		VE3LVO(at)rac.ca Guest
				 Posted: Mon Jan 02, 2006 8:47 am    Post subject: 914 drivers only please! |
 Intermediate frame mounting -
 To Steve, Kevin, Bob, Cliff, Paul, Patrick, Fred and others:
 Many thanks for such a lrage and quick reply to my plea. One or
 two misinterpreted the problem but in most cases the solution varied
 between longer bolts or replacement after compression. I worried that a
 longer bolt would soon be an inappropriate length after compression - grip
 and all that. Fred came up with the "'why didn't I think of that" solution -
 threaded 5/16 cut to size until compression allowed 5A-40 replacement. Lord
 knows I used it elsewhere but ennui and frustration claimed the day.
 I will explore that avenue, while I fuss over the next plateau -
 the placing of the oil tank makes it impossible to site the filter
 compartment below it. All the photos show the tank at the top of its
 possible height, yet the filter compartment metal is still too high to house
 the tank drain - and probably other facilities.
 It's just one did-it-wrong after another............
 May 2006 be a better backdrop......
 Cheers, Ferg
		BEBERRY(at)aol.com Guest
				 Posted: Mon Jan 02, 2006 10:27 am    Post subject: 914 drivers only please! |
		hurstkr(at)growzone.com.a Guest
				 Posted: Mon Jan 02, 2006 12:35 pm    Post subject: 914 drivers only please! |
  	  | Quote: | 	 		   My particular one is vibration. Horrid airframe vibration between
 2000 and  |
 3700 rpm with my 914
 Patrick,
 Have you tried getting your propeller dynamically balanced whilst on the
 aircraft ?
 Also, have you checked your spinner for run-out? Have you tried it
 without the spinner ?
 Has the aircraft ever had a prop strike ?
 Cheers
 Kingsley
 Happy New Year to all.
				 Posted: Mon Jan 02, 2006 1:07 pm    Post subject: 914 drivers only please! |
				 Posted: Mon Jan 02, 2006 1:16 pm    Post subject: 914 drivers only please! |
 Hi! Patrick.
 I am no Rotax Authority but:-
 a) Did you get the carburettor's balanced?
 b) Is the "sprag clutch" in good order?
 c) Did you have the prop balanced dynamically?
 d) Have you had a stress resonance check done on the prop/engine
 combination?
 e) is your ignition working adequately on all cylinders?
 Bob Harrison
 Do not archive.
		acrojim(at)cfl.rr.com Guest
				 Posted: Mon Jan 02, 2006 2:24 pm    Post subject: 914 drivers only please! |
 You might try checking the pitch of each blade to see if all are the same.
 Jim
 BEBERRY(at)aol.com wrote:
 Hope you have all your problems sorted now Ferg. There will be more!!
 My particular one is vibration. Horrid airframe vibration between 2000 and
 3700 rpm with my 914. Fuel drained and refilled, filters cleaned, carbs
 cleaned and jets., carbs balanced with proper kit, set of new plugs fitted,
 engine mounts checked. New Arplast prop back in France for re-balancing. All
 plugs show equally nice and grey. I have run out of ideas. Has anyone
 experienced similar problems and can suggest any other areas of search please ?
 Had no problems with the old Warpdrive (now defunct).
 Patrick
		SPurpura(at)aol.com Guest
				 Posted: Mon Jan 02, 2006 4:49 pm    Post subject: 914 drivers only please! |
 You should get a dynamic balance done with a new prop,,just for peace of
 mind.
 Sam N77EU
				 Posted: Mon Jan 02, 2006 5:19 pm    Post subject: 914 drivers only please! |
 Hello Patrick
 No real life experience, some ideas though.
 After you get prop back, do a dynamic balance of prop (on plane and
 running)after you make sure blades track the same and they are all at the
 same pitch, check your motor mounts are in good shape and fully tightened,
 might as well check to see if all mounts are not cracked.
 Make sure that the throttle cables where they attach to arms on carbs
 rotate free, if they do not there will be an imbalance because 1 carb will
 be opened more than the other.
 Check out Causes of Vibration at:
 http://www.rotaxservice.com/rotax tips/rotax troubleshooting.htm
 You need Power Point.
 Ron Parigoris
		terrys(at)cisco.com Guest
				 Posted: Tue Jan 03, 2006 9:46 am    Post subject: 914 drivers only please! |
 Hi Patrick,
 We had problems with vibration in that rpm range that had us stumped for
 a while. It turned out to be a mis-match in the prop blade incidences
 on our Airmaster prop. As I recall, one blade was almost one degree off
 from the other two. Turned out to be a problem with the blade followers
 that was eventually corrected by the factory. Depending on how the
 blades were installed in the hub (and the orientation of the followers),
 the incidences could come out fairly close, or be rather bad.
 Terry Seaver
 A135 / N135TD
