jd(at)lawsonimaging.ca Guest
Posted: Wed Nov 01, 2006 6:01 am Post subject: no battery contactor? |
Greetings...
I'm just wondering what the justification for eliminating a
battery contactor as per Z17 or Z-20?
Also, if the S700-2-10 split master type switch can be
replaced by a 2-3, per appendix Z, how should it be wired,
exactly?
Thanks...
Regards, J.
flying: Zenith STOL CH701/912 C-IGGY, 350 hrs.
building: Sonex #325, Jabiru 3300/6, 85% completed
| J. Davis, M.Sc. | (computer science) |
| *NIX consulting, SysAdmin | jd at lawsonimaging.ca |
| c/o Brandywine Aviation | voice: 519.289.1527 |
| 5507 Irish Dr., Appin, ON | http://www.cleco.ca |
| N42 47.33 W081 36.50 31/13 | 2000+ x 60', elev: 740' |
To most people the sky is the limit.
To those who love aviation, the sky is home.
Take charge of your attitude. Don't let someone else choose
it for you.
nuckollsr(at)cox.net Guest
Posted: Wed Nov 01, 2006 6:46 am Post subject: no battery contactor? |
At 08:59 AM 11/1/2006 -0500, you wrote:
Greetings...
I'm just wondering what the justification for eliminating a battery
The engine drive power sources for a number of small
engines have limited output. The classic battery contactor
implementation consumes 0.7 to 1.0 amps for the
duration of flight. In most cases, there's energy-to-
burn while the main alternator is functioning but
for Rotax and Jabiru engines, this resource is small
(8-18 amps) and a builder may elect to avoid power
losses represented by the installation of a battery
contactor.
Indeed ANY airplane can use a manual switch in lieu
of a contactor . . . but recall that one of the design
goals for a contactor is that when the master switch
is OFF, the amount of hot wiring between battery and
battery switch is minimized.
| Quote: | Also, if the S700-2-10 split master type switch can be replaced by a 2-3,
per appendix Z, how should it be wired, exactly?
A 2-3 is not progressive transfer . . . so the battery
and alternator come on and off together. This presents
a problem for conducting battery-only ground ops
where an alternator might come alive even with the engine
not running and load the battery unnecessarily during
ground testing.
If you use a 2-3, the pulling the alternator field
breaker during ground ops takes the place of the
progressive transfer feature of the 2-10 where
the system can be alive on battery only.
Looking at the back of the switch, the 2-3 is
wired just like a 2-10.
Posted: Thu Nov 02, 2006 7:17 am Post subject: no battery contactor? |
Thanks, Bob. Clear, concise and timely, as usual ;')
<nuckollsr(at)cox.net>
> Greetings...
contactor.
> 2-3, per appendix Z, how should it be wired, exactly?
ground testing.
Regards, J.
it for you.
