Rudder bottom secrets?
recapen(at)earthlink.net
PostPosted: Fri Nov 24, 2006 5:08 am    Post subject: Rudder bottom secrets? Reply with quote
Fellow listers,
Are there any secrets to fitting the fiberglass rudder bottom cap? I'm cleaning up a bunch of little things that I have been putting off and I have come to this chunk of plastic.
Its not cut in a straight line although the bottom of the rudder is - that's one issue. There does not appear to be a mold line to cut to either.
The other issue is cutting out the forward notch for the rudder throw arms. I've seen this done a couple of different ways - the one that comes closest to what I would like to do is cutting the horizontal line of the rudder arms forward and putting in a few nutplates to screw it back together after it is installed.
I don't recall reading anything in the instructions on how this is to be accomplished (OK - I'll read them again to be sure). I can make a template of the area that it fits to - but how do you ensure that both sides are symmetrical?
Any explicit instructions or photos would be greatly appreciated.
Ralph Capen
RV6AQB N822AR (at) N06 Aligning wings and a bunch of little things.
Hopperdhh(at)aol.com
PostPosted: Fri Nov 24, 2006 6:12 am    Post subject: Rudder bottom secrets? Reply with quote
Richard,
I don't have any photos, but I will admit to one mistake I made which is still visable on my airplane.
I had the same concerns that you do, so I just trimmed until it looked right. But, when I assembled the whole airplane it is obvious that the rudder bottom sticks about 1/4 inch lower than it should. So my advice is to wait to fit it after you have the vertical stab on the fuselage.
Dan Hopper
RV-7A Flying since July '04
In a message dated 11/24/2006 8:10:55 AM Eastern Standard Time, recapen(at)earthlink.net writes:
Fellow listers,
Ralph Capen
PostPosted: Fri Nov 24, 2006 6:45 am    Post subject: Rudder bottom secrets? Reply with quote
My VS is on so I'll hopefully not have it sticking out the bottom....Thanks,
Ralph
smittysrv
PostPosted: Fri Nov 24, 2006 7:14 am    Post subject: Rudder bottom secrets? Reply with quote
Here's a link to a short tutorial I found on the internet about attaching
the rudder bottom. It doesn't mention how much of the rudder top to cut off.
On my RV-9A the rudder fiberglass bottom actually has a faint line on the
service to indicate where to cut the flanges off. I had to hold it up to the
light to see the line.
http://www.cafes.net/leo/RV-6/R-Fairing/R-Fairing.html
Have a goodun!
Smitty's RV-9A
http://SmittysRV.com
Smittys RV-9A
SmittysRV.com
PostPosted: Fri Nov 24, 2006 7:47 am    Post subject: Rudder bottom secrets? Reply with quote
Smitty,
The tutorial you've pointed me to also has a reference to a RVator article that I will check out.
I'll look for the line again on my bottom part.
Stuff like this makes my donation worth it!
Ralph
PostPosted: Fri Nov 24, 2006 8:38 am    Post subject: Rudder bottom secrets? Reply with quote
Oops -- sorry I called you Richard, Ralph!
In a message dated 11/24/2006 9:51:31 AM Eastern Standard Time, recapen(at)earthlink.net writes:
[quote]--> RV-List message posted by: "Ralph E. Capen" <recapen(at)earthlink.net>
Ralph
jfogarty(at)tds.net
PostPosted: Sat Nov 25, 2006 8:11 am    Post subject: Rudder bottom secrets? Reply with quote
Hey Smitty, Did your have a faint line for the forward notch, because my
fiberglass bottom looks like it does.
Jim
