Before closing up the top of the TailconeBefore closing up
rene(at)felker.com
PostPosted: Sat Nov 11, 2006 2:03 pm    Post subject: Before closing up the top of the TailconeBefore closing up Reply with quote
I wish I had pictures but……..I did mine a little different. It is further back, the flat part of the angles (vertical) are the opposite and I put the angles on top of the longeron. I also put nutplates on the angles so that the shelf is removable using a screw driver from underneath.
I will try to take some pictures this weekend. My plan is to wait until I ready to mount the items on the shelf, determine the layout and then to cut out portions of the shelf that are not needed. That will make the shelf lighter…
Rene'
801-721-6080
