fish(at)aviation-tech.com Guest
Posted: Wed Jan 04, 2006 1:41 am Post subject: Air bottles |
Yak List,
Over the weekend I was watching the Myth Busters, and they did a show on the
movie JAWS. One of the things they did was to shoot a hole in a Scuba bottle,
and the results were very interesting. The bottle did not blow up, but did have
to expend a serious amout of pressure(bounce all over a 40' sea container).
They stated the equivilant in explosives, but I do not remember.
Be carfull
John Fischer
Yak-52, N213YA
gus.fraser(at)gs.com Guest
rvfltd(at)televar.com Guest
Posted: Wed Jan 04, 2006 6:40 am Post subject: Air bottles |
Walt,
Page 107 of the Maint and Tech Specifications for the CJ6 states that the
tank is 8 liters. But now that you mention 12 liters I went to the PT-6
Trainer Aircraft Overhaul Manual for Airframe Accessories and find that it
calls out 12 liters. Who is buying the beer? I'm getting a sinking feeling
that it's me.
But Walt is correct on one point for sure, proceed VERY carefully, you are
dealing with a bomb.
Always Yakin,
Doug Sapp
brian-yak(at)lloyd.com Guest
Posted: Wed Jan 04, 2006 7:59 am Post subject: Air bottles |
doug sapp wrote:
Quote: | What exactly is Boyles law?
P1*V1 = P2*V2
P = pressure
V = volume
For example: if you start with a 1 litre bottle with 100 kg/cm2 and then
let that expand into a 10 litre bottle, the final pressure will be 10
Kg/cm2. This assumes that the temperature and total amount of gas
remains constant.
It is a specific application of the more general formula for the ideal
gas law of:
PV = nRT
where:
P = pressure
V = volume
n = number of moles of a gas (based on Avogadro's constant -- actually
the number of molecules of the gas present in the container)
R = the universal gas law constant (0.0821 liter-atm / mol-K)
T = absolute temperature in degrees Kelvin (0C = 273K)
This latter formula will allow you to do calculations where the
temperature changes or the amount of gas present changes. If you want to
know what temperature will do to the pressure of the gas, you can
calculate it with this formula.
Brian Lloyd 2243 Cattle Dr.
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
wlannon(at)cablerocket.co Guest
Posted: Wed Jan 04, 2006 9:24 am Post subject: Air bottles |
Hey Doug;
We must have different Tech. Specs. manuals. Pg 107 does not mention air
tanks. That is on pg. 109 and shows 12 liters.
Cheers;
Walt
L39parts(at)hotmail.com Guest
Posted: Sun Jan 08, 2006 8:05 am Post subject: Air bottles |
In the US, firemen's SCBA bottle fittings vary with the manufacturer. SCUBA
diving bottles use a standard fitting, but there are a lot of airports in
the US that are a long ways from the ocean and quite possibly a long ways
from a dive shop. Another problem is that most US airports don't have a
fire department on the field.
BasiliereR(at)ci.boulder. Guest
Posted: Mon Jan 09, 2006 8:58 am Post subject: Air bottles |
FYI on the firefighter SCBA fittings. They are "all" standard GCA Universal threaded fittings. Survivair, Scott, MSA, all the same. If we have a big "event" multiple agencies will be "invited" and we need to be able to fill our bottles from other Fire Dept compressors or cascade systems. I'd love to have the SCBA adapter to Russian airplane - the SCBA bottles are a dime a dozen.
Respectfully, rick b
Posted: Mon Jan 09, 2006 11:51 am Post subject: Air bottles |
SCUBA to commie airplane adapters can be ordered from my former partner at L39ZAparts(at)hotmail.com (L39ZAparts(at)hotmail.com) unless the Kazakistan warrants caught up with him.
I defer to your experience, which is probably more recent than mine. In the mining industry, NIOSH allows only certified systems. Our safety engineers determined that using a part (cylinder) from MSA on a regulator from Scott constituted an uncertified "system". They were fanatics about things like that, not like FAA un-approved parts regs.
At another job, we changed from Scott to a German-built system, Interspiro perhaps. My recollection is that those fittings were incompatible with the existing filling fittings, but I wouldn't swear to it. It was many years ago.
Posted: Mon Jan 09, 2006 12:56 pm Post subject: Air bottles |
Yaksters,
I can not beleive that a fire dept, will allow there cylinder to connect to
your system. This is dangerous!
Once the pressure equilizes, the air can possably backflow into there tanks.
at this point there tanks are contaminated, and cannot be used for breathing
air until they are checked and cleaned. That is why you leave some pressure
in cylinders to keep them from becoming contaminated.
I would also have some concern about filling tanks at a shop as the same thing
can happen to their systems. Once the pressure equilizes form their tanks to
yours, there system will become contaminated.
I have heard to many stories about divers who had problems with thier air air
(compressors need to be maintained also), which sometimes leads to contaminated
air. That I would be rather error on the side of safety when it comes to breating
air (compressed or Oxygen).
Fly Safe
John fischer
Absolutely correct on the "system" thing.?
Scott won't fit in a Survivair pac, nor will Interspiro, MSA, etc.?but...they (the bottles) can all fill from the same hose - that is the threaded GCA adapter on them all.? The new Scott NexGen2's are too cool.? They have their own specialized fitting to allow the bottle to "snap" into place (supplying high pressure air - 4500psi- to the first stage regulator) rather than being threaded on to the 1st stage like the others and the older Scotts (using the CGA?fitting).? The new Scott bottles have 3 different ways to fill them now - including the universal GCA.? Thank you Homeland Security for the 50 Scott packs we received (at)$4,000 a pop last week.? Good bye, Survivair and Monsieur Cousteau... (the dime a dozen used SCBA bottles alluded to earlier)
More than most of you folks cared to know about how our Firefighters go to work...sorry
Rick b???
dabear(at)damned.org Guest
Posted: Mon Jan 09, 2006 1:01 pm Post subject: Air bottles |
I've used my SCUBA fitting for over 7 years. Don't see a reason to go
to scuba.
DaBear
Richard Basiliere wrote:
Quote: | FYI on the firefighter SCBA fittings. They are "all" standard GCA
Posted: Mon Jan 09, 2006 1:22 pm Post subject: Air bottles |
If I'm correct (think I am - while looking at Sarah's Yak-55 and my SU-29)
#1. There is an anti back flow valve just inside the fuselage from the external fill connector - other wise you would never be able to DC (disconnect) without losing all the air you just put in.
#2. Our Fire Dept compressors and cascade systems are set to be full (to be able to fill bottles at..) 4500-5000psi. We NEVER see less than 2500 psi on our cascade. Our compressor works just like yours - it pumps up to 4500 psi as the system drops below that. It does our FF's no good to enter a burning building with a tank less than full - 4500 + 10%. There would be a winnable liability suit...
#3. This is the same system that fills the 80 cu ft SCUBA bottles our Dive Search and Recovery team uses
#4 I guess it goes without saying that at those pressures there is NO WAY there could ever be any back flow from a system that maxes out at 50 bar - 750 psi - whatever.
Again respectfully,
Lt. rick b
Yaksters,
Fly Safe
John fischer
Quote: |
SCUBA to commie airplane adapters can be ordered from my former partner >at
L39ZAparts(at)hotmail.com unless the Kazakistan warrants caught up with >him. |
Quote: |
I defer to your experience, which is probably more recent than mine. In >the
mining industry, NIOSH allows only certified systems. Our safety >engineers |
determined that using a part (cylinder) from MSA on a >regulator from Scott
constituted an uncertified "system". They were >fanatics about things like
Quote: |
At another job, we changed from Scott to a German-built system, >Interspiro
perhaps. My recollection is that those fittings were >incompatible with the |
existing filling fittings, but I wouldn't swear to >it. It was many years ago.
pa3arw(at)euronet.nl Guest
Posted: Tue Jan 10, 2006 6:51 am Post subject: Air bottles |
As I said, be carefull in doing this...the fire fighter and/or scuba dive
bottles maintain 300 or 200 bars of pressure. Our bottles will never
equalize with these ones...remember we only need 50 bars.....backflow will
never occur...before that either the yak bottle has been blown to pieces
(and your Yak as well....) or the pressure valve has released...I hope for
you the latter.....
Hans
-----Oorspronkelijk bericht-----
Van: owner-yak-list-server(at)matronics.com
[mailto:owner-yak-list-server(at)matronics.com] Namens fish(at)aviation-tech.com
Verzonden: maandag 9 januari 2006 13:37
Aan: yak-list(at)matronics.com
Onderwerp: Re: Air bottles
Yaksters,
thing
air
contaminated
breating
Fly Safe
John fischer
at
the
ago.
Posted: Tue Jan 10, 2006 6:54 am Post subject: Air bottles |
Air flows from high pressure to low, and there are spring loaded check
valves throughout the filling systems that keep "equalized" pressure from
ever really being equal. Even without them, no system fills the "empty"
tank to a higher pressure than the supply (it's a physics thing) so it then
starts flowing the other way.
Your're right, you can't be too safe. That's why many people buy AVIATORS
breathing oxygen instead of that nasty old welding oxygen (cynicism alert-
if you're gullible stop reading now) which is full of water/oil/bugs/cat
entrails.
Posted: Tue Jan 10, 2006 7:12 am Post subject: Air bottles |
Speaking of the check valve. The check valve on my fill port has a slow
leak, are the balls the same as the ones in the uplocks ? If so who was
offering the hard balls a while ago, and I am talking durons not anything
else.
Gus
cgalley(at)qcbc.org Guest
Posted: Tue Jan 10, 2006 7:18 am Post subject: Air bottles |
Ron, Your statement about welding oxygen might have been tongue in cheek but
the facts are Welding oxygen has to be the most pure of the three common
specs. Aviators breathing is next followed by I believe. medical. In
reality ALL oxygen at this time is fractionally distilled from liquid air.
We are talking temps over 100° BELOW zero. Not possible for any water to be
in any of the three, so that when used for medicinal purposes, it is
sometime bubbled thru a water bath for the patient. So you can fill your
supplemental oxygen from any of these three but cheapest is the same as the
most expensive. Welding oxygen works fine but if Medicare is paying, get it
from the medical house.
Cy Galley
EAA Safety Programs Editor
Always looking for ideas and articles for EAA Sport Pilot
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Tue Jan 10, 2006 7:28 am Post subject: Air bottles |
_________________ Brian Lloyd
- Antoine de Saint-Exupery |
Posted: Tue Jan 10, 2006 7:31 am Post subject: Air bottles |
Exactly, thank you. Don't believe it? Call Air Liquide
Cy Galley
Posted: Tue Jan 10, 2006 7:39 am Post subject: Air bottles |
Gus,
If the check valves in your airplane look like the ones in the 52, there are
no balls inside of it like the ones used on the shuttle valves for the gear
actuators. They have three components; a spring; bronze piston that is
square with rounded corners that has a hard rubber seal on the top; a disk
that the piston rubber seal presses against to seal it off.
I had to buy one last week and unfortunately none of the usual suppliers had
any in stock except the new central parts stocking location for Aerostar in
IL, Emory I couldn't believe the price they charged for one - $225.00.
But I think I've got an excellent fix that I will be testing that will cost
significantly less than $225.
I only wish the CJ check valves would cross to the 52 because I would buy
them from Doug Sapp in a heartbeat. The problem is the fittings on the
Russian check valves are male and the Chinese ones are female. Adding a
male to male fitting would seem like the logical solution. But then you run
into a space problem. ie: The additional space required for the Chinese
check valve with a male to male conversion fitting on each end would make it
virtually impossible for the original metal lines to fit properly. In some
cases it would be impossible. In particular, the check valve closest to the
main oil tank on the + (cross) fitting where the pop-off valve is located.
Dennis
Posted: Tue Jan 10, 2006 7:51 am Post subject: Air bottles |
Brian,
Only one minor correction with regards to the 52. On the 52 the main air
valve does not have to be opened to refill the pneumatic system from the
external air fill port.
As for using N2, I'm not going to go there again because this has been
cussed and discussed on numerous occasions over the years. I have my
personal experiences and so do you and many other people with regards to
filling a completely empty MAIN air system with N2 and then trying to start
the engine.
Dennis
