jgswartout(at)earthlink.n Guest
Posted: Tue Nov 07, 2006 3:40 pm Post subject: Definition of Alternator B-lead? |
Bob has recommended keeping the B-lead out of the cockpit to avoid electromagnetic interference with instruments & radios. How much of the B-lead are we concerned about? Looking at Z-13/8, it seems to me that all five wires connected to the battery contactor (except the master switch wire), plus the E-bus main feed path, are all electrically equivalent to the B-lead. Does that mean, if the goal is to keep the B-lead out of the cockpit, that the battery, the battery contactor, and the three power busses must be forward of the firewall too? If not, where do you draw the line? What’s the ideal, and if one must compromise, how should one prioritize component location?
Thanks.
John
nuckollsr(at)cox.net Guest
Posted: Tue Nov 07, 2006 4:45 pm Post subject: Definition of Alternator B-lead? |
At 06:36 PM 11/7/2006 -0500, you wrote:
| Quote: | Bob has recommended keeping the B-lead out of the cockpit to avoid
line? What s the ideal, and if one must compromise, how should one
The "b-lead" is limited to that hunk of wire that
runs from the alternator to the circuit protection
(classically a breaker on the panel).
The b-lead has strong magnetic fields modulated
with alternator ripple. It's useful to keep this
(and all other FAT wires) as far from potential
victims as practical . . . if everything BUT the
bus feeders could be kept forward of the firewall,
super. Depart from this 'ideal' as needed but make
all practical efforts to maintain separation.
< with experiment. >
< --Lawrence M. Krauss >
mprather(at)spro.net Guest
Posted: Tue Nov 07, 2006 5:20 pm Post subject: Definition of Alternator B-lead? |
I just looked at the latest z13/8 and noticed something interesting about
the drawing.. The B-lead coming from the alternator to the starter
contactor is listed as 4g. I think that might be overkill for that
portion of the circuit, as something as small as 10g (8g to be
conservative) would do for a 60A alternator.
The output of the alternator is noisy. Using the fatest wire to connect
the alternator to the battery provides the best filtering. Making the
wire between the starter contactor and battery contactor perform double
duty allows using a much fatter wire for the alternator without any
penalty (for many architectures).
The RI noise will be worst on the starter end of the wire between the
starter contactor and the battery contactor. Ideally the system
architecture would allow making the connection between the battery and
battery contactor short as compared to the connection between the battery
contactor and the starter contactor. This will minimize the noise on the
remaining connections to the battery contactor. Keeping the wire between
the battery contactor and the battery short also makes the contactor
perform as it's intended - to de-energize the majority of the electrical
system.
I believe there have been system architectures that routed the b-lead
directly to an ammeter on the panel, and then to the battery, with a
totally seperate wire used to power the starter. Using a remote shunt in
line with the b-lead, as in the Z-drawing eliminates any need for such
nonsense.
If the engine is in the nose, and the battery is behind the cockpit,
obviously, the B-lead/starter_feed will go through the cockpit.. If you
have a choice, keep that wire further from the panel than you would other
wiring. Don't use the starter end of that wire to power anything else -
make all connections as close to the battery contactor as possible.
Sorry if that seems like an indirect answer to your query...
Matt-
the
line? What's the ideal, and if one must compromise, how should one
Thanks.
John
Posted: Wed Nov 08, 2006 5:43 am Post subject: Definition of Alternator B-lead? |
At 06:18 PM 11/7/2006 -0700, you wrote:
<snip>
| Quote: | If the engine is in the nose, and the battery is behind the cockpit,
but easily kept low on the firewall and under the floorboards . . .
| Quote: | If you
If the battery is in the rear, then the starter contactor
becomes the forward local power distribution point for
fat wires that connect to the alternator and main bus.
Keeping the b-lead out of the cockpit focused very narrowly
on the decades old practice of feeding generators/alternators
onto the bus with panel mounted breakers.
For fat wires in general, SEPARATION from compass for reducing
magnetic effects is a good thing to do . . . but in small airplanes,
it's probably impossible to get the fat wires so far from the
compass that noticeable effects are zero. This is why compass
swinging procedures call for making note of what electro-whizzies
are ON during the procedure. Magnetic coupling of noise to other
systems is easily handled by not bundling victim wires with
fat wires.
