Bonnets
naumuk(at)alltel.net
PostPosted: Sat Nov 18, 2006 7:40 am    Post subject: Bonnets Reply with quote
Polishers-
I'm having no luck using my rotary polisher- bonnet life is nonexistant. All I have to do is go over a rivet and I'm done for. Bonnet shreds in no time. God help you if you catch a sheet metal edge- bonnet shreds immediately.
Rivets are set well within Zenith "Can't get a fingernail under it" tolerance, and I'm using no more than the "Weight of the polisher" pressure suggested by Nuvite. (Think about that sentence, we really are rocket scientists!) I have no problem with my orbital polishers, but they take forever.
Believe it or not, my $18.95 HF polisher is speed adjustable from 0-2500 RPM. Of course, I self destruct quicker at high RPM than low, but it's still just a matter of time.
1. Am I supposed to avoid going over rivets until I reach the orbital stage?
2. My HF polisher came with velcro over the backing plate. I removed the velcro, but it doesn't seem to make any difference. Anyone out there that bought the Wen rotary polisher from Nuvite- is the face velcro or smooth?
HELP!
I think we ought to archive this one.
Bill Naumuk
HDS Fuselage
Townville, Pa
larry(at)macsmachine.com
PostPosted: Sat Nov 18, 2006 10:44 am    Post subject: Bonnets Reply with quote
Hi Bill,
Polishing is hard work, given the amount of time needed to keep it
looking good. You might rethink paint. I had no idea how durable and
tough urethanes were until I was getting rid of nearly 20 painted sample
panels. They wouldn't fit the garbage container, so I folded them and
jumped on each one until they would fit in the box. Wife Lee noticed
the paint wasn't cracked or affected by the abrasion or the direct 180
degree bend on its own thickness. It was still shiny. Even if you
painted only a base color and trimmed it out in vinyl, you'd probably be
saving a lot of work.
On polishing rivets, I'd avoid high speed buffing on them as they will
shine with the least effort. On thin sheet of .016 to .020, I'd go
lightly or you'll find distortion in the surface.
Larry McFarland - 601HDS at www.macsmachine.com
Bill Naumuk wrote:
Polishers-
orbital stage?
velcro or smooth?
HELP!
Bill Naumuk
HDS Fuselage
Townville, Pa
PostPosted: Sat Nov 18, 2006 11:17 am    Post subject: Bonnets Reply with quote
Larry-
I'm committed now. Or, to be more precise, should be committed! You've
known me since the REALLY bad old days and know this is just another bump in
a washboard road. I'll figure it out sooner or later.
Although everything was trued up when I clecoed the C section, I removed
it from the cruciform jig and flopped it upside down on my workbench to
polish the underside. In order to get rid of potential snags, I set some
temporary rivets, then removed the clecos. I think I should lay the
C-section on my bench after polishing and check for trueness. If not true,
drill the temp rivets and realign.
re: Distortion- I've been careful to keep the problem to a minumum. I
have one area 2" square that might qualify.
Bill Naumuk
HDS Fuselage
Townville, Pa
tshank(at)core.com
PostPosted: Sat Nov 18, 2006 7:06 pm    Post subject: Bonnets Reply with quote
Bill,
I not sure what is causing your problem, I have yet to damage any bonnets. I have two for each grade of polish and after polishing my entire plane still have and use them all. The compounding bonnet I bought at a local auto finishing store and the rest form a local hardware/general store.
Tim Shankland
Bill Naumuk wrote: [quote] Polishers-
HELP!
Bill Naumuk
HDS Fuselage
Townville, Pa
PostPosted: Sun Nov 19, 2006 7:55 am    Post subject: Bonnets Reply with quote
To: Carlos Sa (carlossa52(at)gmail.com)
Sent: Sunday, November 19, 2006 10:53 AM
Subject: Re: Bonnets
Carlos-
The bonnets are getting under the rivets and self destructing. I figure even a thou or so clearance is enough to grab the fibers when they're being driven in at the max recommended 2000 RPM. I'm probably running more in the 600-800RPM range.
Let's face it, no matter how perpendicular you try to hold a riveter, the rivet's still going to be set at a slight angle, creating a little gap on one side. There are only a handful of planes that are built using blind rivets, and I'm sure the Nuvite procedure was created for standard, driven rivets. It comes down to simple physics. Standard rivets are DRIVEN, while blind rivets are PULLED. A slight gap is inevitable with blind rivets.
The problem only shows up when you're using a rotary polisher- orbitals aren't such a problem.
My immediate solution is to avoid the rivets when using the rotary polisher and F9. I've done a half decent job through grade C, and am going straight to Nuvite recommended flannel over a wool bonnet for grade S. Flannel doesn't have the "Hairs" to get caught. Much cheaper than a bonnet, too. My wife got me a square yard from Wal-Mart for $1.00. For the next panel I polish, I'm going to try flannel over wool on my rotary polisher, tucking the flannel under the elastic band and safety-pinning it.
Soon as I'm done answering my e-mails, I'm going out to see what grade S/ flannel over wool and my orbital results in.
Bill Naumuk
HDS Fuselage
Townville, Pa
Gig Giacona
PostPosted: Sun Nov 19, 2006 10:25 am    Post subject: Re: Bonnets Reply with quote
Just make sure it isn't green flannel.
DO NOT ARCHIVE
[quote="naumuk(at)alltel.net"]From: Bill Naumuk (naumuk(at)alltel.net)
Carlos-
Bill Naumuk
HDS Fuselage
Townville, Pa
W.R. "Gig" Giacona
601XL Under Construction
marinegunner(at)gmail.com
PostPosted: Sun Nov 19, 2006 11:44 am    Post subject: Bonnets Reply with quote
Carlos,
Your problem is interesting. I am polishing about 1/3 of my airplane - the remainder will be painted. I have used the C9 with a Nuvite wool bonnet mounted on a Dewalt 1/2" VSR Drill. I operate the drill at full speed when compounding the airplane. I generally use each bonnet at least 8 or nine times before there is any significant degrading. Apply dabs of C9, compound and repeat a couple of times. Rake bonnet as required. Never use another grade with that bonnet. Follow C9 by compounding with lessor grade, then use the orbital polisher with same grade, followed by orbital with Nuvite S and a final hand polish. I use fleece and microfiber for everything after compounding. Works very well and I do not go through bonnets very fast. Oh! I do clean bonnets by letting them soak in a solution of Tide concentrate and water for 24 hours, then put them through the washing machine with two extra rinses. Keeps bonnets in great shape. Some of the aluminum on my airplane was purchased and worked as long ago as 1986. As you might imagine, there are lots of scratches, etc. When the polish job is complete, it looks very very good. Throughout the initial process I attempt to have the bonnet moving in a direction that does not cause it to catch metal edges, but go over them. Getting some really nice comments from folks who stop by and see what I am doing. I just don't have a problem polishing over the pulled rivet heads. I do not press down very hard, but I do press down. Cannot see where this may or may not help you, but thought you might like to know my results.
Semper Fi,
Steven R. Hulland
CH 600 Taildragger
Amado, AZ
This and all other incoming/outgoing email, attachments and replies scanned prior to opening/sending and uses an external firewall to help insure virus free email and attachments.
tshank(at)core.com
PostPosted: Sun Nov 19, 2006 4:49 pm    Post subject: Bonnets Reply with quote
Bill,
You bring up a point that has always somewhat concerned me. When I started my rudder kit (the only kit I bought)
I looked up the information about how to rivet in the manual. It told about the specially shaped rivet puller to give the domed heads and a little drawing about the shape. What bothered me was that there were no dimensions or instructions other than that little drawing. I can only wonder how many variations there are of those puller heads. I know the one I made have the rivet down tight enough that I had virtually no threads pulled out when I buffed. This issue was amusing to me when the list had an animated discussion of rivet strength and which factory made the rivet. It is all immaterial when the shape of the head is never clearly defined.
Tim Shankland
Bill Naumuk wrote:
[quote] Polishers-
HELP!
Bill Naumuk
HDS Fuselage
Townville, Pa
PostPosted: Sun Nov 19, 2006 5:41 pm    Post subject: Bonnets Reply with quote
Steve-
Not Carlos, me. Carlos uses paper towels! I'm about frustrated enough to go that route myself.
There is one point you brought up- I use the same bonnet for F9 and C, but a separate one for S.
I ordered some flannel bonnets and will see what happens.
There are still two more variables to take into account. I'm polishing the bottom skin of the C section, but the top isn't in place yet. There's a good possibility the ribs are moving down under pressure since they're still relatively free, and creating a pinch point. The other thing is, I've been using $1.99 HF bonnets. I would expect a Nuvite bonnet to be more durable.
What really bothers me is, C isn't doing too good of a job getting rid of the F9 scratches.
Bill Naumuk
HDS Fuselage
Townville, Pa
bryanmmartin
PostPosted: Tue Nov 21, 2006 5:16 pm    Post subject: Bonnets Reply with quote
I didn't use a bonnet on my plane for the compounding buffer. I used a wool buffing pad, the velcro backed type. This is woat was recommended by Nuvite.
Polishers-
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive
Bryan Martin
do not archive.
PostPosted: Wed Nov 22, 2006 4:01 pm    Post subject: Bonnets Reply with quote
Interesting. I'll try that if the flannel bonnets don't work. Thanks.
Bill Naumuk
HDS Fuselage
Townville, Pa
PostPosted: Thu Nov 23, 2006 7:50 am    Post subject: Bonnets Reply with quote
Oh, yeah.
Bill Naumuk
HDS Fuselage
Townville, Pa
