Posted: Thu Nov 30, 2006 10:09 am Post subject: LED light revisted. |
Deems,
Very helpful web site you have!
I've been to the archives and no help there. That search engine sure isn't
Google
Deems--Your web site gives a link to Jeff"s LED nav lights.
I don't see any contact info for Jeff on that site.
Second, what voltage are these lights(Your Nav lights). Will the 14v lights
run on 12v system?
I see so many LEDs that are either 14V or 28 volt. without revisiting the
12, 28 volt issue. What are people using if they are a 12V system to drive
a 14 volt LED lights or 28V lights.
JOhn G.
Deems Davis
Posted: Thu Nov 30, 2006 10:35 am Post subject: LED light revisted. |
You can contact Jeff Bordelon (at) RV-7A(at)austin.rr.com ;they are 12/14V
and only draw a small amount of current (< 1 amp). Re 12V / 14V: I'm
definitely NOT the electron guru, and somebody else should jump in here
and provide a definitive answer, but they are essentially the same
system and operate from the same battery/alternator source. Battery
outputs 14.5 v when fully charged, there is some loss in the wiring due
to wire resistance etc. You may want to get Bob Nuckols book available
on his web site and subscribe to the Matronics aero-electric list as
well. Bob provides free consulting via the list on a time available
basis, Some of the stuff is more detailed than I want or care about, but
it is a very valuable resource. In his book he explains all about the
12/14v and 24/28v systems and why they are referred to the way they are.
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
ps. if you contact Jeff, let him know he's got no contact info on the
LED page.
John Gonzalez wrote:
Deems,
isn't Google
lights run on 12v system?
the 12, 28 volt issue. What are people using if they are a 12V
system to drive a 14 volt LED lights or 28V lights.
JOhn G.
Posted: Thu Nov 30, 2006 11:04 am Post subject: LED light revisted. |
The book is in the mail.
Thanks for the contact.
John
| Quote: | From: Deems Davis <deemsdavis(at)cox.net>
Subject: Re: LED light revisted.
Date: Thu, 30 Nov 2006 11:33:22 -0700
You can contact Jeff Bordelon (at) RV-7A(at)austin.rr.com ;they are 12/14V and
only draw a small amount of current (< 1 amp). Re 12V / 14V: I'm definitely
NOT the electron guru, and somebody else should jump in here and provide a
definitive answer, but they are essentially the same system and operate
from the same battery/alternator source. Battery outputs 14.5 v when fully
charged, there is some loss in the wiring due to wire resistance etc. You
may want to get Bob Nuckols book available on his web site and subscribe to
the Matronics aero-electric list as well. Bob provides free consulting via
the list on a time available basis, Some of the stuff is more detailed than
I want or care about, but it is a very valuable resource. In his book he
explains all about the 12/14v and 24/28v systems and why they are referred
Deems Davis # 406
ps. if you contact Jeff, let him know he's got no contact info on the LED
page.
>Deems,
>Google
>Thanks,
>JOhn G.
