		John Bolding
				 Posted: Sun Nov 12, 2006 5:09 am    Post subject: STOL 701 Wheel measurements |
				[quote]    Guys,
    I'm considering a couple of scratch built    options for the 701 main gear.
    I need a couple of items to pass on to the    engineer that is doing the analysis and hopefully someone can help.
    The Matco Wheel used for the Tundra Tire option    is MHMH6BD.75XT,  I need the weight of the wheel,tire, axel and brake    assy. Also need the width of the wheel between the rims.  Outside dia of    inflated tire would be useful useful as well. OR if someone has a pair that    they need to unload I'll buy them.
  This is a preliminary design exercise    to see if a homebuilt carbon gear can be made using pultruded rods into a    simple mold. Goals are weight reduction (several POUNDS is anticipated)and    reduced cost over the purchased original alum gear. THANKS I'll post the    results of the study to the group.  LOW&SLOW   John    Bolding
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		jon(at)joncroke.com Guest
				 Posted: Sun Nov 12, 2006 8:48 am    Post subject: STOL 701 Wheel measurements |
				Hi John,
  Took a look at my wheels, not yet  mounted:
  About 13 lbs each for the complete assembly with  brakes...
  18" diameter tires inflated,
  Had trouble measuring the width of the rims...  close to 4.5"
  I am looking for a 701 Rotax engine mount... ifyou  are going to scratch build one then build TWO and I'll buy one!
  (Dont think you're going Rotax, tho!)
  I have a Zenith Rotax 601 mount  available for trade or sale..! (used, one owner)
  35 degrees this morning... ouch!
  Jon
  [quote]   ---
