GrummanDude
Posted: Sun Oct 29, 2006 12:22 am Post subject: Manifold pressure |
Did an interesting test today.
2004 Tiger with a JPI 800. With Manifold Pressure.
My TIger, 1987 Tiger with a JPI 800.
Engine not running: both indicate the same manifold pressure
During a climb at WOT (wide open throttle) from 4000 ft to 6500 feet,
manifold pressure in the 2004 was 1/2 inch less.
Straight and level, WOT, MAP in the '04 Tiger was 7/10 inches less.
I've thought for a long time that the design of the carb air inlet on
the AG5B was stupid. Now I'm convinced.
________________________________________________________________________
across the web, free AOL Mail and more.
| - The Matronics TeamGrumman-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ Gary
AuCountry Aviation
Home of Team Grumman |
FLYaDIVE(at)AOL.COM Guest
Posted: Sun Oct 29, 2006 3:44 am Post subject: Manifold pressure |
In a message dated 10/29/2006 3:24:02 AM Eastern Standard Time, teamgrumman(at)aol.com writes:
Quote: | --> TeamGrumman-List message posted by: teamgrumman(at)aol.com
________________________________________________________________________ |
Gary:
Where is the manifold pressure being taken from for each gage?
What I'm thinking is: Since we know the poor configuration and fuel distribution that the intake manifold offers, could it be this, that is showing the difference between your gages.
Then again they are only gages. Made by different manufactures and I believe the JPI uses a transducer while the planes gage is a Boron(sp) Tube. Lots of mechanical differences their also. There is also the scales range to consider. What is the advertised accuracy of the each of the gages? Are the reading differences between the gages within that accuracy range?
GAUD! I hate being so QA Analytical.
Barry
"Chop'd Liver"
flyv35b(at)minetfiber.com Guest
Posted: Sun Oct 29, 2006 4:47 am Post subject: Manifold pressure |
Posted: Sun Oct 29, 2006 4:53 am Post subject: Manifold pressure |
Barry,
Read his email again. Both planes had JPI instrumentation and used the same transducer in all likelihood. Also, they both indicated the same MP on the ground. That sounds as if the instrumentation is NOT a factor to me. At any rate I'd be willing to buy Gary's theory about the poor induction system on the AG5B models.
BTW, it's bourdon tube. But I'm not sure if that's the type gauge the AG5B used or not.
Cliff
Posted: Sun Oct 29, 2006 8:03 am Post subject: Manifold pressure |
Disregard the last comment. None of the single engine Grummans ever had MP gauges from the factory.
Cliff
GrummanDude
Posted: Sun Oct 29, 2006 10:16 am Post subject: Manifold pressure |
I thought I made it clear that both planes have a JPI 800. Same
instrumentation. Same transducers. The pressure is being measured
from the fuel injection port on the #3 cylinder on both planes. The
length of tubing to the MAP transducer is the same.
AuCountry Aviation
GrummanDude
Posted: Sun Oct 29, 2006 10:23 am Post subject: Manifold pressure |
I need a test AG5B to create an STC for a diffferent inlet. The same
(stupid) air filter and airbox will be used.
AuCountry Aviation
923te(at)cox.net Guest
Posted: Sun Oct 29, 2006 11:44 am Post subject: Manifold pressure |
I have one...how long do yu need it for?
FLYaDIVE(at)aol.com Guest
Posted: Sun Oct 29, 2006 2:20 pm Post subject: Manifold pressure |
In a message dated 10/29/2006 11:04:44 AM Eastern Standard Time, flyv35b(at)minetfiber.com writes:
[quote] Disregard the last comment. None of the single engine Grummans ever had MP gauges from the factory.
Cliff
GrummanDude
Posted: Mon Oct 30, 2006 9:33 am Post subject: Manifold pressure |
Well, based on how long the FAA is taking with the cowling .... TBD. I
wish you lived closer.
AuCountry Aviation
