peter(at)mather.com Guest
Posted: Sun Nov 05, 2006 11:08 am Post subject: Transorb voltage for 14V system |
What is the optimum voltage of transorb for a 14V system. 15V seems a bit
marginal. 18 seems OK?
Thanks in anticipation
Peter
klehman(at)albedo.net Guest
Posted: Sun Nov 05, 2006 7:03 pm Post subject: Transorb voltage for 14V system |
Peter
18 volt seems to be the ones to use... I used a few of them in a couple
of places.
Ken
Peter Mather wrote:
<peter(at)mather.com>
bit marginal. 18 seems OK?
Peter
nuckollsr(at)cox.net Guest
Posted: Mon Nov 06, 2006 7:11 am Post subject: Transorb voltage for 14V system |
At 06:35 PM 11/5/2006 +0000, you wrote:
Peter
I am curious as to why you think you need one.
The topic of spikes and other evils on the bus
has been discussed here on the list since day-one,
but to date, nobody has offered data from a repeatable
experiment that illuminates sources, intensities and
energy content of any perturbations of interest on
an airplane or any other vehicular DC power system.
Thus far, proponents of prophylactic measures such as
Transorbs, MOVs, etc. have only cited the sales
literature for such products that strongly suggest
that you buy a lot of their product and sprinkle
liberally about your system . . . at least having done
so might make you feel good. See:
http://www.aeroelectric.com/Mfgr_Data/Semiconductors/AN9312.pdf
Keep in mind too that a Transorb rated at 18v goes into
a hard limit at over 25 volts when it's "working hard"
at it's intended task. See:
http://www.aeroelectric.com/Mfgr_Data/Semiconductors/15ke.pdf
Just be aware that to date, nobody has come forward
with an engineering justification for sprinkling Transorbs
around any part of the airplane's electrical system and
then explained the simple-ideas that support their
proposition. Those who have championed the Transorb
most vigorously have overlooked and/or ignored the wide
range of clamping voltage when the device is stressed
over the full range of its ratings. An 18v Transorb
does NOT guarantee that the device being "protected"
will not suffer a spiking event that exceeds 18v by
a considerable margin.
Don't mis-interpret my suggestions here. Transorbs
are marvelous devices and I've designed dozens of
circuits that utilize these nifty gizmos to stand off
the effects of lightning strokes! But the notion that
they're useful for much of what folks tend to worry about
in little airplanes is not supported in physics or practice.
< with experiment. >
< --Lawrence M. Krauss >
Posted: Mon Nov 06, 2006 8:19 am Post subject: Transorb voltage for 14V system |
Bob
I'm building a RV9A and using a variant of Z-11 as the electrical system.
Basically the endurance bus is provided by a composite design mini-power
panel http://www.compositedesigninc.com/Mini_Power.htm except that this has
all the electrics connected to it except the alternator field, Critically,
the non-switchable load is only a measured 0.8amp for a Dynon D10A and
engine instruments.
I'm using a IR 125NQ015 diode mounted directly onto the power panel positive
bus (this is a great device with 1/4" screw terminal for the incoming feed
and its case as the output. This has a VF of only 0.33V so at my full load
is only dissipating about 8 Watts.
I'm intending to use a 5000W axial transorb across the terminals of the
power panel to provide both a level of spike protection but also overvoltage
protection. I've conducted experiments with a 9V version of the transorb and
demonstrated that I can blow either my endurance bus fuse or my alternator
current limiter without damage to the transorb. In other words an
overvoltage on the alternator should blow its own fuse and if any transients
exist they would also be mopped up. The transorb voltage is obviously
critical in this. I don't want it conducting in any normal situation, but do
want it to let go as soon as any significant overvoltage condition exists.
Without wishing to start any further spike protection or alternator
overvoltage wars, I'm very interested in your views on this approach.
Best regards
Peter
Posted: Mon Nov 06, 2006 8:32 pm Post subject: Transorb voltage for 14V system |
At 04:16 PM 11/6/2006 +0000, you wrote:
Bob
has all the electrics connected to it except the alternator field,
Critically, the non-switchable load is only a measured 0.8amp for a Dynon
D10A and engine instruments.
positive bus (this is a great device with 1/4" screw terminal for the
incoming feed and its case as the output. This has a VF of only 0.33V so
at my full load is only dissipating about 8 Watts.
power panel to provide both a level of spike protection . . .
From what spikes?
| Quote: | . . . but also overvoltage protection. I've conducted experiments with
a 9V version of the transorb and demonstrated that I can blow either my
endurance bus fuse or my alternator current limiter without damage to the
transorb. In other words an overvoltage on the alternator should blow its
own fuse and if any transients exist they would also be mopped up. The
transorb voltage is obviously critical in this. I don't want it
conducting in any normal situation, but do want it to let go as soon as
What kind of alternator? And did you measure the voltage
across the transorb just prior to fuse opening and bringing
an ov event to heel?
Posted: Tue Nov 07, 2006 5:44 am Post subject: Transorb voltage for 14V system |
Bob
I didn't measure the voltage the transorb opened but it was clearly enough
open at 12.5 volts which was the battery voltage to blow a 25amp fuse.
I'm using a prestolite externally regulated 60amp alternator with a
Zeftronics regulator.
I don't know if there are any transients that a transorb might solve but I'm
only intending to put one across the power panel and at $10 it seems like
cheap insurance with no obvious downside
Best regards
Peter
Posted: Wed Nov 08, 2006 5:55 am Post subject: Transorb voltage for 14V system |
At 01:42 PM 11/7/2006 +0000, you wrote:
Bob
I'm lost. Was this experiment conducted just to see if
you could open the 25A fuse with a conducting Transorb?
It's not that the experiment didn't yield meaningful data,
I'm not clear where you're proposing to connect a Transorb
of any voltage and what you expect it to do for you.
| Quote: | I'm using a prestolite externally regulated 60amp alternator with a
Okay, from an architecture perspective, this looks like
Z-11. Where would you install the Transorb in Z-11?
| Quote: | I don't know if there are any transients that a transorb might solve but
I'm only intending to put one across the power panel and at $10 it seems
like cheap insurance with no obvious downside
One can probably buy really cheap insurance against
pink elephant stampedes and meteor strikes too. Of course
it's your airplane and you can do anything you like. But for
the benefit of 1300+ folks who watch this List go by, let
us be clear on features that meet quantifiable and demonstrable
design goals . . . and those that are cheap and simply feel good.
When you ask the question about sizing a Transorb for use
in your system, the question is unanswerable without knowing
exactly what you expect the device to accomplish and whether
or not it's capable of meeting your expectations.
