occom
				 Posted: Sun Nov 19, 2006 10:11 am    Post subject: Alodine, what I found |
				After my last question about the Alodine solution I  bought I took it back and got it replaced. The store personnel did not think  anything could be wrong with it until  the new bottle was a much different  colour. In any case it works as advertised and simply applying it to a cleaned  surface will result in an instant change of hue to a distinct yellow/gold. I  applied it to a sample and the tried to remove it, after a several second heavy  scrub with scotchbrite it was still easy to see the line between treated and  untreated so it might not come off as easily as some claimed.
  The maker claims a much improved corrosion  resistance and it may have been enough but since I need some of the polyfiber  epoxy primer anyway and the smallest kit will yield around two quarts I'll use  that inside the new spars as well as the small areas that need touch-up on the  airframe.
  Thanks to all who sent opinion.
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
