Flap Torque Tube
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Tailwind-List
Rcaprd(at)aol.com
PostPosted: Sun Nov 12, 2006 10:38 am    Post subject: Flap Torque Tube Reply with quote
In the AS&S plans for the W10, it shows the torque tube that the 3 arms are welded to is 1" .035 wall tube. On the ends, it shows 7/8 X .035 sticking out 7/8". There is a lot of slop between these two tubes, probably causing a rattle is this is the wear point. Does that loose fitting 7/8" tube go all the way through the 1" torque tube ?   Then, on the side view, it shows two bushings made from 1" X .058 that are 7/8" long. This, of course, makes a nice fit with the 7/8" tubes. It's just not clear where the wear points are.
Chuck G.
Wichita, KS
p.s. I just uploaded some more pictures of my progress to my web site:
http://nx770cg.com/NextProjectTailwind.html
- The Matronics Tailwind-List Email Forum -
http://www.matronics.com/Navigator?Tailwind-List
jclement000(at)centurytel
PostPosted: Sun Nov 12, 2006 1:27 pm    Post subject: Flap Torque Tube Reply with quote
The 7/8" tubes get welded into the 1" tube. The 1" x .058 are welded to the
airframe, these are the wear points. Drill 1/8" holes in the top of the 1"
bushings for oiling. One way to center up the 7/8" in the 1" is to wrap
aluminum tape around the 7/8" tube on the inserted portion for a snug fit.
Jim
Rcaprd(at)aol.com
PostPosted: Sun Nov 12, 2006 2:24 pm    Post subject: Flap Torque Tube Reply with quote
In a message dated 11/12/2006 3:28:09 PM Central Standard Time, jclement000(at)centurytel.net writes:
Jim
How much of the 7/8" tubes should be inserted into the 1" tube...about 2" or 3" ?
Are they welded all the way around ?
You already answered how to center it up, and lube the wear point !!
Thanks, Jim
Chuck G.
PostPosted: Sun Nov 12, 2006 2:34 pm    Post subject: Flap Torque Tube Reply with quote
Insert it about 3" or so the tape is about 1/2" in from the welded area.
Weld all the way around.
Rcaprd(at)aol.com
PostPosted: Sun Nov 12, 2006 7:18 pm    Post subject: Flap Torque Tube Reply with quote
In a message dated 11/12/2006 4:35:43 PM Central Standard Time, jclement000(at)centurytel.net writes:
Will do. Thanks Jim !!
Chuck G.
gorgonc3(at)hotmail.com
PostPosted: Sun Nov 12, 2006 8:44 pm    Post subject: Flap Torque Tube Reply with quote
How about a photo of the topic?
Mark
"When landing a taildragger, all that matters is you touchdown straight - no
drift/crab. You want to make sure your wreckage goes straight down the
runway..."
Reply-To: tailwind-list(at)matronics.com
Subject: Re: Flap Torque Tube
Date: Sun, 12 Nov 2006 22:18:20 EST
Chuck G.
Get today's hot entertainment gossip
http://movies.msn.com/movies/hotgossip?icid=T002MSN03A07001
Rcaprd(at)aol.com
PostPosted: Sun Nov 12, 2006 10:32 pm    Post subject: Flap Torque Tube Reply with quote
In a message dated 11/12/2006 10:44:56 PM Central Standard Time, gorgonc3(at)hotmail.com writes:
I haven't got one, but if you look at the plans, you'll see what we're typing about.
Chuck G.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Tailwind-List All times are GMT - 8 Hours
