cjensen(at)dts9000.com Guest
Posted: Tue Dec 12, 2006 5:12 am Post subject: Conversion to Experimental |
In reading about conversion of six-packs and upgrading panels in older planes, et al, if a person wants to upgrade to a glass panel, is there a reason more people don't just slap an "Experimental" label on the certified plane and put in a non-certified panel, such as GRT, TruTrak, et al. It's understood that the plane is devalued by making it "Experimental" but then, the value is also increased with the upgraded panel. And, with the difference between a certified glass panel and a very good, but non-certified glass panel, you can stick the difference ($30,000 - $50,000?) in your pocket and buy a lot of gas.
Since it doesn't seem to be done by many people, I must be missing something?
Chuck Jensen
AV8ORJWC
Joined: 13 Jul 2006 Posts: 1101 Location: Aurora, Oregon "Home of VANS"
Posted: Tue Dec 12, 2006 5:40 am Post subject: Conversion to Experimental |
Mike Dennis of Oregon Aero did exactly that with one of his two Pilatus PC-12s. No small chunk of change. Kind of reminds me of Malcolm Forbes corporate jet. Mike wanted IR forward looking video. Almost lives in the plane, growing his business. The plane is beautiful and his IA did not have a problem doing the Annual Inspection on a Certified Aircraft with a Leading Edge electronic device installed under the "Experimental" tag. At some point the equipment can come out of the increase in value is greater being back to Certified. Commercial use is the stumbling block with an "Experimental" tag.
John Cox
[quote] From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Chuck Jensen
Sent: Tuesday, December 12, 2006 5:13 AM
Subject: Conversion to Experimental
Chuck Jensen
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.kitlog.com">www.kitlog.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
| [b]
n395v
Joined: 10 Jan 2006 Posts: 424 Location: Summit, Mississippi
Posted: Tue Dec 12, 2006 6:01 am Post subject: Re: Conversion to Experimental |
All right I am confused.
It is my impression that you can put non certified equipment in a panel if it is not there to replace a required item. It is also my impresion tht this requires a 337?
I am not aware of a reg that allows you to just slap a unit in a plane and tag it experimental.
I also no of no regs that allow you to convert a production plane to experimental with out severe restrictions that would render the plane useless for most purposes.
Am I incorrect?
_________________ Milt |
rtitsworth
Posted: Tue Dec 12, 2006 6:26 am Post subject: Conversion to Experimental |
Chuck asked…In reading about conversion of six-packs and upgrading panels in older planes, et al, if a person wants to upgrade to a glass panel, is there a reason more people don't just slap an "Experimental" label on the certified plane and put in a non-certified panel, such as GRT, TruTrak, et al….
Some investigation of the FARs will show that it is not nearly that simple (rather it is nearly impossible). To begin with, an airplane’s experimental status is granted by the FAA via it’s airworthiness certificate (it is not created by an owner adding an “experimental” label/placard). Changing an A/W cert is not easy to get the FAA to do. Furthermore, there are different types of “experimental” airworthiness certificates and rules/limitations that apply to each (such as experimental - amateur built, experimental – research and development, experimental – exhibition, etc.) For reference, see documents at:
http://www.faa.gov/aircraft/air_cert/airworthiness_certification/sp_awcert/experiment/
http://www.faa.gov/aircraft/air_cert/airworthiness_certification/sp_awcert/sp_awcert_regs/
In (gross) summary…
An “experimental amateur built” plane needs to be built for educational and recreational purposes and the builder has to show he/she did more than 51% of the work.
An “experimental – research and development” airplane is typically limited to test flights (very limited distance and flight conditions).
An “experimental – exhibition” airplane is typically limited to specific events (i.e. only flight to/from and at pre-specified airshows).
None of those typically apply and/or are very appealing.
The FAA has two processes that allow alteration of a type certificated aircraft (in addition to the AD process which might mandate it). The first is a STC (supplemental type certificate which is approval granted to a specific alteration for a specific make/model (usually granted to the manufacturer of the modified part). The second is the field alteration process (typically called a 337 based on the associated FAA form) which allows owners to have mechanics alter (add avionics, etc) to a type certificated airplane. 337 alterations are approved by the local FAA FSDO (field standards district office). Ref: http://forms.faa.gov/forms/faa337.pdf
Rick
Sent: Tuesday, December 12, 2006 8:13 AM
Subject: AeroElectric-List: Conversion to Experimental
Chuck Jensen
Do Not Archive[b] [/b]
| Quote: | | www.aeroelectric.com | 0123456789012345
pilot4profit(at)sbcglobal Guest
Posted: Tue Dec 12, 2006 6:29 am Post subject: Conversion to Experimental |
I’ve been told by aircraft sales people that a certified aircraft gone experimental is the equivalent of aeronautical leprosy. They say the value is severely impacted, and the aircraft can not be used for any commercial purpose (flight training, aerial photography, SAR, CAP, etc.). In addition, restoring one to certified status is supposed to be tough. Now whether you buy those arguments or not, is up to you, but the FARs are pretty clear about the commercial use thing. It may just be another excuse to say your airplane is worthless so they can steal it from you at a fraction of it’s worth. I don’t trust sales people anymore.
CS
Chuck Jensen
[quote] [b]
Posted: Tue Dec 12, 2006 6:41 am Post subject: Conversion to Experimental |
Rick,
Oh. Maybe that's why its not done more!! That's kind of a shame.
Chuck Jensen
oldbob(at)BeechOwners.com Guest
Posted: Tue Dec 12, 2006 6:44 am Post subject: Conversion to Experimental |
Good Morning Milt,
Your interpretation of the rules matches mine.
Having said that, I guess we have to admit that each
Experimental Certification is an individual
negotiation between the applicant and the responsible
FAA inspector who issues the certificate.
The primary exception is for those aircraft which meet
the amateur built sub provision of experimental
certification.
There are other provisions which are somewhat
restrictive that apply to various other special
conditions.
If the rules, as we interpret them, are followed, any
experimental, other than for an amateur built
aircraft, must delineate the conditions under which it
may be operated so as to prove or disprove the
efficacy of the project being experimented with or to
comply with the special operations that are approved.
I have seen a couple of experimentally licensed
aircraft with operating limitations so loose that the
aircraft could be operated almost as freely as one
that had a standard certificate.
It was my personal opinion that those certificates did
not meet the intent of the regulations, but, until
such time that some FAA official felt the same, the
certificate remains in effect.
I am not sure what was meant by the reference to one's
IA. An A&P holding an Inspection Authorization does
NOT have the power to approve experimental operations.
It really does ---- All Depend!
Do we still agree?
Happy Skies,
Old Bob
AKA
Bob Siegfried
Downers Grove Illinois
--- N395V <n395v(at)hughes.net> wrote:
requires a 337?
for most purposes.
Am I incorrect?
Milt
N395V
F1 Rocket
http://forums.matronics.com/viewtopic.php?p=80992#80992
LloydDR(at)wernerco.com Guest
Posted: Tue Dec 12, 2006 6:56 am Post subject: Conversion to Experimental |
He also changed an air inlet for one of the generators, and is working with Pilatus to get the mod to everyone. His family lives near 4G1 in PA, so he is out here all the time. A couple of months ago we had a Lobster flyin. The FBO coordinated it, and Mike flew the Pilatus to Maine to get the lobsters, at least they had a sweet ride before they got the boiling pot!
Dan
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John W. Cox
Sent: Tuesday, December 12, 2006 8:40 AM
Subject: RE: AeroElectric-List: Conversion to Experimental
John Cox
Chuck Jensen
nuckollsr(at)cox.net Guest
Posted: Tue Dec 12, 2006 7:20 am Post subject: Conversion to Experimental |
Jensen
Yeah, it's called the FAA. I've placed many an x-ticket
on a certified ship for the purpose of conducing engineering
research. But the FAA's stance x-ed TC aircraft for
the purpose of conducing engineering tests and the
airplane cannot be used as a standard TC aircraft until
restored to certified condition. We have a small fleet
of experimental aircraft used for research and development
but these aircraft cannot be used for anything except
company engineering business.
The "experimental" tag on OBAM aircraft gives rise to a lot
of mis-understanding. 99% of the OBAM aircraft flying
are obviously not experimental but Owner Build and/or
Maintained. In Canada, you can de-certify an older out-of-
production aircraft and begin to own, operate, modify and
maintain it as if it were an RV or Kitfox. These
aircraft are far from "experimental" in the engineering
and development sense of the word. The owners are simply
attempting to breath new life into older airplanes by modernizing
some of its features.
Converting an older airplane to a new 6-pack or glass-panel
configuration is often done by qualified shops under a
337. The gentleman who initially inquired about this can
enlist the help of an AI, local flying-fuzz and install any
new gear and panel arrangements that have been used on
other aircraft with no more than the usual bureaucratic
difficulties. It's done all the time.
< with experiment. >
< --Lawrence M. Krauss >
Posted: Tue Dec 12, 2006 7:23 am Post subject: Conversion to Experimental |
Yes, you are incorrect, you can take a certified aircraft, and
re-register it from the standard category or whatever it is in and
designate the entire craft experimental. Then you can do what you want
with it, but you will not hold the repairman's certificate unless you
built it, so you would still need an A&P to do the annual. At least this
is how I understand it from talking with the local FSDO.
Dan Lloyd
Earl_Schroeder(at)juno.co Guest
Posted: Tue Dec 12, 2006 7:55 am Post subject: Conversion to Experimental |
I'm wondering if this 'de-certified' aircraft can then be moved to the
US and that designation remains?
If so, perhaps I can take my 'ol C-150 up there for a visit and upgrade??
mlas(at)cox.net Guest
Posted: Tue Dec 12, 2006 8:44 am Post subject: Conversion to Experimental |
To all,
Rick was right on the money. If and when you convert an airplane’s airworthiness from Standard to Experimental many things change. The first issue is what type of Experimental Certificate will you apply for and be approved for? In order to convert an airplane you must have a new Airworthiness Certificate issued which will be accompanied by a list of Limitations for operation. The list of limitations are covered by Advisory Circulars which are generally not regulatory for part 91 operations but the limitations issued with the new airworthiness certificate will change that. The list of limitations issued are derived from the AC’s that cover these types of conversions. There is some latitude with these limitations but you never know until you do it. Unless you get an FAA inspector or DAR if authorized to issue an Experimental Exhibition Certificate (many are not) to cope a previously issued set of limitations without question, you will be subjected to their interpretation of the AC’s in question.
As for valuation, that is very subjective. If you take a new $1,000,000 Baron and are able to convert it to an Experimental certificate I would think you would loose as much as 75% or more of the original value due to the new limitations and insurance issues. But if you take an old Cherokee 140 and upgrade it with a bigger engine, new glass panel, IR video, ect. The overall selling amount would improve but would most likely not cover the cost of the improvements and therefore the value would remain close to the same..
Here is a different view, what if you bought an old Cherokee 140 for $10,000 with an old panel and run out engine. Your good with you hands and can do good work that an A&P would like. Let’s assume that you were able to convert the aircraft Certification to Experimental Exhibition with very relaxed limitations. You and you’re A&P friend overhaul the engine, repair cracks, corrosion, broken parts (for example: door handles, head liners, switches, lighting, seats), up graded the avionics to a new glass panel, and certify during the condition inspection the aircraft airworthy. You would be able to do this any way you would like within the scope of the newly issued limitations. If you had to do this with a Standard Airworthiness Certificate this could be cost prohibitive if you had to meet part 43 with a $10,000 airplane that is only worth $20,000 in good condition with a Standard Certificate. This example would be one reason I would consider a conversion to Experimental. But as mentioned above you would have to have a good handle on the re-certification process or one might find them selves with a 1500 pound paper weight at the end of the day.
Mike Larkin
11/22/2006
11/22/2006
AV8ORJWC
Posted: Tue Dec 12, 2006 10:27 am Post subject: Conversion to Experimental |
Our ole C-421C with Riley conversion with Lyco turbines (under a STC)
was converted for MaxViz. Just like Mike Dennis did for his PC-12. It
is easy to misunderstand when dealing with Certified and rolling out new
avionics onboard. The bird gets reconstructed under a 337 back to
certified configuration at the end of the trial period. It receives a
new annual and a trip back to the FSDO in hopes that the MIDO doesn't
want more to reissue a Standard Certificate.
John Cox
Kellym
Joined: 10 Jan 2006 Posts: 577 Location: Sun Lakes AZ
Posted: Tue Dec 12, 2006 1:25 pm Post subject: Conversion to Experimental |
Hi John,
Let's not confuse the troops too much. There is not an Experimental
category for "I don't want to follow the TC rules and want to do whatever
hits my fancy, with a TC production aircraft" crowd.
The most common available categories, as Bob pointed out are
Experimental, R&D, where you get approval from FSDO for specific
modification development towards 337, STC, TC, etc. with very specific
operating limitations and time limits. Don't get it done in time, beg for
extension at FSDO, but it will never be for unlimited time and uses.
Amateur built...persuade FSDO that you are building 51% of the aircraft,
that just happens to also use portions of a TC aircraft, and then you get
the privileges that go with that category.
Experimental Exhibition, limited to flying to airshows, exhibitions, etc
which have to be reported, may be restricted, no flight over congested
areas, etc. Probably prohibits pax beyond "required" crew as well.
<johnwcox(at)pacificnw.com>
John Cox
KCHD |
khorton01(at)rogers.com Guest
Posted: Tue Dec 12, 2006 6:24 pm Post subject: Conversion to Experimental |
On 12 Dec 2006, at 10:53, Earl_Schroeder wrote:
<Earl_Schroeder(at)juno.com>
the US and that designation remains?
upgrade??
Nope, once an aircraft is moved to the Owner Maintenance category,
you can't even cross the border into the US. The Owner Maintenance
category is not recognized by ICAO, so it is not recognized by any
other country.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
Bob McC
Posted: Tue Dec 12, 2006 6:34 pm Post subject: Conversion to Experimental |
Bob is correct in his interpretation of Canadian regulation, but in answer
to your question, my understanding is NO! And not only that, but the FAA has
apparently also decided that planes which have followed this procedure are
no longer even allowed to fly into the US at all, even when still registered
in Canada and flown by a Canadian pilot. There are no such exclusions on
Canadian OBAM aircraft which are welcomed across the border with very little
hassle. Go figure. This fact has put a considerable damper on the
desirability of this conversion. Also under Canadian law, once the plane has
been de-certified under this rule it is then ineligible to ever be converted
back into the TC category.
Bob McC
Toronto, Canada
_________________ Bob McC
Falco #908
(just starting) |
echristley(at)nc.rr.com Guest
Posted: Tue Dec 12, 2006 8:13 pm Post subject: Conversion to Experimental |
Kelly McMullen wrote:
| Quote: | Experimental Exhibition, limited to flying to airshows, exhibitions, etc
"Limited" is a subjective term in this case.
First, you're given a practice area that is something line 100 mile
radius or so. The category includes a lot of fast airplanes, and the
pilots really do need a large area to practice for proficiency. This is
actually a good provision.
Then at the beginning of each year, you tell the FAA all the flyins that
you might want to attend. No need to restrict yourself, just tell them
you might want to go to all of 'em. There's also no penalty if you
don't quite make it there and have to stop somewhere short of the
destination.
Finally, for the most part, there is no restriction on passengers just
for it being an exhibition plane.
I've heard that the FAA is cracking down on this category, but
historically the restrictions have been a paper tiger. You can pretty
much do whatever a normal GA pilot would do, you just have to take a
couple more steps to cover your tracks.
ainut(at)hiwaay.net Guest
Posted: Tue Dec 12, 2006 9:27 pm Post subject: Conversion to Experimental |
If you're ONLY adding some non-certificated instrumentation, you could
use the loophole that allows us to add non-certificated GPS's without
damaging the craft's certs. You'd still have to keep all the
certificated minimum required instruments though.
David M.
Dan Lloyd
richard(at)RILEY.NET Guest
Posted: Tue Dec 12, 2006 10:46 pm Post subject: Conversion to Experimental |
At 01:09 AM 12/13/2006, you wrote:
| Quote: | Then at the beginning of each year, you tell the FAA all the flyins
that you might want to attend. No need to restrict yourself, just
tell them you might want to go to all of 'em. There's also no
penalty if you don't quite make it there and have to stop somewhere
short of the destination.
You can also update your list at any time. Like, for instance, the
night before you fly off across country, you fax them an update to
include your cross country proficiency flight.
Posted: Wed Dec 13, 2006 6:04 am Post subject: Conversion to Experimental |
Given the many postings about all the hurdles to conversions, one comes
away with the over-mastering impression that the FAA is THE hurdle. Not
that it's unsafe, unwise or stupid, but it's a bad idea because the FAA
says so. I can understand the FAA being control freaks for commercial
aviation--a lot of traveling people are involunatarily putting
themselves in situation out of their control and they deserve protection
from unscrupulous, unsafe operators. Whether the FAA accomplishes that
or not, some may argue with, but the intent is clear.
But as we step down the aviation food chain, why the FAA feels the need
to obsess over control of personal aircraft is less understandable. Is
it so outrageous an idea that if someone wants to put 6" letters
EXPERIMENTAL on an aircraft, that they shouldn't have great leeway in
what they do...much as the OBAM does? Owning a C150 that was not owner
built and is subsequently converted to Experimental is no different than
owning an RV that was built by someone else. Both have to be inspected
by an A&P. How is one more, or less, safe than the other?
With that said, and given the personality of the FAA, I stand amazed
(and thankful) that the 51% rule was reviewed and the repercussions seem
to have been minimal--to date. This initially looked very much like the
proverbial 'camel's nose under the tent' problem, but the FAA seemed to
show considerable restraint in reining in the most egregious examples
that were pushing the boundaries without going on a boundless witch
hunt.
Gads, if only the world were perfect!!
Chuck Jensen
