Michel
Posted: Sat Nov 18, 2006 9:25 am Post subject: Jabiru Service Bulletin |
For the sake of those who have a Kitfox with a Jabiru engine, but are
not on the Jabiru list, here is the link to the inspection and
re-torque of the flywheel bolts I did today.
http://home.online.no/~michel/Flywheel/
Cheers,
Michel
jimlc(at)att.net Guest
Posted: Sat Nov 18, 2006 9:47 pm Post subject: Jabiru Service Bulletin |
At 10:24 AM 11/18/2006, you wrote:
are not on the Jabiru list, here is the link to the inspection and
Cheers,
Michel
Michel,
The last time I wrote you I am sure I misspelled your name. Sorry.
What is the blue tool you show in your picture apparently identified
as torch? If it is a torch, it is unlike any I have ever used. No
Jabiru engine as yet but curious.
Jim Crowder
Michel
Posted: Sun Nov 19, 2006 12:46 am Post subject: Jabiru Service Bulletin |
On Nov 19, 2006, at 6:46 AM, Jim Crowder wrote:
| Quote: | The last time I wrote you I am sure I misspelled your name. Sorry.
Don't worry, Jim, having lived in three different countries, ... I am
used to be called all sorts of names!
| Quote: | What is the blue tool you show in your picture apparently identified
as torch?
The word "torch" is what I think may translate what it is, in English,
but I may be wrong. This is the kind of tool you find e.g. in the
kitchen, to make a crème brulée. You may also use it to solder. It uses
lighter gas but while a lighter only burns the gas directly, this
device allows for a flow of air to come on the side and therefore works
more like a torch, giving a warmer blue and pencil-sharp flame.
Cheers,
Michel
pwmac(at)sisna.com Guest
Posted: Sun Nov 19, 2006 5:56 am Post subject: Jabiru Service Bulletin |
Jim,
Its a butane fueled soldering torch. Find at
Radio Shack or Harbor Freight but best of all go
to Home Depot or Lowes for a nice kit with all
kinds of ends and a refill canister. Very handy
for soldering big wires and soldering in remote places.
Regards, Paul
At 12:45 AM 11/19/2006, you wrote:
different countries, ... I am used to be called all sorts of names!
>apparently identified as torch?
what it is, in English, but I may be wrong. This
use it to solder. It uses lighter gas but while
side and therefore works more like a torch,
Cheers,
Michel
Posted: Sun Nov 19, 2006 9:15 pm Post subject: Jabiru Service Bulletin |
Michel,
I have saved your illustrations as I feel I will no doubt be pleased
to have them in the future.
Thanks, Jim Crowder
Cheers,
Michel
Michel
Posted: Mon Nov 20, 2006 3:17 am Post subject: Jabiru Service Bulletin |
| Quote: | From: Jim Crowder [jimlc(at)att.net]
Jim, if I understand correctly, you will receive a new Jabiru 3300. In that case, your engine has the flywheel mounted with dowel pins and you can ignore this service bulletin.
Cheers,
Michel
Fox5flyer Guest
Posted: Mon Nov 20, 2006 5:13 am Post subject: Jabiru Service Bulletin |
I agree with Jim. Excellent photo sequence. Thanks Michel.
Deke
Michel,
Thanks, Jim Crowder
>Cheers,
>Michel
