propellerdesign(at)tele2. Guest
Posted: Tue Oct 24, 2006 12:09 pm Post subject: Re Propellers |
The right place is 75% radii from center of hub to tip, or 25% from tip, if diameter is 68" that is 8,5" from the tip or 25,5" from center.
when an total change of half degree+ make a difference from a standard prop to an cruise prop, 2 degree at the tip make some difference if it is only at the tip.
But as Dave measured, and difference of half deg make a lot difference on a whole blade.
is #1 = 47,75" pitch
#2 = 48,58" pitch
#3 = 49,40" pitch
I got 47,89" on a Standard and 49,64 on a Cruise prop in my program at 75%
Jan
Dave said<
>all 3 blades are same degrees on tip ( about 10,5 degrees) but the
measurements at this station is about .82 the length of prop. Not
ideal but I used what I had....
blade 1 15.25 deg
blade 2 15.50+ deg
blade 3 15.75 to 16 approx.<
dave
Posted: Tue Oct 24, 2006 1:08 pm Post subject: Re Propellers |
Ok , Just went out to shop and got more accurate measurements.
Here are the three measurements that I took as follows.
Distance from centre of hub
25 25.5 at tip 34 1/8 inch
Blade 1 15.25 15.75 -10 (light 10 degree)
Blade 2 15.50 16.50 10
Blade 3 16 16.75 +10 ( heavy 10 degree)
as it turns out the 25 Inch from centre was my original measuring point no .82 of the length - my mistake.
My conclusions -well I know it flys well now as you see it set above and wx sucks today for accurate measurements 15 gusting 24 in light rain and snow showers so I wait for another day.
but I think maybe set all three blades at the 25.5 inch place to about 16.25 to 16.5 degrees... how does this sound > ? And the tip ? Well we worry about that later I guess.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Float Flyr
Posted: Tue Oct 24, 2006 4:30 pm Post subject: Re Propellers |
To be clear ..
What you are saying is the folks at Warp are wrong and the blades pitch angle should be set at and all equal at .75 the length of the blades.
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
dave
Posted: Tue Oct 24, 2006 5:46 pm Post subject: Re Propellers |
Ok, I just put together new GSC 68 " blade tonight and did preliminary pitch setup on shop table.
Set at 16 degrees to start and that is measured with GSC protractor and it fits snug at 23.75 inches from centre of hub.
in my calculation that comes out to 69.9 % radii.
Measuring at tip gives about the same 13 degrees on each blade approx.
Wx permitting I will re adjust WARP and test fly and try GSC as well.
I do have a 70 or 72 inch IVO UL prop 2 blade that I have used on same Kitfox with 3 to 1 box but IVO does not recommend it. on a 2.68 it supposed to be fine. The Blades are brand new and I only tested for an hour or so.
It is for sale if anyone wants it or if IVO is reading this I will trade you for a suitable prop to test and publish the numbers. They say a Medium is a better fit for a 582 3 to 1 box.
Same goes for any prop manufacturer, send me a prop and I will try and video and publish the numbers. If you got it -, might as well flaunt it. Repeat business is best from word of mouth and practical testing.
Dave
Posted: Wed Oct 25, 2006 4:40 am Post subject: Re Propellers |
I am saying that if the blades is made uniform with each other you can use any reference point to make them equal pitch.
If they are like it seems not uniform, 70 - 75 % radii is best.
Why? this is not only the center of thrust but also the peak of thrust, differences here make a bigger difference then at the tip or near the hub.
from 60 to 90 % the thrust is high, from 90% to tip it is reduced, and from 60% to 15% it is also reduced to zero.
To compare different props the 75% station is best, due to different twist between different brands.
Jan
Float Flyr
Posted: Wed Oct 25, 2006 9:06 am Post subject: Re Propellers |
So Warp is at fault here for producing at least six blades the are not consistent.
Thanks..... I bought an Ivo-ul primarily because of the in cockpit adjustable feature ( floats ) but when I contacted Warp it was going to take weeks before any blade ordered would be shipped.
The Ivo has its idiosyncrasies too. they require that you check the torque on the mounting bolts at regular intervals... They are so adamant about this that they don't put holes for lock wire in the heads of the bolts because they say people don't want to cut a little lock wire to check the prop torque.
I think the Ivo does a bit of coneing but that is away from the cowl. I do know it's a lot smoother than the time expired GSC it replaced. I would consider going back to GSC with the cockpit adjustable two blade hub with the nickel edge Warp blades if it would fit on my Rotax "B" box PSRU. (it won't) Now I'm not sure about the Warp blades.
Noel [quote]
Kitfox III-A
dosmythe(at)cox.net Guest
Posted: Wed Oct 25, 2006 9:41 am Post subject: Re Propellers |
Noel,
I started this thread about the tips of the Warp blade. Actually, I first reported it over 5 years ago and nobody ever came back with a check of their own. First off, even if it's a true situation that doesn't make it a bad prop. You noticed I said "IF". The beauty of this List is the ability to see what's going on in the Kitfox world. We have uncovered many problems in the last 10 years or so. Some were very minor and some a whole lot bigger. I have a strong feeling this tip thing is a minor problem. In the ideal world, all list members owning a Warp would go to the airport on a lazy day and map out their props and report back. If it turns out that many see the same situation then we would have leverage to go to Warp and report our findings. They might just have to relax their opinion on measuring at the tips.
Bottom line, I don't think Warp is at fault for making bad blades. I do feel strongly that measuring at the tips is not the best way to go. Lets face it, measuring at the 75% point can't be a safety or dangerous method and as pointed out on this thread, the 75% point is the hardest working point.
Don Smythe
dave
Posted: Wed Oct 25, 2006 4:17 pm Post subject: Re Propellers |
Don, pretty well said there. I did change all three of mine after a flight at dawn.
I set hem all at the .75 mark 25.5" from center of hub. One tip was out about 1 degree.
To be honest I really don't think that I found any differnances and if anything perhaps a little less vibration.
I did not have a chance to get again till about noon and winds were 10 g 15 knots on ground and kinda bumpy and hard to get good numbers.
I finally got out again at about 4:30 til 5:30 temp 39F winds on ground 7 knots and at 3000 asl ( 2000 agl) about 20 knots
I did climbs and still remains 1200 to 1400 fpm ,cruise about 88 to 90 mph (at) 5900 rpm and fuel flo about 19 to 20 litres / hour.
I have a GSC here 68" as well and will try it as soon as I can this week hopefully and report back.
Dave
dave
Posted: Wed Oct 25, 2006 4:31 pm Post subject: Re Propellers |
Warp blades ok in my book.
Warp blades are probably too heavy for a B box. You should get a C or E box with rubber damper for smoother operation as well. E box would be my choice.
2 blade props should not be used on 582 with 3 to 1 ratio. Not sure exact reason but might be some resonance or something that causes extra strain and stresses and will possibly lead to failure. I don't think Warp or IVO recommend this. IVO will allow a medium prop on a 3 to 1 box because of it's larger size hub over 5 " whereas the smaller one is about 4 inches.
Dave
PS Warp Blades take about 2 to 3 weeks to get , GSC a week and IVOs overnight. WARPs with nickel leading edge is most abrasion resistant for dirt, sand, stone and float operations
Posted: Thu Oct 26, 2006 3:24 am Post subject: Re Propellers |
Dave,
That's either good or bad depends on how you look at it. At least, a point is starting to get made that the tips are suspicious. If you had pitched at the tips you would have had that 1 degree error at the .75 station. Maybe I'll go back to Warp and see what they say now. I think that is 3 or 4 of us that see a little error. I lost track.
Don Smythe
dave
Posted: Thu Oct 26, 2006 3:47 am Post subject: Re Propellers |
Yes Don,
So I will trry to get some more accurate testing done and see. Now it would be interesting to see what Warp has to say and the reasoning for their approach to adjusting at the tip.
Maybe WARP thinks their blades are 100 % uniform from root to tip. Once thing I did not check was the tracking, although I should have . I will go out to shop now and look and let you know soon.
Also as you can see from the movies we did last Weekend from the Trailer park <snicker> http://www.cfisher.com/kitfox/ this Kitfox is not lacking in short field performance in my opinion. So what does that say about the Warp prop that seem to not be uniform ? Any comments on a better way to test ?
Dave
Posted: Thu Oct 26, 2006 4:21 am Post subject: Re Propellers |
Dave,
See below
>> Maybe WARP thinks their blades are 100 % uniform from root to tip.>>
I think that Warp chose the tips because it's a reference point for them. They want to know what pitch you have for a particular plane/engine when they provide service. If everybody uses the same point (tips) they have a good reference base. It doesn't do them much good to have a customer give them a pitch of 27 degrees and another give them 15 degrees for the same plane/engine setup. Maybe, just maybe they don't really realize that their tips "could" be off just a tad????
>>that say about the Warp prop that seem to not be uniform ?>>
Again, I think the blades are very uniform (in my case anyway) all the way except the last 2". I think this is a very minor situation but worth knowing about. When we adjust our props, we want to be exact as possible. Right????
Don Smythe
Posted: Thu Oct 26, 2006 4:27 am Post subject: Re Propellers |
Dave,
Why not call Stuart at Powerfin and ask if you can borrow a 68" 3 bladed F-blade prop for testing?
Phone <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />1 (509) 924-7556 - Toll Free 1 (800) 581-8207
Jan
Float Flyr
Posted: Thu Oct 26, 2006 4:40 am Post subject: Re Propellers |
I agree with every thing you have said here.... And I will usually find something to disagree with, so this is a to me an event.
I still find it amazing with this information, apparently reported to Warp several times, they haven't changed their manuals to designate the .75 station as the place to measure prop angles.
I would also like to strobe a Warp prop at Take off speed. I'm willing to bet dollars to doughnuts that there is some flexing going on as centripetal forces increase. Blade flex to decrease pitch with rpm, as I understand it, occurs in the Boer prop used on SuperCub sea planes.
Noel [quote]
Kitfox III-A
dave
Posted: Thu Oct 26, 2006 4:47 am Post subject: Re Propellers |
OK , just went out again and measured prop -- all 3 blades at 25.5 inches from centre of hub at 16 degrees
Measured at tip as follows 10 , 10.125 10.875
tracking of all three measured at tip within .125 inch at most more like about 3/32s
Went for flight temp 37 F air dead calm every direction at under 200 agl flew 88 70 89.5 mph via gps in any direction at low altitude.
Did this for 20 mins. Very pretty when you see every chimney and smoke stack with a vertical column of smoke going steady - straight up ........
Prop works well , GSC going to get tested next - hopefully today !!
Dave
dave
Posted: Thu Oct 26, 2006 4:48 am Post subject: Re Propellers |
If you know him have him email me ..... I would be more than happy to compare his best choice to the others.
Dave
dave
Posted: Thu Oct 26, 2006 5:31 am Post subject: Re Propellers |
Noel it a Borer prop and they are a must have for a super cub on floats.
Same goes for Kitfox - We need a ultimate search for the best prop for Kitfoxes.
I sure the 582 as I have one and they are probably the most intalled engine in Kitfoxes.
Prop manufacturers should be happy to show off their product. I am not looking for handouts but I have paid for every other prop I have.
If anyone wants it tested "un- biased" well let me know .
Dave
PS can we geta Borer prop for a Kitfox ?
lcfitt(at)sbcglobal.net Guest
Posted: Thu Oct 26, 2006 5:57 am Post subject: Re Propellers |
Jan,
Not familiar with the term F-blade. Is that new to Powerfin?
I fly regularly with a group that does long cross countrys together and lots
of high altitude and short field stuff in the back country of Idaho. Two of
the guys switched to Powerfin propellers about 3 or four years ago. One
switched from a GSC wood, and one from a Warp - pitched at the 75% station
incicentally.
Both guys had reduced cruise with the powerfin and this was determined by
the overall pace of the flight of six guys over three or so years of flying
in loose formation together. Pitching for optimum cruise and climb was a
challenge. The Powerfin climbed very well, but at the expense of top end
and the top end never equalled what they had before. I always liked it when
they were on their Powerfin props because I could wander off to see
something of interest and always had the top end to easily catch up. Not so
easy now - one went back to his GSC and now has the IVO and the other is
back to the Warp.
I have been flying behind a Warp 70 inch three blade and could always stay
in reasonably close performance range with the Powerfin in climb and miles
ahead in cruise. My Model IV is heavy - 700 lbs - but is very clean with
lots of fairings.
Lowell
Posted: Thu Oct 26, 2006 6:53 am Post subject: Re Propellers |
Hi
The model F is there largest blade, recommended to be 68" 3 blade on the 582 3:1
Interesting, I would have bet that it was faster but not did climb as good as the Warp.
I think the Powerfin use Clark Y airfoil, and the Warp have RAF6 style. GSC I don't know.
the difference is that RAF has the nose radii starting from the flat bottom, Clark Y the nose radii is higher up.
RAF have better take off performance then Clark, but Clark have higher efficiency.
But it all depends on blade twist, thickness, blade area ...
Do you know if they used same diameter on the Powerfin as the other and what blade model it was?
Jan
Ps. I have no business with any propeller maker, just interested to get the best out of it.
Posted: Thu Oct 26, 2006 8:09 am Post subject: Re Propellers |
Jan,
I went to the Powerfin site and think they were using the F blade. To
improve performance a bit, they cut some off the end of the prop. I don't
know how much but an inch comes to mind.
Lowell
