frank.hinde(at)hp.com Guest
Posted: Fri Jan 27, 2006 9:06 am Post subject: Wheelpants and leg fairings RV 7a |
Morning all,
Fitting up my wheelpants and noticed from the drawing that you have to
lift the plane off its gear so the tires are off the ground. I have one
trolley jack and its not immediately apparent how I would do this?
I notice what sounds like a fairly involved procedure to align the leg
fairings...probably cus I didn't understand it on the first read
through...Can anyone expain a simple procedure?
I am thinking of using #6 screws and C/s washers rather than rivets to
mount the pants..Any reason why not?
Looks like a fair bit of work but I'd like to get everything done before
I take the plane to the hangar.
Frank
RV7a..Final engine connections, bodywork, paint..Sell other
airplane...and fly..
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
deruiteraircraftservices( Guest
Posted: Fri Jan 27, 2006 9:25 am Post subject: Wheelpants and leg fairings RV 7a |
Hi frank,
the idea is to lift the airplane clean of the ground supported by trestles
or similar. Align the main fairings to the centrelign of the aircraft. You
can measure from centreline outboard on both sides and mark your H-stab. Use
a piece of string over the centre of the pant and align with your mark on
the h-stab. Now set the horizontal alignment. Pilot drill with 3/32 and use
a cleco this way you have some leeway of adjustment. The holes in the pants
can be filled with a little epoxy adhesive should you get it wrong. (but we
never make any mistakes).
hope this helps.
