kirkhull(at)kc.rr.com Guest
Posted: Mon Nov 13, 2006 6:22 pm Post subject: transponder |
After a few problems I finally got an X ponder installed in 205AK but in the process ended up with another serviceable unit. The long story short, I ordered a Narco AT50 A and got it but it was over 30 days before it was installed and found to be broken at which point I ordered another one from the avionics shop to get the plane flying. Later I found out that Dodson would not return the money just send out another unit. I will have just under $400.00 in it including a bench check from the avionics shop. It will be a good slide in replacement for someone who has a broken Narco or has a tray. If anyone is interested please let me know.
