Posted: Sun Nov 05, 2006 9:42 pm Post subject: LED extension |
I am installing an electronic circuit (Flap Positionong System) which has a
3 colour LED on it. I am puting this box inside the flap enclosure of my RV,
thus hiden in a place out of sight.
Since I need, for some operations, to see the LED, I am thinking in puting
another 3 colour LED somewhere in the panel. How should I connect the pannel
LED to the circuit LED? Is it just a 3 wire connection? And both LED's would
show the same?
TIA
Carlos
armywrights(at)adelphia.n Guest
Posted: Mon Nov 06, 2006 6:06 pm Post subject: LED extension |
Run fiber optic cable; no extra wiring to do.
Rob Wright
Posted: Tue Nov 07, 2006 11:47 am Post subject: LED extension |
Bob and listers
I am installing an electronic circuit (Flap Positioning System) which has a
RV,
pannel
would
show the same?
TIA
Carlos
nuckollsr(at)cox.net Guest
Posted: Wed Nov 08, 2006 5:44 am Post subject: LED extension |
At 07:43 PM 11/7/2006 +0000, you wrote:
<trigo(at)mail.telepac.pt>
Bob and listers
show the same?
TIA
Carlos
Difficult to advise without having a schematic of your
hardware. Do the installation instructions for this
system offer any options for remote indication at all?
What do these lights indicate?
< with experiment. >
< --Lawrence M. Krauss >
Posted: Wed Nov 08, 2006 8:45 am Post subject: LED extension |
<nuckollsr(at)cox.net>
>Bob and listers
>a
>RV,
>pannel
>would
>show the same?
>TIA
>Carlos
The installation instructions don't provide any option for remote
indication.
This LED indicates the mode of operation (number of blinks in Red color
showing mode 1 to 6), programming mode (blinking yellow) and memory erased
(blinking green).
The 3 color LED is soldered to the circuit by its 3 "legs".
What I'm asking is if I can connect a similar LED installed in my panel with
a 3 wire cable to the 3 circuit LED contacts.
Carlos
Posted: Wed Nov 08, 2006 2:46 pm Post subject: LED extension |
| Quote: | >
> Bob . . .
The installation instructions don't provide any option for remote indication.
(blinking green).
with a 3 wire cable to the 3 circuit LED contacts.
Sounds good to me. You won't be able to wire in parallel
with the existing LED . . . take it out and drop your three
wires into the same holes where the LED used to reside.
