nuckollsr(at)cox.net Guest
Posted: Thu Nov 02, 2006 8:47 pm Post subject: Current limiter and/or Circuit breaker for alternator |
At 04:40 PM 11/2/2006 -0800, you wrote:
| Quote: | If I install a current limiter, say an ANL80, should I still also install
a conventional 60 or 70 amp circuit breaker in the alternator output? Or
is that an unnecessary redundancy? If it's not necessary, is there any
down side to having both, other than the additional minimal weight and cost?
Thanks for any input.
The whole idea behind the ANL is to get the alternator
b-lead out of the cockpit . . . and if it's out of the
cockpit, then ANL or equivalent devices for circuit
protection are called for. Breakers under the cowl
don't make much sense.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
