ignition module wiring
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List
jpkarnes2000(at)msn.com
PostPosted: Thu Jan 26, 2006 11:24 am    Post subject: ignition module wiring Reply with quote
Listers:
I am electrically challenged and would like a "how-to" guide to correctly
wire my TP-45 ignition module. I have the pick-up wires and the wires
leading to the coil. Which wires go where? Thanks!
John Karnes
601 HDS
Bremerton, WA
- The Matronics Stratus-List Email Forum -
http://www.matronics.com/Navigator?Stratus-List
frank.hinde(at)hp.com
PostPosted: Thu Jan 26, 2006 11:32 am    Post subject: ignition module wiring Reply with quote
I can fax you the wiring diagram ...I can even fax it to your email if
you adobe acrobat installed.
Frank
PostPosted: Fri Jan 27, 2006 7:59 am    Post subject: ignition module wiring Reply with quote
About to fax the wiring diagram to your email.
Note I had to reverse the connection from the ND magnetic pickup to the
TP 45 to get it to work...But work just fine it does..Smile
Frank
Billvt
PostPosted: Fri Jan 27, 2006 4:32 pm    Post subject: ignition module wiring Reply with quote
Mag Pickup + (usually a red wire) goes to TP45 G
Mag Pickup - (usually a white wire) goes to TP45 W
Coil + goes to TP45 B
Coil - goes to TP45 C
Bill
PostPosted: Mon Jan 30, 2006 7:28 am    Post subject: ignition module wiring Reply with quote
Yes I had to wire mine up the way Bill said...even though the original
instructions showed the W & G wires reversed...It didn't work this way.
One thing missing from the instructions below is the ground needed for
the stud...This HAS to be a very good ground, I uses a separate wire
back to the engine block just to make sure.
Frank
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List All times are GMT - 8 Hours
