jfrjr(at)adelphia.net Guest
Posted: Wed Dec 06, 2006 7:59 pm Post subject: wing tip lens repair |
I faintly remember discussions about removing Sharpie Ink from plexiglass but when I do the search I am obviously not asking the right questions; so I need help. After doing a nice job on my wing tip lenses I stupidly grabbed some acetone to clean off the ink marks--fortunately I only smudged a small area. Is there a way to get rid of the hazy smudge, and what should I have used in the first place? Thanks
Jay Rowe 40301
Tim(at)MyRV10.com Guest
Posted: Wed Dec 06, 2006 8:20 pm Post subject: wing tip lens repair |
You're pretty much stuck with it for all practical purposes, unless
you want to sand and polish it, which will leave it uneven.
Kerosene is the preferred solvent. I was also able to use
DX-33 (I think that's the right number) the PPG stuff you use
during painting to clean things, without harming the plexi, but I
didn't leave it on long.
Jay Rowe wrote:
| Quote: | I faintly remember discussions about removing Sharpie Ink from
Jay Rowe 40301
Posted: Wed Dec 06, 2006 10:29 pm Post subject: wing tip lens repair |
Well, the best advice is to not get the sharpie on the lens where it can be seen!!!
But, since you're past that, you might be able to polish it out with some toothpaste, or some paint compound from the auto parts store. It'll take some elbow grease, but refrain from using to large a grit ..... this is best done slowly.
Linn
Jay Rowe wrote:
[quote] I faintly remember discussions about removing Sharpie Ink from plexiglass but when I do the search I am obviously not asking the right questions; so I need help. After doing a nice job on my wing tip lenses I stupidly grabbed some acetone to clean off the ink marks--fortunately I only smudged a small area. Is there a way to get rid of the hazy smudge, and what should I have used in the first place? Thanks
Jay Rowe 40301
david555(at)cox.net Guest
Posted: Thu Dec 07, 2006 1:46 am Post subject: wing tip lens repair |
Try Flitz at www.flitz.com, it worked great for me. Expensive at $22 for 5 oz, but worth it. David O Boone
