		rv6(at)earthlink.net Guest
				 Posted: Sun Nov 19, 2006 7:33 am    Post subject: Woodward Prop govenor.. |
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Sun Nov 19, 2006 7:35 am    Post subject: Woodward Prop govenor.. |
		Dale Ensing
				 Posted: Sun Nov 19, 2006 11:38 am    Post subject: Woodward Prop govenor.. |
				John,
  Is it leaking at the spacer plate? Do you have the  spacer plate in place?
  Dale Ensing
  do not achieve
    Woodward    oil leak Help..
    Has any    one that has Vans Woodward governor,had oil leaks
    around the    1/4 mounting studs to the unit..Even after replacing
    with new    gasket,there is oil coming out at the studs at 2000 rpm
    or more!!I    know that there is a lot of pressure this unit puts out,
    but I    really do not want to send it out to be checked if anyone    has
    had this    same problem..It has only about 130 hrs on it..
                           Anyone have any ideas???
                                 John McMahon (RV6 C/S 180)
 href="http://www.aeroelectric.com">www.aeroelectric.com
 href="http://www.buildersbooks.com">www.buildersbooks.com
 href="http://www.kitlog.com">www.kitlog.com
 href="http://www.homebuilthelp.com">www.homebuilthelp.com
 href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
  | 	  [b]
  _________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
				 Posted: Sun Nov 19, 2006 2:14 pm    Post subject: Woodward Prop govenor.. |
				Dale
  Well it is  leaking at the 10 o'clock stud and moving back and pooling
  in a small  depression just past the nut..The spacer plate did leak a
  little,but  removed and installed with new gasket..I have been chasing
  this leak  since I installed the new eng and governor,and got mad and said this is going to  stop!!It will only show up at the 2000 and operate the CS some and out it  comes...I sure hate to have to send it off for $320.00 to check it out..I am  going to try to call Woodward tomorrow..
                                                         John
  [quote]   ---
		Kellym
				 Posted: Sun Nov 19, 2006 3:04 pm    Post subject: Woodward Prop govenor.. |
				IIRC there is supposed to be a gasket on BOTH sides of the spacer.
 John Mcmahon wrote:
 [quote] *Dale*
  *Well it is leaking at the 10 o'clock stud and moving back and pooling*
  *in a small depression just past the nut..The spacer plate did leak a*
  *little,but removed and installed with new gasket..I have been chasing*
  *this leak since I installed the new eng and governor,and got mad and
  tomorrow..*
  *                                               Thanks*
  *                                                      John*
KCHD |
		Larry Bowen
				 Posted: Sun Nov 19, 2006 6:29 pm    Post subject: Woodward Prop govenor.. |
				I have a rebuilt Woodward gov that works fine.  Leaked  at one time, but a new gasket fixed it.
  You've witnessed it squirt out at that location?  It  can't be coming from something up higher on the accessory case and leaking  down?  Just a thought....sometimes it's hard to  tell......
 Larry Bowen
 Larry(at)BowenAero.com
 http://BowenAero.com
  [quote]         From: Dale Ensing    [mailto:densing(at)carolina.rr.com]
 Sent: Sunday, November 19, 2006    2:37 PM
 To: rv-list(at)matronics.com
 Subject: Fw:    Woodward Prop govenor..
    John,
    Dale Ensing
    do not achieve
  | 	  [b]
  _________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
