jhasbrouck(at)woh.rr.com Guest
Posted: Tue Nov 28, 2006 5:39 pm Post subject: Rudder question |
Question regarding rudder bearing blocks and the "nylon" rudder cable guides. How snug should both of these be? I can tighten the center rudder bearing block to the pont where the rudder pedals will not move, obviously too tight. Same with the rudder cable guides. How much play do we need in these? Are the aerodynamic forces on the rudder enough to overcome the situation? Will there be enough wear in to loosen the pedals and the cable? Inquiring minds want to know
John Hasbrouck
#40264
