M4 Speedster Rudder post Fairing
shericom(at)rogers.com
PostPosted: Fri Jan 27, 2006 1:14 pm    Post subject: M4 Speedster Rudder post Fairing Reply with quote
Hi everyone, I have a question about the fiberglass
fairing on the rudder post of my M4 speedster.(under
construction) The construction manual says to cut
large enough holes in the fairing to get the attaching
bolts through the rudder tabs and tail post rod ends.
OK, I assume when the fabric is applied the holes need
to be cut out to provide access as stated above, My
question is, are these holes covered up in some way
after final assembly as they are quite large and will
certainly be visible? I hope the makes sense to
someone but not to me! Looking forward to some help on
this one, Thanks, Don.
Don Stevenson, Caledon, Ontario, Canada
M4/1200-912 Speedster
roncarolnikko(at)hotmail.
PostPosted: Fri Jan 27, 2006 3:18 pm    Post subject: M4 Speedster Rudder post Fairing Reply with quote
Don mine are quite large and will be visable when the rudder is turned. Ron
NB Or
To: Kitfox List <kitfox-list(at)matronics.com>
Subject: M4 Speedster Rudder post Fairing Date: Fri, 27 Jan
2006 16:10:32 -0500 (EST)
cliffh(at)outdrs.net
PostPosted: Fri Jan 27, 2006 7:32 pm    Post subject: M4 Speedster Rudder post Fairing Reply with quote
My Kitfox is painted lemon yellow. I covered these holes on the rudder with
yellow duct tape.
Floran H.
szakreski(at)shaw.ca
PostPosted: Fri Jan 27, 2006 8:29 pm    Post subject: M4 Speedster Rudder post Fairing Reply with quote
No the holes are not covered, and yep... are definitely visible. But to me
they add a high tech look to the rudder. I'm fairly picky, but they don't
bother me.
SteveZ
Calgary (brother lives in Mono Mills!)
Classic IV/NSIEA81/CAP
PostPosted: Sat Jan 28, 2006 5:03 am    Post subject: M4 Speedster Rudder post Fairing Reply with quote
Hi Steve, Sounds to me as if the holes in your rudder
post are much neater then mine, these were cut by the
original Pearson who started the build and did not or
could not do anything with any amount of finesse, I
have spent the last year re-doing a lot of his work
and will soon be ready to cover. My construction
manual has no detail on the holes, so I flying blind
so to speak. If you have anything you could send me
that would show how they should be done that would be
great!
Thanks for your help as well as others who replied.
Best regards, Don
bother me.
SteveZ
rkstevens(at)verizon.net
PostPosted: Sat Jan 28, 2006 5:52 am    Post subject: M4 Speedster Rudder post Fairing Reply with quote
One neat thing that I saw somebody do to cover the unsightly rudder post
access holes is to fabricate some aluminum covers. Here's how it's done:
- Cut the access holes in the rudder post fairing as normal. I actually cut
them a little oversize so it's easier to get to the bolt & nut on the
inside.
- Then fabricate a small aluminum cover that goes over the outside of the
access hole. You'll need to cut a slot in the aluminum cover plate for the
rudder hinges. But the rudder hinge holes can be very small & neat as
compared to the rudder access holes in the fiberglass fairing. Use very
thin gauge aluminum that can be easily bent to the shape of the rudder
fairing.
- I used nutplates to attach the aluminum plates to the rudder post.
After the aluminum plates are painted, the access holes virtually disappear.
Makes for a very neat installation.
Ron
Series 6
dan(at)azshowersolutions.
PostPosted: Sat Jan 28, 2006 6:13 am    Post subject: M4 Speedster Rudder post Fairing Reply with quote
Does anyone have a picture of this?
Dan
www.azshowersolutions.com/Kitfox1.html
inside.
fairing.
Ron
Series 6
lcfitt(at)sbcglobal.net
PostPosted: Sat Jan 28, 2006 9:04 am    Post subject: M4 Speedster Rudder post Fairing Reply with quote
One thing I learned from the Lancair build - they use a lot of instant
glue - temporary positioning of parts for drilling etc. The bolt insertion
issue is a problem there as well, as the airplanes are quite fast and having
everything faired is a major issue. The glue comes in handy as you can glue
the bolt head to a strip of aluminum that is bent to allow for bolt
insertion in a tight space and after the bolt is in place snap the strip
off. The only consideration then becomes the clearance for the wrench.
And some will use a fine ratchet to minimize the need for a long throw.
One other trick they use in this area is to take several short lengths of
metal rod the same diameter as the bolt and taper one end. Then make a
tight 90 degree bend near the tapered end and use that in the hinge to
position everything first then one at a time remove that and insert the
bolt.
When I built, I bet I spent hours putting that part together.
Lowell
