waj(at)quik.com Guest
Posted: Thu Nov 02, 2006 12:54 pm Post subject: Mamual flaps on the 601XL? |
Hello group ,I started welding up the flap components today .I may be overlooking the flap controls on the plans ,are they only electrically controlled .If possible I would rather have manual controls . Thanks Wade Jones
nfivesl(at)yahoo.com Guest
Posted: Thu Nov 02, 2006 1:33 pm Post subject: Mamual flaps on the 601XL? |
Hi Wade:
Many of us who are past that point have looked into the possibility and pondered the possibilities for hours. The conclusion I arrived at was there just isn't a good way to get the lever past the center spar. Also, an electric actuator is so simple and works so well that there's no reason to do a lever IMHO. I used this type of actuator since it has internal limit switches:
http://www.cooknwithgas.com/11_17_04_Actuator.JPG
Here are all the parts I fabbed up to use up all the 4" of travel in the actuator:
http://www.cooknwithgas.com/11_21_04_Flaps.JPG
Good luck with whatever you decide to do.
Scott Laughlin
Omaha, Nebraska
601XL/Corvair
Finishing up BRS installation
DO NOT ARCHIVE
Posted: Thu Nov 02, 2006 3:46 pm Post subject: Mamual flaps on the 601XL? |
Thanks Scott , I will proceed on with welding up all the flap components .I was trying to get by without paying the high price for the actuator ,($500.00 +) . I believe I thanked all who replied about my fuselage skin thickness ,if not thanks to Ed and all the rest . Wade
Posted: Thu Nov 02, 2006 5:27 pm Post subject: Mamual flaps on the 601XL? |
Go here and search on "linear": www.surpluscenter.com
Item# 5-1577-2 has 2 inches of travel while 5-1577-4 has 4. The companion controller can memorize intermediate stops: 5-1577-C. Each of these are well under $100. The disadvantage compared to the factory actuator is that the stops are not adjustable. So you need to build some adjustment into your linkage.
-- Craig
