ron.mcgann(at)baesystems. Guest
Posted: Mon Nov 27, 2006 12:26 am Post subject: Flowscan installation |
G'day all,
I am installing the flowscan sender at the moment. The sender mount holes appear to be sized for an AN4 bolt, while the fuselage attach bracket has nutplates for AN3. What's the go here - remove the mount and install nutplates for AN4, or insert a bushing into the sender? I received zero documentation from GRT on the floscan - is this normal?
cheers,
Ron
187 finishing
