RV 10 designation with FAA
GenGrumpy(at)aol.com
PostPosted: Thu Dec 14, 2006 7:19 pm    Post subject: RV 10 designation with FAA Reply with quote
For those interested, I sent the following to van's today (might help if you also prodded them)
Grumpy #40404
Vans,
While working with FltPlan.com in trying to build my RV 10 (#40404) database, and from which I file flight plans with the FAA, the RV-10 is not included as an identified model in Section 5 (page 5-1-82) of the FAA Order 7340.1Y. It lists RV models 3 through 9 only.
Paragraph 1-3-3 (page 1-3-1) provides instructions on how to request an aircraft-type designator be added to the approved identifiers.
All of us RV 10 fliers (and those to fly later) would appreciate it if Van's would request that the -10 be added to FAA's list.
Thanks - John Miller
#40404 with 40 hrs and counting!!
coop85(at)bellsouth.net
PostPosted: Thu Dec 14, 2006 7:47 pm    Post subject: RV 10 designation with FAA Reply with quote
FWIW, same issue when filing through DUATS. Oddly enough though, if you file over the phone you show as a RV-10. Tracking on FlightAware.com has shown me as a RV-10 if a file by phone. For now if filing through DUATS I call myself a RV-6/G and then in the remarks say it’s really a RV-10 but I’m not sure it’s made a difference.
Marcus
40286
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GenGrumpy(at)aol.com
Sent: Thursday, December 14, 2006 10:19 PM
Subject: RV 10 designation with FAA
Grumpy #40404
Vans,
www.aeroelectric.com
n223rv(at)wolflakeairport
PostPosted: Thu Dec 14, 2006 8:01 pm    Post subject: RV 10 designation with FAA Reply with quote
Why not just file as experimental??
And I'm sure Van's would know how to do this, especially if 3-9 are already there....
Tim(at)MyRV10.com
PostPosted: Fri Dec 15, 2006 4:44 am    Post subject: RV 10 designation with FAA Reply with quote
Well, I've had to file HXB/G but then inevitably as I'm cruising along
someone has to ask what kind of plane it is because it's too vague
to envision. It would be great to just have RV10/G available.
Hopefully they'll get'r-done.
Mike Kraus wrote:
[quote] Why not just file as experimental??
already there....
