Kitfox on ski technique
Michel
PostPosted: Mon Jan 30, 2006 1:23 am    Post subject: Kitfox on ski technique Reply with quote
Hello guys,
Yesterday was the first nice day this year and I went flying. I used the opportunity to do some touch and go, with my skis, on the snow, on the shoulders of the runway. It didn't go very well.
There was about a good foot of powdery snow with a thin crust of ice on the top. Because I don't have a ski on the tailwheel, I try to land on two wheels, tail up. But then, the drag (wheel penetration skis) in the snow is such as the nose tend to go down. Normal reaction is to pull the stick. But then the AoA increases and the plane is airborne again, to fall back in the snow a few yards away. It felt like the bad landings I did when I learnt to fly my tailwheel Kitfox.
I did four such bad snow landings then gave up. I can't find the proper technique. Should I do a three-points landing? Do you, guys, have a ski on your tailwheel? How do you attach it?
Thanks in advance,
Michel
Kitfox 3 - Jabiru 2200
jcorner(at)shaw.ca
PostPosted: Mon Jan 30, 2006 6:38 pm    Post subject: Kitfox on ski technique Reply with quote
Michel
Many long years ago when I flew ski equipped Aeroncas, (no tail ski)
I was taught to land as if on wheels.
When you think about it, it will help to keep the aircraft straighter
on roll out and shorten landing distance.
Jim
Hello guys,
Thanks in advance,
Michel
gofalke(at)sbcglobal.net
PostPosted: Mon Jan 30, 2006 6:44 pm    Post subject: Kitfox on ski technique Reply with quote
Michel,
I had a similar experience with home-made wheel penetrating skis.
The snow was very deep. Upon trying to land, the Fox decellerated very fast, in fact so fast that I was afraid to get airborn again. I had to use full power to get off again before I stopped. The lack of a tail ski should not effect the performance that much.
I think my problem was the wheels penetrated to far down, about 1-1/2" below the skis, and the gap between the tires front and back were too large for snow to accumulate. I took the skis off, waiting for modification, if I ever feel like it.
Herb Gottelt, M4-1200,912UL,
Mt. Prospect, IL
Michel Verheughe <michel(at)online.no> wrote:
Hello guys,
Thanks in advance,
Michel
smokey_bear_40220(at)yaho
PostPosted: Tue Jan 31, 2006 11:55 am    Post subject: Kitfox on ski technique Reply with quote
Michel,
I was given a picture last fall of a tail wheel ski
made out of an aluminum dish pan. Your wheel sticks
thru like the main wheels, but the dish pan keeps it
from sinking into the snow. Brackets were made and
riveted to the pan to attach it to the tail wheel
assembly. The only problem I saw with the system is
that you would not have help steering on the snow
since the pan was a round dish shape. Only the rudder
would be effective.
Anyway, a very inexpensive tail wheel sky that worked
for a Rans S-7 and might work for a Fox too.
Unfortunately I am in Equador and not at my home
computer to send the pic. Be back next week if you
are interested in it, but I bet you could figure one
out yourself by then. Just have to wait until your
wife is out of the kitchen to grab a pan....
Kurt S.
--- Michel Verheughe <michel(at)online.no> wrote:
Hello guys,
Thanks in advance,
Michel
Michel
PostPosted: Tue Jan 31, 2006 1:29 pm    Post subject: Kitfox on ski technique Reply with quote
Hello Kurt,
On Jan 31, 2006, at 8:52 PM, kurt schrader wrote:
Brackets were made and riveted to the pan to attach it to the tail
wheel
assembly.
I have seen something similar on a EuroCub but my worry is that, if the
snow is soft enough, it would dig like a plough. I understand that, in
the snow, the tailwheel won't steer at all. It's not a problem, to
taxi, I have to give so much throttle that I usually do it on the main
gear, tail up, using the rudder only.
I was thinking of making something that would be ahead of the
tailwheel, something I could attach to the cross pipe that is used to
attach a dorsal fin, on seaplanes. That ski, or aluminium plate would
then make sure that the snow won't reach up to the fuselage AND that no
snow can accumulate on the top of that "ski."
Any thoughts, anyone?
Entonces, que aprovechas tu viaje y hasta pronto! Smile
Michel
CrownLJ(at)verizon.net
PostPosted: Tue Jan 31, 2006 5:58 pm    Post subject: Kitfox on ski technique Reply with quote
Michel,
I have an Avid on ski's and I use the following method. I always take off and land with full flaperons. I also put a 5lb lead weight on the tail to offset the weight of the skis. I approach as per a normal 3 point landing, but just hold the tail off from touching and allow the mains to touch. I am usually adding power at this point. (about 3500 rpm Rotax 3:1) Snow does produce a fair amount of drag and it will want to tail up. Just hold the nose where you want it. If you lift off again, I would suggest that you may be too fast on touch down, and too brisk on the stick. I normally touch down at 40ish mph ias. It indicates a stall at 38ish. I would highly encourage the use of full flapperon to get the attitude more shallow. Some will say that you will lack aileron control, but I do not find this to be the case, but more rudder is needed to stay coordinated. The Avid flapperons are limited to 15 degrees ref a level wing.
Hope this help. I have to run to pick up the kids.
Larry
algate(at)attglobal.net
PostPosted: Wed Feb 01, 2006 7:53 am    Post subject: Kitfox on ski technique Reply with quote
I would be careful using full flapperon deflection on late model 4 or Lite2
Kitfoxes as this will basically make it very difficult to keep the tail
down. You will almost be guaranteed to land nose down and have an unpleasant
view of the runway. I'm sure this is different for the Avid.
GaryA
