jacques.voynaud(at)cegepa Guest
Posted: Fri Nov 03, 2006 10:06 am Post subject: wing root fuel gauges |
Is anyone using the wing root fuel gages sold by sportplane? I'm wondering if there is a need to drill holes in the tank wall to install those E If so, isn't there a possible leak problem, since the wall is quite thin? Any other advise or comments on this equipment would be appreciated E
Jack
jacques Evoynaud(at)cegepat Eqc Eca ([email]jacques Evoynaud(at)cegepat Eqc Eca[/email])
Lynn Matteson
Posted: Fri Nov 03, 2006 10:44 am Post subject: wing root fuel gauges |
I am using them and they work quite well. I have a model IV, and my
fiberglass tanks had the necessary holes already in them, tapped, and
ready to receive the supplied nipples from John and Debra McBean's
Kitfox Aircraft/Sportplane wing root gauge kits. When I installed mine,
all I needed to do was custom fit the printed panels (can't think of
what they're called) to my root rib...a few minutes work with the
Dremel tool.
Lynn
Kitfox IV Speedster...Jabiru 2200
On Friday, November 3, 2006, at 01:05 PM, Jacques Voynaud wrote:
| Quote: | Is anyone using the wing root fuel gages sold by sportplane? I'm
install those. If so, isn't there a possible leak problem, since the
would be appreciated.
Jack
jacques.voynaud(at)cegepat.qc.ca
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
