switches?
CJohnston(at)popsound.com
PostPosted: Wed Dec 20, 2006 3:11 pm    Post subject: switches? Reply with quote
Hey all -
I'm trying to nail down some ancillary components for the panel, and
have a couple of questions. For those of you who have installed a
trutrak ap, how many poles and throws are required of the switch that
switches the AP source from a NAV radio to the GPS (chelton)? I
couldn't find a reference to it in the Trutrak installation
instructions. Also, I plan to have a switch that will move all functions
except PTT from the pilot to co-pilot side. Are people using relays to
accomplish this? if so, I suspect a SPST or SPDT switch would fit the
bill? I'm away from all my reference materials, and I'm trying to nail
down what I need to order.
Thanks all!
cj
#40410
fuse
www.perfectlygoodairplane.net
rene(at)felker.com
PostPosted: Wed Dec 20, 2006 3:31 pm    Post subject: switches? Reply with quote
For the stick switches, I am using one switch and putting all the grounds
through it. Not my original idea, but sounded like a good way to go. I
will let you know if it works once I get my panel finished.
Rene' Felker
40322
N423CF
Finish kit or something like it.
noel(at)blueskyaviation.n
PostPosted: Wed Dec 20, 2006 4:22 pm    Post subject: switches? Reply with quote
CJ
Double through double pole. Auto pilot arinc a & b in the middle gps arinc
a & b on one end and effis aric a & b on the other.
I have installed 4 or five Grand rapids EFIS now with the trutrak autopilot
and the next two that are currently in the works I am NOT putting the arinc
source switch in. Just going directly to the EFIS. Why? When you switch
arinc sources the autopilot drops out of GPSS (well after a few seconds) at
witch time your scan is somewhere else on the panel, then the plane starts
doing something else than what you have in mind. So you get the autopilot
back up on GPSS and it reacquires the GPS track so heading changes are in
order. After a few times like this you get really good and switch the Arinc
source turn the autopilot to heading mode and then back to GPSS and life is
great. OR you can just leave the autopilot alone and use the EFIS the
autopilot never drops off line and life is great.
my 2.3333333 cents worth
Noel
The rest of the story:
To isolate pilot and copilot we just put an (ON NONE ON) switch that
controls the grounding for the switches located on the two sticks, you will
want to keep the PTT on both sticks alive no mater what stick the isolate
switch is favoring.
The rest of my 2.6666666666 cents worth
Noel
stein(at)steinair.com
PostPosted: Wed Dec 20, 2006 4:49 pm    Post subject: switches? Reply with quote
Hi Chris,
If you're using anything other than an RV-10 Autopilot or Sorcerer you can't
switch between a NAV & GPS....only RS-232 and/or ARINC signals (of course
there is always an exception, this time being the 480). You can switch
between two devices RS-232 GPS signals and/or two devices which give RS-232
& ARINC, but typically the autopilot source select switch that you see on
most Chelton panels is for the GPS feed only. The NAV side requires the
higher end AP's and then it would require a multiple pole relay due to the
large number of wires needed. If it's GPS & ARINC only it's only 1 or 3
wires....
I hope I helped a little, I know - clear as mud right?!?! Give me a call of
list and we'll get it figured out for you. Stick functions depend totally
on the number of items being switched, but if it's many of them then a relay
is a must.
Cheers,
Stein.
[quote]--
Tim(at)MyRV10.com
PostPosted: Wed Dec 20, 2006 5:56 pm    Post subject: switches? Reply with quote
You've got some good answers already Chris, but I'll try to explain
mine, and in a different way.
You can either do a double-pole double-throw, or you can get a quad-pole
switch. There are 2 ARINC lines, and 1 serial lines that are in
question. The serial line just gets the GPS position data from
the GPS, so the Autopilot knows it's TRK. If you don't provide
GPS, it would only know heading. The ARINC does the controlling
of the autopilot. So now it gets fun... You can leave your
Serial switch on one GPS all the time if you wish, if you have a
GPS you can count on. Your ARINC you may want to switch between
an EFIS or a NAV/COM/GPS unit. I have my Cheltons or my GNS480
drive my autopilot.
Now, on the panel is a source select switch for those 2 systems.
That one just switches the ARINC lines, in my case. So I can
control the system from either source. My GPS signal I have
on an under-panel hidden switch, that can select between my
Chelton GPS, or the GNS-480. This switch I usually leave on
the GNS-480 side, because that's my WAAS GPS that supposedly
would be top notch. However, I did put the switch there,
because if I need to run at minimum power draw, my GNS-480
is getting the boot and it shuts off with the master, when I'm
running E-bus only. So therefore, I wanted a switch behind the
panel that I could move to the other side for GPS source. It's
just on a little L bracket on the panel so it's easy to feel for
and find.
Now for the stick stuff. I really like the way I did it, and
here's how and why.
On my panel I have a switch labeled like
TRIM CONTROL - Pilot / Co-Pilot
The labeling isn't what I'd want, and you'll see why.
My PILOT side stick is always active, for everything. I didn't
want ANY switch to knock me out of control. I will not let
most anyone fly my plane from the Left seat. My CO-Pilot stick,
however, has the switches for Trims, Frequency flip-flops, and
anything else that I deemed something that the kids or another
person could bump or mess with, as "restricted" devices. When
the switch is in the PILOT position (should read PILOT ONLY), then
those items have their grounds cut off....so the switches don't
function. When it's in the Co-Pilot position (Should read
PILOT/CO-PILOT), then those grounds are available and the functions
will work. This allows me to basically deactivate that stick
for all but a couple things, like PTT, unless I want it activated.
When I fly with the wife, it's usually activated. When the kids
come up, it's rarely activated. It works very well and
should help keep people from bumping things they shouldn't.
Note that since it's just one ground, the switch can be a SPST
if you wish. There isn't a center position.
Chris Johnston wrote:
Hey all -
Thanks all!
cj
#40410
fuse
Tim(at)MyRV10.com
PostPosted: Wed Dec 20, 2006 5:59 pm    Post subject: switches? Reply with quote
I forgot to add in my post I just did for this reply that on the
Autopilot source, you could switch your stuff with a quad switch,
and flip both the ARINC and Serial lines from source to source, and
that would work fine too. That would be the simplest way to
do it, but it would have to re-acquire itself when it loses the
GPS signal to the AP, so it would take a couple more seconds for it
to re-learn it's TRK.
Hey all -
Thanks all!
cj
#40410
fuse
jesse(at)itecusa.org
PostPosted: Wed Dec 20, 2006 8:00 pm    Post subject: switches? Reply with quote
Am I wrong in thinking that the ARINC is just for adding the GPSS feature,
but with just the serial connection you can still have the GPS control the
autopilot, but it will not "cut the corner" in a turn at a waypoint? I
think I remember this being the case. In this case you don't truly NEED
ARINC at all, but it makes it better.
In answer to your question as asked, the NAV radio and the GPS do completely
different things in the AP, so you don't need a switch at all. The NAV
radio would control the AP when flying on a VOR, LOC or ILS and the GPS
would control it when flying, well, GPS. As Stein said, this would only
apply to the RV-10 AP or the Sorcerer, since none of the others have the NAV
function. If you are referring to two actual GPS sources, then the other
replies will do the trick. For the Sorcerer, the NAV side connects to GS
Up, GS Down, Nav Left, Nav Right, and LOC trigger wires from the Nav radio.
On the GPS, you have the RS-232 wire and two ARINC's if you are using that
function (which I very much do recommend, in case my post leads you to
believe that it isn't beneficial).
On the trims, contrary to what may be normal these days in "Experimentals",
I wired all controls on both sticks active always. No switch. The only
problem may come when the copilot bumps the non-momentary flap up switch and
leaves it up and then the pilot tries to lower the flaps and they don't go
down. To remedy this I just put in a momentary up as well as momentary down
on the copilot's flap switch. Nothing has blown up yet, but it might at any
time.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Cell: 352-427-0285
Fax: 815-377-3694
