		wvu(at)ameritel.net Guest
				 Posted: Sun Nov 05, 2006 7:01 pm    Post subject: Fuel Selector Valve Operation |
				I have a stock selector valve.  Fuel lines were installed by the book,  expecting that the lever would operate pointing upward.  i.e. up and left  for left tank, up and right for right tank.  I expected that it would  also work with it pointing down and left or right.  Well,  I only  get good fuel flow with it pointing down/left and down/right.  I thought  the design was simply two tunnels in the valve shaft in a "+" shape so that it  would work in any of the four positions.  Any idea why it didn't work  pointing upward?
  Anh
  #141
		zackrv8
				 Posted: Sun Nov 05, 2006 7:27 pm    Post subject: Re: Fuel Selector Valve Operation |
				Deja,
   I think the "pointer" end of the fuel slector valve that comes with Van's kits is supposed to filed down (not totally sure though).  The longer "handle" end becomes your handle AND pointer.  Of course, I have an Andair valve and am not totally sure if this is correct.
 Zack
 quote="wvu(at)ameritel.net"]I have a stock selector valve.  Fuel lines were installed by the book,  expecting that the lever would operate pointing upward.  i.e. up and left  for left tank, up and right for right tank.  I expected that it would  also work with it pointing down and left or right.  Well,  I only  get good fuel flow with it pointing down/left and down/right.  I thought  the design was simply two tunnels in the valve shaft in a "+" shape so that it  would work in any of the four positions.  Any idea why it didn't work  pointing upward?
  Anh
  #141
  _________________ RV8 #80125
RV10 # 40512 |
		jesse(at)itecusa.org Guest
				 Posted: Mon Nov 06, 2006 6:28 am    Post subject: Fuel Selector Valve Operation |
				This is correct on the Van's valve.  You need to file down the point and use
 the arm as the pointer.  You have Left Right Off Off, starting from forward
 left and working clockwise.
 Do not archive.
 Jesse Saint
 I-TEC, Inc.
 www.itecusa.org
 W: 352-465-4545
 C: 352-427-0285
