Tapping flap pushrod
Goto page 1, 2  Next
recapen(at)earthlink.net
PostPosted: Sun Dec 10, 2006 4:32 pm    Post subject: Tapping flap pushrod Reply with quote
Fellow listers,
I've been trying to tap the pushrod for my flap links.
First, I tried just running the tap through - the tap and tube would just
spin in whatever I was trying to hold the tube in.
Next, I tried drilling out the tube with a bit slightly smaller than
recommended for the tap - more successful, except that I could only turn the
tap in one turn at a time.
The next thing I'll try is getting the correct size drill bit (#3) for the
1/4x28 tap.
After that, buying the VA-256 RV9 rods might cure what ails me.
I guess part of my issue is being able to hold the tube while I'm tapping
it.
Any suggestions would be appreciated,
Ralph Capen
n616tb(at)btsapps.com
PostPosted: Sun Dec 10, 2006 4:50 pm    Post subject: Tapping flap pushrod Reply with quote
Ralph,
I had a terrible time with that and marred mine up real bad. I used the
buffing wheel to smooth it back out but wasn't happy about it. I figured if
I ever re-visit that area I would replace them with the hex rods.
Sorry I can't help as I didn't have the answer either.
Tim
[quote] --
Bob Collins
PostPosted: Sun Dec 10, 2006 4:57 pm    Post subject: Tapping flap pushrod Reply with quote
Ralph:
I put the tube(s) in a vice (covered it with some duct tape first)...I'd
turn the tap and if the tube started to turn, I gave the vice a crank. I
did short amounts of tapping, and then backed the tap off...and kept
repeating. The tube didn't collapse in the pressure of the vice and it came
out OK. It was a bit of a P-I-T-A.
Bob
Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/
lhelming(at)sigecom.net
You are right, every tap has one recommended correct drill size. Be sure to
use oil when you work with the tap. Stop every 1/2 turn or so and back up a
little bit to clear the metal. Go forward another 1/2 to 1 turn and back up
again to break free the metal. That is how I did it and it worked ok. I
like to put some rubber tubing about the part and put in a vice to hold it
securely. Larry in Indiana
dan(at)rvproject.com
PostPosted: Sun Dec 10, 2006 5:00 pm    Post subject: Tapping flap pushrod Reply with quote
it.
If you don't have access to a lathe, you could do what I did...
I used the rubber pads on my vise jaws. Clamped the tubing in the vise the
long way, to maximize how much area was held by the vise. Lube the tap
liberally. Worked for me.
)_( Dan
RV-7 N714D (1150 hours)
www.rvproject.com
Hopperdhh(at)aol.com
Ralph,
I have a drill press vise that has a V-groove to hold the tube exactly(?). Drill it with the right size for the 1/4-28 tap. Then put the tap in the drill press, turning it by hand to run the tap in 2 or 3 turns. This will start it straight. Then you can take it out of the drill press and finish tapping it by hand. Use tapping fluid (thread cutting oil). The key is to get it started straight.
Dan Hopper
RV-7A Flying 180 hours.
In a message dated 12/10/2006 7:34:25 PM Eastern Standard Time, recapen(at)earthlink.net writes:
--> RV-List message posted by: "Ralph E. Capen" <recapen(at)earthlink.net>
Fellow listers,
1/4x28 tap.
it.
Ralph Capen
PostPosted: Sun Dec 10, 2006 5:05 pm    Post subject: Tapping flap pushrod Reply with quote
In a message dated 12/10/2006 8:02:35 PM Eastern Standard Time, Hopperdhh(at)aol.com writes:
Ralph,
Dan Hopper
I meant to say "exactly(?) vertical", obviously!
PostPosted: Sun Dec 10, 2006 5:09 pm    Post subject: Tapping flap pushrod Reply with quote
Thanks for the info - lotsa responses really quick....
Worth my donation
More tools on order....
PostPosted: Sun Dec 10, 2006 6:32 pm    Post subject: Tapping flap pushrod Reply with quote
A lath is even better since you can chuck it up horizontal on the lathe line. I have an easy tap that allows it to tap under power with a clutch. Unfortunately when I did mine, my smithy was already moved to Texas. I do think getting the hole drilled straight and then getting the tap started straight with the hole is 9/10 of the problem.
Tim
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Hopperdhh(at)aol.com
Sent: Sunday, December 10, 2006 7:00 PM
To: rv-list(at)matronics.com
Subject: Re: Tapping flap pushrod
Ralph,
Dan Hopper
Fellow listers,
1/4x28 tap.
it.
Ralph Capen
www.aeroelectric.com
jmsears(at)adelphia.net
PostPosted: Mon Dec 11, 2006 3:39 am    Post subject: Tapping flap pushrod Reply with quote
> tap started straight with the hole is 9/10 of the problem.<<
Tim is right, it would be much easier to do this with a lathe. This makes
the second time that I've seen a lathe recommended in the last couple of
weeks, or so. Fortunately, Van's parts don't require the use of a lathe.
I'm betting very few of his customers have lathes; and, the rest don't want
to buy them to complete their projects. Most of us figure out how to do the
tasks without one. Now, if one were maunufacturing his own RV parts with
plans, only, that would be a different matter. I'm thankful that I don't
have to do that.
When I did the pushrods on my -6A, my problem wasn't doing the tapping. It
was getting a tight fit on the threads of the bearing. There was a little
play between the bearing and rod, which made the fit as it if was worn out
before it was ever used. As it turned out, the tap I had was a cheap one
that made bad threads. It was fine for building model airplanes; but, it
needed to be a little better for full size construction. I went to the
local industrial supply store and got a good one. Problem solved.
Fortunately, good taps are available to all of us at reasonable prices, if
one needs one. I think Avery is one of those sources, if one doesn't have
an industrial supply store at hand.
Someone mentioned the hex rod that's already threaded. Now, that may be a
better suggestion than threading the tube that comes with some of the older
kits. It appears to be much stiffer than the older version and costs
little. Personally, I'd make that my first choice. I'm not one of those
"perfect" pilots; so, I sometimes let Scooter get a little out of the white
arc after I've dropped the flaps. I cringe when I do that. I don't have
hex tubes on Scooter's flap actuator. Sad
Jim Sears in KY
RV-6A N198JS (Scooter)
RV-7A #70317 (Project on hold due to laziness)
EAA Tech counselor
aerobubba(at)earthlink.ne
PostPosted: Mon Dec 11, 2006 7:38 am    Post subject: Tapping flap pushrod Reply with quote
Hi Ralph-
To expand a tad on what's already been written, I clamped my tubing in the
vise horizontally between two blocks of pine. I drilled the tube out with
a hand drill and plenty of lube. The geometry / depth of the hole makes it
pretty much self aligning. Anytime the tube would start to slip, I'd give
the vise another crank. Same process tapping. Just don't get any lube in
the grip area. By the time I was done, the pine blocks had an almost 180
deg trough in them, but there was no discernable deformation of the tube.
No problemo!
glen matejcek
aerobubba(at)earthlink.net
brianpublic2(at)starband.
PostPosted: Mon Dec 11, 2006 8:17 am    Post subject: Tapping flap pushrod Reply with quote
I use rubber jaws in my vise that have a v-groove in them - one running
horizontally and one running vertically. This will hold things like round
tubing snugly without marring it. Sorry, I don't remember where I got it,
but I'd think common tools sources would have it. Email me direct if you
want a pic of it, if you aren't sure of what i mean. Also, as someone else
wrote, make sure you use the tap with lube and work it in using a
back-and-forth motion - fwd 1/8 turn, back 1/4 turn, over & over.
brian
http://brian76.mystarband.net/RV-7Ahome.htm
truflite(at)yahoo.com
PostPosted: Mon Dec 11, 2006 12:22 pm    Post subject: Tapping flap pushrod Reply with quote
I don't think I will have a problem with this as I
have a full size lathe and a mill in my basement. If
anyone wants to take advantage of this, feel free to
email me. It would not be a problem to do this
tapping. Just pay shipping.
Dave Nellis
Fellow listers,
links.
1/4x28 tap.
what ails me.
it.
Ralph Capen
Click on
about
provided
www.buildersbooks.com
Admin.
browse
Subscriptions page,
FAQ,
Want to start your own business?
http://smallbusiness.yahoo.com/r-index
zackrv8
PostPosted: Mon Dec 11, 2006 1:12 pm    Post subject: Re: Tapping flap pushrod Reply with quote
Ralph,
Contact Dave at 302-437-6087. Tell him what RV model you are making and what length. He will tap these out of aluminum or stainless steel. The neat thing about stainless is that it is stronger, more corrosion resistant and polishes up nice. OK, it adds 1/2 ounce to the total weight of the plane! So what. Go for the stainless!
Zack
recapen(at)earthlink.net wrote:
Fellow listers,
1/4x28 tap.
it.
Ralph Capen
RV8 #80125
RV10 # 40512
khorton01(at)rogers.com
PostPosted: Mon Dec 11, 2006 4:06 pm    Post subject: Tapping flap pushrod Reply with quote
On 11 Dec 2006, at 10:37, glen matejcek wrote:
<aerobubba(at)earthlink.net>
Hi Ralph-
in the
out with
makes it
Maybe I'm proof that nothing is idiot proof, but I did manage to tap
a rod with the thread not aligned with the hole. On my next
attempts, I chucked the tube in a drill press, and turned the chuck
by hand, while holding the tap aligned with the rod. This worked
very well, as the fact that the rod was being turned meant that it
was impossible to have the tap remain misaligned on any given axis.
You do need to back up every turn or so to break the chips off. The
fact that the tap is coming up from the bottom helps the chips fall
clear without having to screw the tap all the way out. You do need
to tighten the chuck quite tightly on the rod to ensure it does not
slip.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
phil(at)petrasoft.net
PostPosted: Tue Dec 12, 2006 6:57 am    Post subject: Tapping flap pushrod Reply with quote
I found that using my tube flaring tool to hold these pieces worked
well. RapidTap cutting fluid works fine for aluminum and some kind of
cut lubrication is definitely necessary. As others have said having the
correct hole size before tapping is absolutely essential. Also make
sure you are using a through hole tap and not a bottom hole tap.
Godspeed,
Phil Birkelbach - Houston Texas
RV-7 N727WB
http://www.myrv7.com
Hopperdhh(at)aol.com wrote:
Ralph,
Dan Hopper
Fellow listers,
would just
only turn the
for the
1/4x28 tap.
tapping
it.
Ralph Capen
halbenjamin(at)aol.com
PostPosted: Tue Dec 12, 2006 10:58 am    Post subject: Tapping flap pushrod Reply with quote
I drilled a hole lengthwise through a cheap 1" x 2" piece of wood about 4 inchs long. The hole diameter was just large enough to slide the tube through. Then you can clamp it tight in a vise without distorting the tube.
Hal Benjamin RV-4
Finish kit in the mail
Long Island, NY
PostPosted: Tue Dec 19, 2006 10:19 am    Post subject: Tapping flap pushrod Reply with quote
I was looking at something else, and realized I had a picture of these
rubber jaws I was referring to here
See the first pic on this page:
http://brian76.mystarband.net/tiedown.htm
PostPosted: Tue Dec 19, 2006 11:30 am    Post subject: Tapping flap pushrod Reply with quote
And I like the subject of that page by itself.....
Another idea that I can steal!
PostPosted: Tue Dec 19, 2006 12:58 pm    Post subject: Tapping flap pushrod Reply with quote
If you like custom ideas, there are some more on this page:
http://brian76.mystarband.net/custom.htm
brian
Goto page 1, 2  Next
Page 1 of 2
