Rex Hefferan
Joined: 10 Jan 2006 Posts: 147 Location: Olney Springs, Colorado USA "NOT a Kitpig"
Posted: Sun Nov 19, 2006 6:46 am Post subject: Heat Gun WAS: Jabiru Service Bulletin |
Here's a page with a few to compare:
http://cableorganizer.com/solder-it/
Rex
Colorado
PWilson wrote:
Jim,
Its a butane fueled soldering torch. Find at Radio Shack or Harbor
Freight but best of all go to Home Depot or Lowes for a nice kit with
all kinds of ends and a refill canister. Very handy for soldering big
wires and soldering in remote places.
Regards, Paul
At 12:45 AM 11/19/2006, you wrote:
> On Nov 19, 2006, at 6:46 AM, Jim Crowder wrote:
>> The last time I wrote you I am sure I misspelled your name. Sorry.
> Don't worry, Jim, having lived in three different countries, ... I am
> used to be called all sorts of names!
>> What is the blue tool you show in your picture apparently identified
>> as torch?
> The word "torch" is what I think may translate what it is, in
> English, but I may be wrong. This is the kind of tool you find e.g.
> in the kitchen, to make a crème brulée. You may also use it to
> solder. It uses lighter gas but while a lighter only burns the gas
> directly, this device allows for a flow of air to come on the side
> and therefore works more like a torch, giving a warmer blue and
> pencil-sharp flame.
> Cheers,
> Michel
> do not archive
_________________ Rex
N740GP - M2/582
Colorado |
jimlc(at)att.net Guest
Posted: Sun Nov 19, 2006 9:06 pm Post subject: Heat Gun WAS: Jabiru Service Bulletin |
At 07:46 AM 11/19/2006, you wrote:
Thanks fellows. I actually own one of the devices which I picked up
some months ago but discovered it did not come with fuel which I have
not gotten around to purchasing. Partly because I have not needed it
to date. Now I will know of a good use for it.
I will not receive my Jabiru 3300 engine until the last of
February. It will hopefully will not need this attention for a
while. I am just trying to keep up ahead of time.
Jim Crowder
