owl40188(at)yahoo.com Guest
Posted: Thu Oct 26, 2006 12:51 pm Post subject: Flo-Scan |
I couldn't find the Flo-Scan fuel flow measuring idevice in Vans accessories catalog. I was thinking of getting it and installing it when I do my fuel system as I am getting close to that step. Is there a reason not to get it yet as I am not sure which engine instument system I will go with?
thanks
Niko
LarryRosen
Posted: Thu Oct 26, 2006 1:27 pm Post subject: Flo-Scan |
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
LarryRosen
Posted: Thu Oct 26, 2006 1:56 pm Post subject: Flo-Scan |
#40356
N205EN (reserved)
<http> |
ainut(at)hiwaay.net Guest
Posted: Thu Oct 26, 2006 2:04 pm Post subject: Flo-Scan |
This info is a couple of years old, but the Flo-Scan senders 1) restrict fuel flow, and worse 2) create turbidity in the fuel. There were a couple of better sensors but I can't remember any brand names. Sorry.
David M.
Nikolaos Napoli wrote:
[quote] I couldn't find the Flo-Scan fuel flow measuring idevice in Vans accessories catalog. I was thinking of getting it and installing it when I do my fuel system as I am getting close to that step. Is there a reason not to get it yet as I am not sure which engine instument system I will go with?
thanks
Niko
bcondrey
Posted: Thu Oct 26, 2006 2:33 pm Post subject: Flo-Scan |
EI makes one that is compatible electronically with a Flo-Scan 201 and is available as a separate item. I ordered the fuel flow sensor from Advanced Flight Systems for their engine monitor and that is what I received.
http://www.buy-ei.com/Accessories.htm Picture shows a Flo-Scan but the actual FT-60 is a red cube.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David M.
Sent: Thursday, October 26, 2006 5:01 PM
Subject: Re: Flo-Scan
David M.
thanks
Niko
0123456789012345
dlm46007(at)cox.net Guest
Posted: Thu Oct 26, 2006 2:40 pm Post subject: Flo-Scan |
check with the maker of your engine monitor. If you are , for example, buying the GRT EIS 6000 you will be getting a floscan. If your are buying JPI engine analyzer you will get a different sensor.
RobHickman(at)aol.com Guest
Posted: Thu Oct 26, 2006 5:22 pm Post subject: Flo-Scan |
The flow transducer will work better on an injected engine if it is place in the line from the throttle servo to the fuel distribution block on the top of the engine.
The EI transducer is not electrically the same as the Flow Scan unit, it puts out about twice as many pulses and you engine monitor has to be able to accept the higher data rate.
Rob Hickman
www.Advanced-Flight-Systems.com
Posted: Thu Oct 26, 2006 6:51 pm Post subject: Flo-Scan |
Go right to the source. I bookmarked this two days ago for when I order.
http://www.floscan.com/html/blue/accessories.php
first item on the list is model 231, the one you want if you use the flo-scan.
Rob Wright
#392
Tailcone attach
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RobHickman(at)aol.com
Sent: Thursday, October 26, 2006 8:21 PM
Rob Hickman
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234567890123
Deems Davis
Posted: Thu Oct 26, 2006 7:40 pm Post subject: Flo-Scan |
Rob, Why the 231? I couldn't find any specs on it on their site. However
they do list the 201 (3 models) for aviation purposes, but I couldn't
find a price listed anywhere?
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
Rob Wright wrote:
| Quote: | Go right to the source. I bookmarked this two days ago for when I order.
flo-scan.
Rob Wright
#392
Tailcone attach
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of
*RobHickman(at)aol.com
*Sent:* Thursday, October 26, 2006 8:21 PM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Flo-Scan
Rob Hickman
www.Advanced-Flight-Systems.com <http://www.Advanced-Flight-Systems.com>
Posted: Thu Oct 26, 2006 7:59 pm Post subject: Flo-Scan |
Well, I based my search criteria off of what I saw other discussing
recently. I thought it was one of the Jims or Johns mentioning using the
231. Yeah, I should know better than to put faith in other, non-hallowed
Vans employees!
A quick call to Vans may clear this up as to which model the supplied
bracket fits, but even that may end up being universal to the 201 series and
the 231 model.
I didn't even check the aviation versions once I saw the search go to the
231. Funny there are no prices for the 201s, and no info on the 231!
More research necessary! If some of you actually intelligent guys could do
it though, would you please let this caveman know while I'm out banging
rivets?
Rob Wright
#392
Tailcone attach
bhughes(at)qnsi.net Guest
Posted: Fri Oct 27, 2006 5:13 am Post subject: Flo-Scan |
There is another option with GRT and fuel injection. They offer an option to monitor the injector pulse to determine fuel flow. I will be using this option on my rotary conversion. It should work with any injection system.
Bobby
40116
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Thursday, October 26, 2006 5:40 PM
Subject: Re: RV10-List: Flo-Scan
Posted: Fri Oct 27, 2006 6:36 am Post subject: Flo-Scan |
Thanks for all the info. I guess I am going to wait until I decided on which engine instrument package I am going to use.
Niko Napoli
lm(at)viscomvisual.com Guest
Posted: Fri Oct 27, 2006 6:38 am Post subject: Flo-Scan |
How precise is this method compared to the FF sender? Has anybody got experience?
Lorenz
40280
apilot2(at)gmail.com Guest
Posted: Fri Oct 27, 2006 7:30 am Post subject: Flo-Scan |
Only on injection that uses timed injection pulses. It wouldn't work
on any continuous flow injection, like the Bendix that Lycoming puts
on their certified engines..those injectors are passive orifices, with
no pulsing involved.
On 10/27/06, Bobby J. Hughes <bhughes(at)qnsi.net> wrote:
Bobby
40116
LloydDR(at)wernerco.com Guest
This is the same method they use for the Eggenfellner Subaru, GRT is monitoring the fuel injection pulse for fuel flow rates.
Dan
40269 (N289DT)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bobby J. Hughes
Sent: Friday, October 27, 2006 9:12 AM
Subject: RE: RV10-List: Flo-Scan
Bobby
40116
Posted: Fri Oct 27, 2006 8:27 am Post subject: Flo-Scan |
Kelly,
That makes since or more folks would be using this option. I have only
flown carburetor Lyc's. So only EFI systems can use this option.
Bobby
Deems Davis
Posted: Fri Oct 27, 2006 8:32 am Post subject: Flo-Scan |
I used their 'request a quote feature' and sent them a request for price
for the 201A-6 Aviation model and asked them what the difference was
between it and the 231.
Deems Davis # 406
Rob Wright wrote:
Vans employees!
the 231 model.
rivets?
Rob Wright
#392
Tailcone attach
rv10builder(at)bellsouth. Guest
Posted: Fri Oct 27, 2006 2:15 pm Post subject: Flo-Scan |
I talked to the folks at Flo-Scan a couple of months ago and posed this
same question. If I recall correctly their response was that the only
difference between the two units was the number of notches in the rotors
for each unit and how many times it interrupts the light beam for a
given flow. They led me to believe they were otherwise identical until
I mentioned the word "airplane" when immediately I was advised to only
use the 201. I then proceeded to discuss my interest as "experimental
aircraft" and was told "conceivable I could use the 231, but...". I
assume this is due to them only getting certification for the 201.
I bought a brand new 231 off eBay from a Marine supply for $100, but now
that I have a GRT will use the 201 supplied with the EIS. When I was
considering a BMA EFIS the folks there advised the 231 as many of their
customer have used them with great success.
Brian
40308
http://www.mykitlog.com/rv10builder
Deems Davis wrote:
price for the 201A-6 Aviation model and asked them what the difference
was between it and the 231.
Deems Davis # 406
> the
> non-hallowed
> Vans employees!
> series and
> the 231 model.
> the
> could do
> rivets?
> Rob Wright #392
> Tailcone attach
Posted: Fri Oct 27, 2006 2:44 pm Post subject: Flo-Scan |
Hey all -
Here's a silly question that I've been wondering - why doesn't anyone
use a flush latch on the oil door like on a Cessna? also, anyone know
where you can pick one up? I was just looking at the baggage door
latch, then started thinking about the Cessna version, which got me
thinking about the oil door... of course, i'm supposed to be working...
cj
#40410
fuse
www.perfectlygoodairplane.net
Rick S.
