jconnell(at)rconnect.com Guest
Posted: Wed Nov 01, 2006 6:58 pm Post subject: Need a floating ball for fuel quantity sight tube |
Hi Guys,
I use a piece of clear fuel tubing looped between the top
and bottom fittings of my wing tanks. Inside the tube at
the top and bottom is a spring to prevent the tube from
kinking. I would like to add a floating ball to help me better
locate the fuel level. (I'm in the tri-focal generation.) What
would you recommend that would not dissolve? I can bend
the end of each spring to keep the ball out of the tank...
Joe Connell
Stewartville, MN
Kitfox-II N62JK
