rdewees(at)mindspring.com Guest
Posted: Sat Oct 28, 2006 2:20 pm Post subject: Microair 769 |
I have had my Microair 760 installed and running for almost two years
and concur with several of the results others have mentioned-- The
transmitter seems to function adequately with it's 5 or 7 watts and I
have no complaints with it. The receiver audio appears to be very
selective though. Many signals are clear and easily understandable,
while others-- towers and ATC are often distorted and difficult to
understand. I have tried various headsets and my Lightspeed ANR is the
best but there are still 30 percent of signals that are very difficult
to understand. I wonder if the percent of distortion in the audio
amplifier is high or there is an overdriven stage in the receiver
causing problems. I read a great review of the radio before I bought it
but nothing in the last few years. I did notice that when I was trying
it out on the ground without the engine running it was very voltage
sensitive. If the input voltage was less than 12 or so the receiver
volume was very low to almost unaudable. It seems almost linear in it's
volume to voltage response between 12 and 14 volts. In the plane the
panel voltmeter reads 14 so low voltage is no issue. Wonder if anyone
has ideas on distorted audio. The open-mike intercom is a whole other
issue. If both headsets aren't the same impedance one hears loud audio
and the other can't hear well at all. Guess it's one of the compromises
of a cheap integrated intecom.
Ron
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Sat Oct 28, 2006 6:56 pm Post subject: Microair 769 |
In a message dated 10/28/2006 5:23:53 PM Central Daylight Time, rdewees(at)mindspring.com writes:
| Quote: | If the input voltage was less than 12 or so the receiver
panel voltmeter reads 14 so low voltage is no issue. |
Now THAT is very interesting- since my 760 is on the E-bus, it's normal supply voltage is typically 12.5 volts. Next time I'm trying to communicate with another plane and the reception is crappy, I'll flip the e-bus switch and see if things improve- good observation!
Mark
_________________ From The PossumWorks... |
ulflyer(at)verizon.net Guest
Posted: Sat Oct 28, 2006 8:49 pm Post subject: Microair 769 |
Unplug the mikes of your head sets, see if it makes any
difference. Many intercoms VOX turn the audio input on for both
mikes at the same time rather than just the one activating the
VOX. The makes the background noise floor twice as high. Using a
head set with a dynamic mikes will substantially increase the
noise, headsets the electret mike made a world of
difference. Wonder how I learned this....
jerb
At 05:19 PM 10/28/2006, you wrote:
years and concur with several of the results others have mentioned--
The transmitter seems to function adequately with it's 5 or 7 watts
and I have no complaints with it. The receiver audio appears to be
very selective though. Many signals are clear and easily
understandable, while others-- towers and ATC are often distorted
and difficult to understand. I have tried various headsets and my
Lightspeed ANR is the best but there are still 30 percent of signals
that are very difficult to understand. I wonder if the percent of
distortion in the audio amplifier is high or there is an overdriven
stage in the receiver causing problems. I read a great review of
the radio before I bought it but nothing in the last few years. I
did notice that when I was trying it out on the ground without the
engine running it was very voltage sensitive. If the input voltage
was less than 12 or so the receiver volume was very low to almost
unaudable. It seems almost linear in it's volume to voltage
response between 12 and 14 volts. In the plane the panel voltmeter
reads 14 so low voltage is no issue. Wonder if anyone has ideas on
audio and the other can't hear well at all. Guess it's one of the
compromises of a cheap integrated intecom. Thanks
Ron
nuckollsr(at)cox.net Guest
Posted: Mon Oct 30, 2006 8:14 am Post subject: Microair 769 |
At 11:46 PM 10/28/2006 -0500, you wrote:
Unplug the mikes of your head sets, see if it makes any difference. Many
intercoms VOX turn the audio input on for both mikes at the same time
rather than just the one activating the VOX. The makes the background
noise floor twice as high. Using a head set with a dynamic mikes will
substantially increase the noise, headsets the electret mike made a world
of difference. Wonder how I learned this....
jerb
>I have had my Microair 760 installed and running for almost two years and
RF power output for this radio is rated at 4w which is
quite adequate for VHF Comm applications in aircraft.
| Quote: | > The receiver audio appears to be very selective though. Many signals
> are clear and easily understandable, while others-- towers and ATC are
> often distorted and difficult to understand. I have tried various
> headsets and my Lightspeed ANR is the best but there are still 30
> percent of signals that are very difficult to understand. I wonder if
> the percent of distortion in the audio amplifier is high or there is an
> overdriven stage in the receiver causing problems.
Audio amplifier quality doesn't vary with circumstance.
If it's okay some times and not okay other times, there's
an external force or some other variable at work . . .
| Quote: | > I read a great review of the radio before I bought it but nothing in
> the last few years. I did notice that when I was trying it out on the
> ground without the engine running it was very voltage sensitive. If
> the input voltage was less than 12 or so the receiver volume was very
The best way to explore this is with a bench check.
The radio needs to be operated under controlled conditions
while varying only one condition at a time.
| Quote: | > It seems almost linear in it's volume to voltage response between 12
> and 14 volts. In the plane the panel voltmeter reads 14 so low voltage
> is no issue. Wonder if anyone has ideas on distorted audio. The
> open-mike intercom is a whole other issue. If both headsets aren't the
> same impedance one hears loud audio and the other can't hear well at
> all. Guess it's one of the compromises of a cheap integrated intecom.
Many intercoms, integrated or not will produce variable
results with different brands of headsets. When I was
more in-the-business, unmatched headsets was the #1
performance issue in audio systems. I did an audio
system specification for the Gates-Piaggio GP180 about
25 years ago that called for totally independent microphone
amplifiers with a small degree of volume leveling. The
output impedance of the headphone amplifiers was very
low so that variability in one headset does not produce
noticeable effects in other headsets. I had to take that
approach because products of choice at that time were
already showing deficiencies in tolerating headset
variability. It CAN be done . . . but almost nobody
does it.
If you want your radio bench checked, you can mail
it to me and I can quantify some of the variables you've
hypothesized about and at least confirm or eliminate
the radio as the root cause of your dissatisfaction.
