skylor4(at)yahoo.com Guest
Posted: Fri Nov 03, 2006 9:53 pm Post subject: Spark Plugs & Repairman |
List,
One thing that seems to be lost in the noise regarding
checking of spark plug gaps:
You don't even need a repairman certifcate to legally
clean or replace spark plugs and set the spark plug
gap.
This is clearly defined in Part 43, Appendix A,
supbart C, paragraph 20.
Any owner licensed pilot/owner may perform preventive
maintenance of Part 91 aircraft, which includes
"Replacing or cleaning spark plugs and setting of
spark plug gap clearance."
I bring this up, because much of the discussion
related to spark plug gapping seems to be centered
around "holders of repairman certificates". A
repairman certificate has absolutely nothing to do
with legally gapping spark plugs, though I assume most
believe that the holder of a repairman's certificate
should know how!
Skylor
dbris200(at)sbcglobal.net Guest
Posted: Sun Nov 05, 2006 10:28 am Post subject: Spark Plugs & Repairman |
The only privilege that the Repairman's Certificate gives you is signing off the condition inspection. How can you responsibly write in your logbook that: "this engine has been inspected in accordance with the scope and detail of appendix D to part 43 and found to be in a condition for safe operation", if you haven't checked the plugs?
Dave Bristol
EAA Technical Counselor
Skylor Piper wrote: [quote] | Quote: | --> RV-List message posted by: Skylor Piper <skylor4(at)yahoo.com> (skylor4(at)yahoo.com)
List,
gap.
should know how!
Skylor
| [b]
Posted: Sun Nov 05, 2006 10:46 am Post subject: Spark Plugs & Repairman |
I don't want to put words in his mouth, but I suspect that his point
goes in the other direction (I'd go further): you don't need *any*
authorization of any sort to change plugs (or anything else on a
homebuilt), so the discussion of the Repairman's Cert. is all moot.
I'm not talking about what makes sense; just what's *required*.
Never, ever, encourage more regulation & further restrictions on your
freedom.
Charlie
no titles, but legal repairs/changes to 4 different homebuilts, so far
(none that I have held Repair. Certs on)
Dave Bristol wrote:
| Quote: | The only privilege that the Repairman's Certificate gives you is
Dave Bristol
Skylor Piper wrote:
>List,
>gap.
>should know how!
>Skylor
Posted: Mon Nov 06, 2006 1:54 pm Post subject: Spark Plugs & Repairman |
Charlie, I think that we're actually on the same side here, but maybe I wasn't clear in what I was trying to say.
My point was that you DO need an authorization to sign off the condition inspection and you DO need to know that the plugs are gapped correctly to do so. My quote "this engine has been inspected in accordance with the...." is from my oplims and is therefore "required". The Repairman's Certificate is not about "repairing" it's about signing.
I would "Never, ever, encourage more regulation & further restrictions on your freedom. "
Dave
Charlie England wrote: [quote]--> RV-List message posted by: Charlie England <ceengland(at)bellsouth.net> (ceengland(at)bellsouth.net)
I don't want to put words in his mouth, but I suspect that his point goes in the other direction (I'd go further): you don't need *any* authorization of any sort to change plugs (or anything else on a homebuilt), so the discussion of the Repairman's Cert. is all moot.
Charlie
no titles, but legal repairs/changes to 4 different homebuilts, so far (none that I have held Repair. Certs on)
Dave Bristol wrote:
| Quote: | The only privilege that the Repairman's Certificate gives you is signing off the condition inspection. How can you responsibly write in your logbook that: "this engine has been inspected in accordance with the scope and detail of appendix D to part 43 and found to be in a condition for safe operation", if you haven't checked the plugs?
Dave Bristol
List,
gap.
should know how!
Skylor
