wvu(at)ameritel.net Guest
Posted: Fri Nov 03, 2006 8:03 pm Post subject: Engine trouble shoots |
Ran my engine again today with two new Slicks. Below is the summary. I would appreciate if anyone can provide insights to the troublesome numbers.
1. Fuel Pressure read 2.2psi at 1700rpm with boost pump off. 2.3psi with the boost pump on. A little low don't you think?
2. Mags check resulted in about 100rpm drop on both mags. Normal.
3. EGT on only #2 and #4 are high ~1500deg at 1700rpm. What up with this?
4. When cycling the prop lever MAP does not decrease during the first inch as I was pulling the lever back. Is this normal?
5. Pulling the mixture to idle cutoff resulted in no increase in rpm before the engine quits - engine runs lean. Richened the adjustment on the fuel servo one full turn in the direction of the "R-->"caused the engine to run rough and quit after a few seconds at 1700rpm. That was pro'ly too aggressive an adjustment but did I turn it in the correct direction?
6. Electrical system read 11.7V and -4Amp as measure by GRT EIS. Hall effect sensor is installed on battery side. Cycling ALT switch didn't appear to make a difference. Will check wiring.
BTW, she weighed in at 1625lbs.
Anh
#141
Tim(at)MyRV10.com Guest
Posted: Fri Nov 03, 2006 8:32 pm Post subject: Engine trouble shoots |
DejaVu wrote:
| Quote: | Ran my engine again today with two new Slicks. Below is the summary. I
Way low...but do you trust the calibration of your sensor,
and what sensor and EIS are you using. With a change of
only .1 psi, it's either Waaaaaay off in scale or there's
something wrong with the sensor/wiring. You should be able to
get 30+ psi with the electric boost pump, and it'll run in the mid
20's with just the diaphragm pump.
| Quote: | 2. Mags check resulted in about 100rpm drop on both mags. Normal.
You may need to run it more to figure this one out, but those
cylinders could be running too lean. Is that full rich
mixture? If so, are you sure you're getting full travel
on the cable or full mixture?
| Quote: | 4. When cycling the prop lever MAP does not decrease during the first
| Quote: | 5. Pulling the mixture to idle cutoff resulted in no increase in rpm
direction?
Don't know about the adjustment, but you definitely want a
small RPM rise when you get it leaned way out.
| Quote: | 6. Electrical system read 11.7V and -4Amp as measure by GRT EIS. Hall
Ahhhh, the GRT EIS.... You may not be charging, if you're only reading
11.7V and that number is real. Try a regular voltmeter on it once
while running and see if it matches. If so, you may need to dig
into why it isn't charging. Now that I know it's the GRT EIS,
I can say that there's definitely a lot of scale factor and
offset programming to do. Make sure all of the inputs are wired
into the proper inputs, but every sensor comes with a scale factor
and offset setting to use. I don't have the standard GRT fuel pressure
sensor, so don't trust mine, but here's an example of mine.
Not sure if it's current though. Note that depending on your software
version, you may not have all inputs active....not all GRT EIS's are
sold with every function. You may want to take the software version
and call GRT and verify what all is included with your version.
The fuel flow cal's are definitely not calibrated at this point,
so this config is at least 145 hours old.
Aux1 ManP
Aux2 LEFT
Aux3 RITE
Aux4 Fpsi
Aux5 AMPS
Aux6
Units IFG
FC1 0
FC2 0
FloCal 200
FloCalR 0
Tach P/R 3 (used on Lightspeed)
Peak 10
Max Fuel 60
1SF 198
1OFF 64
2SF 44
2OFF 119
3SF 47
3OFF 127
4SF 63
4OFF 47
5SF 93
5OFF 177
6SF 0
6OFF 0
I/D DIIDII
Good luck on it and if I can be of help let me know. 1625 is
a great weight.
Anh
#141
Kellym
Posted: Fri Nov 03, 2006 8:59 pm Post subject: Engine trouble shoots |
numbers.
Right for carb, low by factor of ten for injection.
Not too high. EGT relates to mixture, not power output. You can achieve
same EGT at 1700 as at cruise, but at 1700 it isn't important, because
you are at way below 50 percent power.
Yes, you are putting more load on the engine with constant power.
direction?
Something else is involved. Adjusting the idle mixture one turn should
not affect your partial power much, but if you have Bendix/Precision
injection 1 full turn is too much. Make adjustments one notch at a time.
Quarter turn is likely what you needed.
Anh
#141
KCHD |
flysrv10(at)gmail.com Guest
Posted: Sat Nov 04, 2006 3:56 am Post subject: Engine trouble shoots |
You might want to wait before making idle mixture adjustments if you have new engine. My engine idled really rough during the ground run ups but did fine after the engine loosened up.
Rob Kermanj
On Nov 3, 2006, at 11:59 PM, Kelly McMullen wrote:
[quote]--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
DejaVu wrote:
| Quote: | Ran my engine again today with two new Slicks. Below is the summary. I would appreciate if anyone can provide insights to the troublesome numbers.
| Not too high. EGT relates to mixture, not power output. You can achieve same EGT at 1700 as at cruise, but at 1700 it isn't important, because you are at way below 50 percent power.
| Quote: | 4. When cycling the prop lever MAP does not decrease during the first inch as I was pulling the lever back. Is this normal?
| Quote: | 5. Pulling the mixture to idle cutoff resulted in no increase in rpm before the engine quits - engine runs lean. Richened the adjustment on the fuel servo one full turn in the direction of the "R-->"caused the engine to run rough and quit after a few seconds at 1700rpm. That was pro'ly too aggressive an adjustment but did I turn it in the correct direction?
| Something else is involved. Adjusting the idle mixture one turn should not affect your partial power much, but if you have Bendix/Precision injection 1 full turn is too much. Make adjustments one notch at a time. Quarter turn is likely what you needed.
| Quote: | 6. Electrical system read 11.7V and -4Amp as measure by GRT EIS. Hall effect sensor is installed on battery side. Cycling ALT switch didn't appear to make a difference. Will check wiring.
Anh
#141
-- Please Support Your Lists This Month --
(And Get Some AWESOME FREE Gifts!)
November is the Annual List Fund Raiser. Click on
the Contribution link below to find out more about
this year's Terrific Free Incentive Gifts provided
by:
* AeroElectric www.aeroelectric.com, and
* The Builder's Bookstore www.buildersbooks.com,
* Aeroware Enterprises www.kitlog.com, and
* HomebuiltHELP www.homebuilthelp.com!
List Contribution Web Site
Thank you for your generous support!
-Matt Dralle, List Admin.
- The RV10-List Email Forum -
--> http://www.matronics.com/Navigator?RV10-List
Posted: Sat Nov 04, 2006 4:47 am Post subject: Engine trouble shoots |
| Yes
| Yup
| Quote: | 3. EGT on only #2 and #4 are high ~1500deg at 1700rpm. What up with this?
| EGT is useless as a finite number. Too many variables exist to know what the 'real number' is. Location of the probe is the biggest variable. I've seen changes in EGT in different spots around the tube as sell as distance from the flange.
| Could be .... read on!
| Maybe.
| Quote: | Richened the adjustment on the fuel servo one full turn in the direction of the "R-->"caused the engine to run rough and quit after a few seconds at 1700rpm. That was pro'ly too aggressive an adjustment but did I turn it in the correct direction?
| Well, not necessarily. The engine could have been too rich to start with and didn't get to a good, lean mixture before idle cutoff. Flies in the face of conventional wisdom, I know. You'll have to play with this and experiment a lot. Have someone look at the exhaust when you start up/shut down. You may be able to see black smoke if it's rich. Small R/L changes and slow (real slow) mixture control changes will make the task take longer but are more meaningful. Changes in EGT will tell you a lot. Let us know just what the outcome is!
| Best guess is that you don't have 'field' voltage. You should be able to measure the same 11.7V (or real close) at the field terminal, with the master and alt switch on. | Quote: | BTW, she weighed in at 1625lbs.
| I hope someone's keeping track of this item! It'll be interesting to see how empty weight changes the performance.
Linn
Anh
#141
jesse(at)itecusa.org Guest
Posted: Sat Nov 04, 2006 7:30 am Post subject: Engine trouble shoots |
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DejaVu
Sent: Friday, November 03, 2006 11:03 PM
To: RV10
Subject: Engine trouble shoots
1. Fuel Pressure read 2.2psi at 1700rpm with boost pump off. 2.3psi with the boost pump on. A little low don't you think? If it truly is that number, that would definitely be a little low. My question would be, “are you absolutely sure you have the right sensor and the right sensor setting in your engine monitor?” Would the engine even start with this low of fuel pressure.
2. Mags check resulted in about 100rpm drop on both mags. Normal. This doesn’t seem normal if your fuel pressure is truly 2.2PSI. Again, check that fuel pressure sensor.
3. EGT on only #2 and #4 are high ~1500deg at 1700rpm. What up with this? Try swapping sensors on 1&5 with 2&4 and see if you still get the same high readings. If so, then try hooking up the wires for 2 to the sensor for 6 (while it is still in 6) and see if it still reads that high. If so, then you either have bad sensors or bad wiring.
4. When cycling the prop lever MAP does not decrease during the first inch as I was pulling the lever back. Is this normal? No clue whatsoever.
6. Electrical system read 11.7V and -4Amp as measure by GRT EIS. Hall effect sensor is installed on battery side. Cycling ALT switch didn't appear to make a difference. Will check wiring. The Alt field (as Van’s calls it) switch makes about 3-5 Amps difference in my current draw on the Dynon ammeter shunt. Are you sure the alternator is working? If not, that would account for your low voltage, probably. You shouldn’t be drawing 4 amps when the alternator is running, unless your sensor is in a place where you would see all current draw in the system not accounting for the amount of charging you are getting. We have ours setup between the battery and the bus/alternator (it sounds like this is where yours is) and it shows total/overall current into or out of the battery.
BTW, she weighed in at 1625lbs. With or without the pilot? J
Anh
#141
0123456789012345
-- Release Date: 11/3/2006
11/3/2006
