dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Sun Nov 26, 2006 6:25 pm Post subject: 2 Tailcone Questions: F-1012B came unpunched, small tear in |
My F-1012B was not pre-punched for the skin either. I just match
drilled as you have noted. No tears in my F-1010. Kit # 40559
David Maib
On Nov 26, 2006, at 7:12 PM, MauleDriver wrote:
During initial assembly of tailcone, I noticed that F-1012B was not
pre-punched for the skin. The plans shows both A & B as pre-
punched. It will be very easy to match drill the bulkhead using the
skin punches and relying on the A bulkhead for alignment. But I am
curious whether others have encountered the same thing.
I also noticed a very small tear in the thin flange around the
central hole in bulkhead F-1010. It appears to have resulted from
the forming of the flange. It would seem to be subject to enlarging
if the area is stressed. Would a stop hole be called for? Or
grinding the tear out? Or a new part? I will be going to Vans with
this.
Link to photos of tear:
http://www.mykitlog.com/users/display_log.php?
user=MauleDriver&project 24&category=0&log 3464&row=4
Bill Watson "MauleDriver"
The QB Fuse and Wing arrived last week (9 weeks early) - here we
Gooooooo!
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
