		jdalton77(at)comcast.net Guest
				 Posted: Sat Nov 18, 2006 7:29 pm    Post subject: Trim cables question |
				So, after cursing and struggling with the Trim  control cables I finally got them all routed and hooked up.
  Now the manual tells me to disassemble the  HS/Tailcone/VS.  Do I have to pull out the cables I routed or did any of  you disconnect them at the trim motor?
  Jeff Dalton
		armywrights(at)adelphia.n Guest
				 Posted: Sat Nov 18, 2006 7:31 pm    Post subject: Trim cables question |
				After all of my struggling to connect them I left them connected for at least two days so I cold take pictures, but then yes, I disconnected them from the elevators. Left them attached to the trim motor/mount.
 Rob Wright
 #392
 Fuse Floor Pans
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jdalton77
  Sent: Saturday, November 18, 2006 9:28 PM
  Subject: Trim cables question
 Jeff Dalton
    	  | Quote: | 	 		  |   www.aeroelectric.com  | 	  0123456789012345
		egohr1
  Joined: 17 Jan 2006 Posts: 38 Location: Oklahoma City
				 Posted: Sun Nov 19, 2006 5:53 am    Post subject: Re: Trim cables question |
				Yes, I disconnected them, but before you pull them though tape a piece of heavy wall tygon tubing to the end of the tube.  Leave the tube in the HS as a fish line.  When you go to reinstall the tube the tubing will make the reinstllation mech easier.
  _________________ eric gohr
EGOHR86@alumni.carnegiemellon.edu |
		Tim(at)MyRV10.com Guest
				 Posted: Sun Nov 19, 2006 7:17 am    Post subject: Trim cables question |
				Great idea Eric.   One thing, for those doing the pre-assembly of the
 tail.  There's really not a lot to be gained by installing the trim
 mechanism early.  You may as well wait untilvyou get to the step
 post-painting where you have to assemble all of the airframe.  I didn't
 really find anything necessary that needed to be done early.  If it were
 me, I'd just avoid it until later.  You could still assemble the rest of
 the tail so you can cut the intersection fairing though.
 egohr1 wrote:
  <EGOHR86(at)alumni.carnegiemellon.edu>
  -------- eric gohr EGOHR86(at)alumni.carnegiemellon.edu
		KiloPapa
  Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
				 Posted: Sun Nov 19, 2006 8:33 am    Post subject: Trim cables question |
				Tim,
 Are you speaking of the elevator trim?
 Kevin
 40494
 tail/empennage
  _________________ Kevin
40494
do not archive |
		wvu(at)ameritel.net Guest
				 Posted: Sun Nov 19, 2006 8:55 am    Post subject: Trim cables question |
				Jeff,
  I think there are disadvantages at both ends.  I did mine at the  trim tabs end.  There's not much room at the trim motor end to secure the  cables.  If you have big arms to stick them through that little bulkhead,  you'd have to crawl inside the tailcone to secure the cables at the trim  motor.
  Before you install the rudder for the last time though there are four  nutplates required on the VS spar to secure the emp fairing.  Make sure  those are installed or you'd have to take the rudder off one more time to rivet  the nutplates, or use screw/nut later.
  Anh
  #141
  [quote]   ---
				 Posted: Sun Nov 19, 2006 3:01 pm    Post subject: Trim cables question |
				Yep, elevator trim.  I didn't even start to install my actuation until
  >30 days from flight.  No big deal at all.
 KiloPapa wrote:
  Tim,
  Kevin
  40494
  tail/empennage
		johngoodman
				 Posted: Mon Nov 20, 2006 6:44 am    Post subject: Re: Trim cables question |
				I'll be at that spot in about a month; thanks for the heads up. For Eric, you mentioned Tygon tubing. Since Tygon is a brand, is there a type of their tubing that's superior, or do you just mean some kind of flexible tubing?
 John
  	  | Tim(at)MyRV10.com wrote: | 	 		  Great idea Eric.   One thing, for those doing the pre-assembly of the
 egohr1 wrote:
  <EGOHR86>
  _________________ #40572 Phase One complete in 2011 |
				 Posted: Mon Nov 20, 2006 8:02 am    Post subject: Trim cables question |
				John, you can use tygon, rubber, poly, electrical wire, a coat hanger,
 or anything you want.  The idea is to leave something in there that
 you can attach to the end of the cable to pull the cable through.
 Ideally, something that fits nice and tight so you can pull with
 a little force when needed.  Just try some things...maybe start with
 cheap poly tubing, and see what fits over the threaded end well.
 You can always add a layer of tape over it to help secure it.  Just
 leave something in the stabilizer so pull with or you'll have to
 deal with the pain twice.
 johngoodman wrote:
  John
 > Tim Olson - RV-10 N104CD - Flying
 > do not archive
  #40572 Empennage - starting Elevators!
  N711JG reserved
  http://forums.matronics.com/viewtopic.php?p=75866#75866
		egohr1
		johngoodman
				 Posted: Tue Nov 21, 2006 6:21 pm    Post subject: Re: Trim cables question |
				 	  | Tim(at)MyRV10.com wrote: | 	 		  .....  Just try some things...maybe start withcheap poly tubing, and see what fits over the threaded end well.
 Tim,
 That noise you hear is me slapping my forehead (g). Just something to fish with, but I took it for something special. As my wife says:
 "You're not too bright, I like that in a man."
 John
