Fuel system
Afterfxllc(at)aol.com
PostPosted: Fri Nov 17, 2006 7:16 pm    Post subject: Fuel system Reply with quote
Does anyone have a diagram of the dual coil dual pump wiringfor the corvair. I saw one on someone's site and can't for the life of me find it now. I do remember it said WW thought it was pretty neat and it uses 2 batteries.
Any help would be appreciated.
Jeff
dbortol
PostPosted: Fri Nov 17, 2006 7:49 pm    Post subject: Fuel system Reply with quote
Mark Langford pioneered this setup on his KR2S. His site is probably the one you're thinking of. http://home.hiwaay.net/~langford/electrical/index.html
WW's 601 is similar. He uses an oil pressure switch on the "main" side to shut the fuel pump off in a crash. I think he has a single battery.
On 11/17/06, Afterfxllc(at)aol.com (Afterfxllc(at)aol.com) <Afterfxllc(at)aol.com (Afterfxllc(at)aol.com)> wrote:[quote] Does anyone have a diagram of the dual coil dual pump wiringfor the corvair. I saw one on someone's site and can't for the life of me find it now. I do remember it said WW thought it was pretty neat and it uses 2 batteries.
Jeff
PostPosted: Fri Nov 17, 2006 7:52 pm    Post subject: Fuel system Reply with quote
Thats it thank you very much.
zodierocket(at)hsfx.ca
PostPosted: Wed Nov 22, 2006 5:26 am    Post subject: Fuel System Reply with quote
In the end we are all individually responsible for our fuel system, this
is just a poor excuse for landing your plane with the big fan not
turning. As for fuel gauges, I don't ever remember a plane in which the
float system ever worked which is why I have installed a capacitance
sender in my fuel system. IS it better and more reliable? I'll let you
know in 10-15 years. As for the header tanks, don't kid yourself here
they came with there own series of problems. One big one is my aversion
to having fuel stored in my lap ( personal preference) the other is how
many people landed without fuel because they trusted the visual sight
tube which has become kinked or rotted and plugged out of view and
drained the fuel into the cabin during a bumpy ride. Another is the
valve started leaking at the bottom of the tank once again emptying fuel
into the cabin. These things have happened and to very experienced
pilots in 601's all of which were avoidable with regular maintenance.
Nevertheless, it still happened. The fuel system in the wings I believe
to be the safest system for the occupants of the plane. I'm writing this
for the new builders who may think that a header tank is a great thing
and can't understand why we don't have one ( which is a private question
I got) In short the answer is Been there, done that, threw it away! Some
people argue the merits of a header tank and there can be some I don't
argue that point but for the masses the better system is the wing tanks
with proper amount of fuel plus reserve for every flight. Also If you
have ever been trapped on the Taxi way with full fuel holding short for
20 minutes on a 90 degree day you will learn in one foul swoop to hate a
header tank. Venting fuel vapours into the cabin and also have several
idea's form into your head on how to topple the Tower responsible for
your dilemma. Best I could come up with was repeat triple for
instructions, poor revenge for my green skin.
Mark Townsend Alma, Ontario
Zodiac 601XL C-GOXL, CH701 just started
www.ch601.org / www.ch701.com / www.Osprey2.com
btucke73(at)yahoo.com
PostPosted: Wed Nov 22, 2006 10:06 pm    Post subject: Fuel System Reply with quote
I fly two Beech Travel Air biplanes just about every weekend for a local tour company. The newer model was built in 1929. They both use header tanks - and not just 15 gallons. They are 42 gallons. The old plane has been in operation for 79 years without any problems - with a header tank. There are several people on the list that do not like the idea of fuel in the cockpit. There are others that have run wing tanks dry due to fuel valve mismanagement. It is a matter of preference.
As for all the Monday morning quarterbacking on Jim's incident. Why don't we all stop kicking the corpse. For all we know, he developed an undetectable leak. We all know that we should, and how to check our fuel levels before takeoff. It is a useless thread. The only people that are quicker to crucify incident pilots than the media are other pilots.
R/
Brandon
601 HDS flight testing.
naumuk(at)alltel.net
PostPosted: Thu Nov 23, 2006 8:22 am    Post subject: Fuel System Reply with quote
Amen.
It all comes down to luck. Unless you've tapdanced your way through the same emergency situation before, you're at a disadvantage. I know that if I were Jim, I would have done the best job I could with what I had to work with.
I'm far from God's choice of pilots. Are you?
He who casts the first stone...
Bill Naumuk
HDS Fuselage
Townville, Pa
jeffrey_davidson(at)earth
PostPosted: Thu Nov 23, 2006 8:54 am    Post subject: Fuel System Reply with quote
Brandon,
With all due respect, I beg to differ. I don't think anyone is kicking the corpse here and I also think the thread is useful if viewed in a constructive fashion. I am a MASPL customer and was checked out in N601VA. My previous post may have been too obscure to be clear. It noted that fuel is not available at Sky Bryce. Fuel exhaustion evidently was a factor in the accident. This reaffirms one of the tendencies that the FAA warns about in their Fundamentals of Instruction required for the CFI rating. Even when taking a short pleasure flight, we need to treat every flight with the same preflight precautions. Various factors go into the IMSAFE calculation that we all make prior to each flight, but situational factors beyond our control may influence us to make less that perfect decisions. We all need to be aware of that. This is of particular importance at Sky Bryce, a beautiful full-season resort. For those of us flying off airstrips or airports without services, and that is an important part of the Zenith community culture, this is especially important. Each accident is an opportunity for us to review our own procedures.
As Samuel Johnson said, people more often need to be reminded that informed.
Jeff Davidson
PS: Happy Thanksgiving to all those that celebrate this Holiday today!
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Brandon Tucker
Sent: Thursday, November 23, 2006 1:06 AM
Subject: RE: Fuel System
R/
Brandon
[quote] [b]
ggower_99(at)yahoo.com
PostPosted: Thu Nov 23, 2006 10:43 am    Post subject: Fuel System Reply with quote
This reminds me about something I once read in internet:
"Whenever we talk about a pilot who has been killed in a flying accident,
we should all keep one thing in mind.
He called upon the sum of all his knowledge and made a judgment.
He believed in it so strongly that he knowingly bet his life on it.
That his judgment was faulty is a tragedy, not stupidity.
Every instructor, supervisor, pilot, and contemporary who ever spoke to him,
had an opportunity to influence his judgment,
so a little bit of all of us goes with every pilot we lose."
Saludos
Gary Gower.
Bill Naumuk <naumuk(at)alltel.net> wrote:[quote] Amen.
Bill Naumuk
HDS Fuselage
Townville, Pa
