   billderou(at)yahoo.com (billderou(at)yahoo.com)
   flying
 "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net> wrote:
   [quote]--> RV10-List message posted by: "Stewart, Michael (ISS Atlanta)"
 Do not archive.
				 Posted: Fri Oct 20, 2006 9:58 am    Post subject: Dual Lightspeed? |
				Bill DeRouchey wrote:
  	  | Quote: | 	 		   I have a question for those familiar with Lightspeed (etc) ignition
 I'm not sure of the lowest lightspeed advance setting, but it may be
 well below 25.  Remember that mags are set at 25 for the best
 cruise setting.  The lightspeed can very depending on the
 power setting, both MP and RPM.
  	  | Quote: | 	 		   I cannot imagine that the Slick is contributing to the ignition if the
 I'm sure it's still contributing, just not as much.  You still get
 the burn from the other side of the cylinder somewhat.  I don't think
 there's any change in explosive force, just a hotter spark that ignites
 quicker.  I think you will find there is an argument as to whether or
 not there is a performance gain, or a loss...there are arguments on
 both sides.
  	  | Quote: | 	 		   From Lycoming, setting the mags at 25 degrees, I would assume this is
 I think you can gain some fuel efficiency.  I would not recommend
 the cockpit controlled variable timing.  I don't know that there is
 any firm evidence of power increase with Lightspeed/mag.   I
 do know that the Lightspeed equipped engines I've heard are
 considerably smoother sounding than engines with only mags.
 It's the fuel economy and smoothness that lead me to them.
 Keep in mind that one of the other huge benefits is the lightspeed
 will keep your plugs cleaner and let you use cheaper auto plugs.
 In my previous plane, I was FORCED to clean the plugs...actually
 remove them and pick out the lead and scale, every 25-50 hours,
 even though I leaned aggressively.  On my new engine, it ran
 smooth so I didn't pull the plugs until 70 hours...and then after
 checking the front 4, I stuck them back in because they were
 perfect, and skipped the rest.  Now, at 170 hours, it still
 runs great, and soon I'll pull them again just to see how
 it's looking.
 I wouldn't bet on the performance aspect.
 [quote] Thanks,
  Bill DeRouchey
  billderou(at)yahoo.com <mailto:billderou(at)yahoo.com>
  flying
      Do not archive.
		LessDragProd(at)aol.com Guest
				 Posted: Fri Oct 20, 2006 10:33 am    Post subject: Dual Lightspeed? |
				Just my opinion:
  The hotter Lightspeed spark fires five (5) times during each combustion  stroke.
  The magneto "25 degree" spark advance is a single point setting that is  "always safe" for the harshest power setting.  It is NOT optimized for a  normal cruise power setting.
  Jim Ayers
  In a message dated 10/20/2006 10:08:16 AM Pacific Daylight Time,  billderou(at)yahoo.com writes:
   	  | Quote: | 	 		     (Stuff Cut)
    From Lycoming, setting the mags at 25 degrees, I would assume this is    optimum. (Stuff Cut)
    Bill DeRouchey
    flying
				 Posted: Fri Oct 20, 2006 10:36 am    Post subject: Dual Lightspeed? |
				So since I’m the guy that started this and I’ve been reading everything I can about it all, I’ll chime in a bit…but I’ll qualify my input thusly – I’ve never built an aircraft before this one, and I’ve never owned one either.  I’ve also never worked on an aircraft engine in my life.  All of my info comes from my previous life of building drag racing engines of various flavors for fun.  and sometimes blowing them up.
 I too wondered about the effect of having 2 sparks happen at different times – and from what I can gather, the second (25 degrees BTDC)spark doesn’t do much of anything when the first spark is firing at full advance (around 45 degrees BTDC).  When the firing of both sparks is closer, I would suspect that (and I have no data to support this – just a guess) the first spark initiates the combustion at a more optimal time, and the second just contributes to the ignition of the remaining gas charge, and depending on the speed of the flame front, may not do much still.  According to lightspeed’s site, the spark is an uninterrupted 20 degrees in duration.  I don’t know what the duration of the magneto’s spark is (maybe someone else does?), but I imagine that at most RPMs and MPs, the lightspeed spark would happen at a more optimal time, and the magneto spark would sort of “chime in” upon reaching 25 deg BTDC while the lightspeed is still firing. At least conceptually this seems fine to me.
 In theory, I suppose that you could also run much leaner without roughness, because you can advance the timing to a point that you will still achieve a complete burn (or more complete I should say) of the fuel charge.  Again, in theory, you could lean and lean and lean, and advance (with manual control) and advance and advance, and get a very low fuel burn.
 To answer your question about advance, the 25 degree setting of a magneto doesn’t seem optimal.  I sort of look at it as a middle of the range value that works everywhere (at all altitudes – within reason of course) but isn’t really optimal everywhere.  In a race car, you’re tuning so that everything is optimal at WOT and nowhere else.  As long as the car will idle on the starting line without choking itself out, you’re good.  Of course you’re pouring unburned fuel into the exhaust pipes and the car wants to shake itself to pieces, but that’s ok.  I’d basically run mechanical advance only (no vacuum advance), and have it all in at something like 2500 rpms, if the redline was around 6500 or 7000.  If I remember right, fully advanced, it’d be somewhere in the neighborhood of 45 or 50 degrees at full advance, and somewhere around 25 to 30 degrees at idle.  Advanced timing and long spark duration is what you need if the rpms are up and the cylinder pressures are high.  Add nitrous, and everything changes (see the above note about things blowing up). In an aircraft where the air pressure changes, the mixture can be controlled from the cockpit, and WOT equals 2600 or 2700 rpms, 25 degrees of advance seems ok, but it seems to be a compromise that costs the engine efficiency as rpm and mixture changes.
 Again – I’M NO EXPERT.  Mostly, I’d get under the hood wind the engine up to full throttle, and turn the distributor back and forth til the thing ran right, then look at the number with the timing light and say “oh. I guess that’s the number.”  I realize that a bit more finesse is required when your life depends on the thing running right… J
 cj
 #40410
 fuse
		AV8ORJWC
				 Posted: Fri Oct 20, 2006 4:03 pm    Post subject: Dual Lightspeed? |
				Flame front propagation is a fascinating topic.  F/A mixture is hotter near the exhaust valve that a comparatively cooler intake valve. Heat is a catalyst for combustion.  If it is a charged carbon deposit and ignites a mixture at other than the required timing it gets its own name – Detonation.  If the event happens before the piston is ready to provide the power-stroke and it is before the exalted event, it is called PRE – ignition.  Read the GAMI site.  The theory is they both meet in the middle in perfect harmony.  Distributor, Mag timing and Electronic timing and all things spark related need to change with the change of engine load and rpm.  A finite setting does not enhance this phenomena.
 The phrase Optimum is a mis-leader in that it is the better of a poor trade off.  PRISM will address this need for a changing advanced spark curve.  One of the vulnerabilities of Mags is they are Primeval – Brain Dead simple and reliable at a single setting throughout a range of performance requirements.
 Everyone building should make their personal decision based on research rather than popularity of the moment.
 John Cox
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill DeRouchey
  Sent: Friday, October 20, 2006 10:06 AM
 Bill DeRouchey
 flying
  Do not archive.
