Drilled the wrong hole in my hs help
HCRV6(at)comcast.net
PostPosted: Sat Jan 28, 2006 12:15 pm    Post subject: Drilled the wrong hole in my hs help Reply with quote
If I under stand your problem correctly, you can use "oops" rivets (AD4 size shank and AD3 size head). Lots of sources, including Avery and I think Van's has them in the catalog now.
Harry Crosby
RV-6 N16CX, 170 hours
-------------- Original message ----------------------
Somehow when I read "Drill all rib attach holes to #30" I drilled the holes
on top of the flange of HS-702 (that connect HS-708) too. My skin
(HS-601PP) is drilled to #40. The plan says use a "AN26AD3-4 to HS-601PP to
HS-702 to HS708" This can't be right! Any suggestions on how I can fix
this dilemma?
Thanks in advance.
David Karlsberg
rvhi03(at)msn.com
PostPosted: Sat Jan 28, 2006 12:58 pm    Post subject: Drilled the wrong hole in my hs help Reply with quote
ceengland(at)bellsouth.ne
PostPosted: Sat Jan 28, 2006 5:53 pm    Post subject: Drilled the wrong hole in my hs help Reply with quote
this dilemma?
Thanks in advance.
David Karlsberg
Aren't the HS-702 flanges dimpled? (I hate the numbers on the
instructions with no name; I've got really short memory with part #'s.)
Assuming adequate edge distance & dimples on everything, the simplest
thing to do is drill the skin #30, dimple, & use an426ad4-4 rivets. Buck
carefully on the thin skin, but it should work fine; some of the older
designs use ad4's for skins.
mark(at)macomb.com
PostPosted: Sun Jan 29, 2006 6:09 am    Post subject: Drilled the wrong hole in my hs help Reply with quote
David,
Just rivet it up with 4-4s. Work carefully and you will be fine. I have
a second hand RV-7 empanage kit and the whole Vertical stab was drilled
with #30. I took my time and only had to drill out a couple.
MG
this dilemma?
Thanks in advance.
David Karlsberg
dennis(at)drrv7.com
PostPosted: Sun Jan 29, 2006 6:30 am    Post subject: Drilled the wrong hole in my hs help Reply with quote
A new builder myself, I have found it very useful to read through the steps several times before committing a drill to anything. Analyzing the drawings over and over as well. As a rule of thumb, skin attachments are USUALLY drilled to #40 (unless otherwise specified). If you are not 100% sure about something, re-read the step while looking closely at the plans over and over until you convince yourself that you ARE 100% sure what you are about to do is correct. If you still are not sure, ask for help BEFORE drilling. It will save you time and $ later on down the line.
Dennis Roberts RV7 N35DR (reserved) Emp nearly complete / awaiting wing shipment
Dennis(at)DRRV7.com
http://www.DRRV7.com
