Posted: Wed Dec 06, 2006 10:09 pm Post subject: QB access into side panels below door rim. |
Dan, You're The Man!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Put in three hours tonight and am back on track.
Thanks a ton..
JOhn G
Or by the way, the conduit that people are using, due to it being an
experimental, is there any requirement. The corregated crap at PepBoys
burns pretty well when the fire gets on it and stinks. The NyloFlo stuff
melts but the the flame seems to self extinguish doesn't smell too bad.,
The Home Depot 3/4 black irragation line of which I have 500 feet of does
just like the Pep Boys car stuff. Did anyone test their's with a flame
The Nyla flow stuff from Do It center smells like snow skis being waxed.
rvbuilder(at)sausen.net Guest
Posted: Thu Dec 07, 2006 6:12 am Post subject: QB access into side panels below door rim. |
The fiber optic conduit that I used (along with Tim and others) should
be plenum rated. This basically means it has a coating on it that
increases the temp at which it ignites and also emits less fumes. I
used the poly pipe in the wings where I'm not as concerned about it.
All of my stuff is still in boxes otherwise I would run a fire test on
the conduit. Maybe Tim want's to light some up.
Michael
LloydDR(at)wernerco.com Guest
Posted: Thu Dec 07, 2006 6:22 am Post subject: QB access into side panels below door rim. |
Use Fiber Optic Cable ducting that is plenum rated, if it ever burns, it
is rated to be non-toxic as it is used in an air return plenum in the
building.
I had some laying around from a cabling job and took Tim's advice. You
could probably call some of the local computer network guys and they
would have what you need laying around.
Dan
Posted: Thu Dec 07, 2006 7:34 am Post subject: QB access into side panels below door rim. |
Can one of you guys light some up with the stove or a soldering torch.
Where do you get this stuff if I don't use the irrigation tubing. Light up
one of those snap bushing and tell me what the difference would be if the
wires got worn on one of them and lit it(for those not using conduit). I
bet it burns.
JOhnG
[quote]From: "Lloyd, Daniel R." <LloydDR(at)wernerco.com>
Subject: RE: QB access into side panels below door rim.
Date: Thu, 7 Dec 2006 09:20:40 -0500
building.
Dan
rleffler
Posted: Thu Dec 07, 2006 8:22 am Post subject: QB access into side panels below door rim. |
| Quote: | Where do you get this stuff if I don't use the irrigation tubing.
Here's a source:
http://onlinecatalog.anixter.com/SearchResultsServlet?QUERY=BROWSE&CATALOGID 04032900100000000&SECTIONID 04032900100004000&SUBSECTIONID 04032900100004006&SUBSECTIONNAME=Innerduct
I didn't check to see what the smallest increment you could purchase. If you have to buy the entire reel, you'll have plenty for all your friends. :^)
_________________ Bob Leffler
N410BL - Phase I
indigoonlatigo(at)MSN.COM Guest
Posted: Thu Dec 07, 2006 9:40 am Post subject: QB access into side panels below door rim. |
I won't need one inch diameter. Thinking I am going to use something else
or go with what I have 3/4 inch.
Thanks.
JOhn G
| Quote: | From: <rvmail(at)thelefflers.com>
Subject: Re: RE: QB access into side panels below door rim.
Date: Thu, 7 Dec 2006 11:19:43 -0500
Here's a source:
Tim(at)MyRV10.com Guest
Posted: Fri Dec 08, 2006 7:46 am Post subject: QB access into side panels below door rim. |
If you know anyone that is in the computer cabling or electrical
business ask them if they have any extra laying around from a job. Good
chance they will just give it to you as long as they are short amounts.
Michael
