dorsal fin
iworonko(at)cox.net
PostPosted: Fri Jan 27, 2006 3:19 am    Post subject: dorsal fin Reply with quote
Has anyone done the dorsal fin mod.?
Was it worth the effort? I am considering doing it before covering, just like to get some input first.
Eric
n10pg(at)neo.rr.com
PostPosted: Fri Jan 27, 2006 6:14 am    Post subject: dorsal fin Reply with quote
Hi Eric:
I did. I think the dorsal ridge enhances the overall appearance of the
kitfox. It also prevents water from just sitting there. There are some
pictures in the photo gallery of my web page.
Peter Graichen
http:/home.neo.rr..com/n10pg/kitfox.htm
rjdaugh(at)rapidnet.com
PostPosted: Fri Jan 27, 2006 1:18 pm    Post subject: dorsal fin Reply with quote
Eric,
I have pictures on SportFlight:
http://www.sportflight.com/cgi-bin/uploader.pl?action=view&epoch=1028485209
I think it improves the aesthetics as well as smooths the airflow at the
bulkhead at the from of the rear access. I got grief that I had added to
much weight to the plane. They are probably right, I could have done it
lighter, but the wood I used was very light redwood. I am please with the
result.
Randy Series 5/7 - 912S
dan(at)azshowersolutions.
PostPosted: Fri Jan 27, 2006 3:55 pm    Post subject: dorsal fin Reply with quote
Hi Eric,
I just had it done on my IV and I know of two other guys in the phoenix area that have it done and are flying. It sure adds a nice touch. I have photos on my buildsite under Mods if you would like to see it prior to getting covered. www.azshowersolutions.com/Kitfox1.html
Dan B
Mesa, AZ Kitfox-IV
Eric
MichaelGibbs(at)cox.net
PostPosted: Sat Jan 28, 2006 9:57 am    Post subject: dorsal fin Reply with quote
I'm not sure if this is what you are referring to as a "dorsal fin,"
but on my Model IV-1200 Murle Williams welded a piece of 4130 tubing
from just behind the turtledeck to the base of the vertical
stabilizer. I usually refer to it as a dorsal fin. Smile
We found that this made applying the fuselage fabric easier in the
area at the base of the vertical tail. The increase in surface area
also slightly increases yaw stability and, in my opinion, improves
the aesthetics.
We just got through welding a similar piece onto the fuselage of my Series 6.
Mike G.
N728KF
PostPosted: Sat Jan 28, 2006 12:59 pm    Post subject: dorsal fin Reply with quote
Hey Mike,
Did you get your 6 back from powder-coating yet?
Dan B.
Mesa
the aesthetics.
Mike G.
N728KF
iworonko(at)cox.net
PostPosted: Sun Jan 29, 2006 6:30 am    Post subject: dorsal fin Reply with quote
thanks to all who responded to my Dorsal fin question
Eric
IV Speedster
PostPosted: Sun Jan 29, 2006 10:03 am    Post subject: dorsal fin Reply with quote
Dan B. sez:
Yeah, Dan, just yesterday. They did a beautiful job! Smile
Mike G.
N728KF
